Manage Task Logs
The Manage Task Logs page provides data that describes a task’s processing information. The logs are automatically generated while a task runs.
On this page:
Fields and Buttons
The top section of the Manage Task Logs page allows you to search for task logs matching criteria in the fields. Fields and buttons include:
  • Task ID: Task’s system-assigned, unique identifier.
  • Task Log ID: Task log’s system-assigned, unique identifier.
  • Refresh Rate: Frequency, in seconds, that the results should be automatically updated.
  • Run Log ID: Run log’s system-assigned, unique identifier. By entering this criteria, you will search for task logs that were processed within a specific run.
  • Get Logs: Initiates a search for logs matching criteria set in the fields.
Back to Top
Data Table
The data table contains the following elements:
  • Server Process: Server node that ran the task.
  • Task Start Time: Date and time that the task started.
  • Task End Time: Date and time that the task ended.
  • Transaction: Associated transaction’s system-assigned, unique identifier.
  • Explore: Opens theManage Calcsdialog box.
  • View: Opens the View Task Logs dialog box, which displays processing information such as the execution type, addresses to email if the task was successful or failed, and the task’s status code.
  • Transaction: Navigates to the Manage Transactions page and displays the current context to provide further information.
Back to Top
View Task Logs
The View link in the data table on the Manage Task Logs page launches the View Task Logs dialog box. This dialog box displays some of the same run log information as well as some additional information:
Fields and Buttons
  • Execution Type: Method that the task was initiated.
  • Success Email: Address to send a notice when the run completes.
  • Failure Email: Address to send a notice in case the run fails.
  • Run Mode: Run’s processing category.
  • Data Start Time: Earliest date and time of the data that was included in the run.
  • Data End Time: Latest date and time of the data that was included in the run.
  • Status Code: Indicates if the run status (In Progress, Successful, or Fatal error).
  • Task Progress: Task’s current status (percentage of completion).
  • Task Priority: Indicates the task’s priority on the node.
  • Scenario ID: Associated scenario’s ID.
  • Filter ID: Associated filter’s ID.
  • Filter Seq ID: Filter’s system-generated, unique identifier as listed on the filter sequence table.
  • Cancel: Closes the dialog box.
Back to Top
