Connect to Your Data Using Datasets
Datasets are self-service data models that you build specifically for your data visualization and analysis requirements. You can connect to your data using datasets and perform a variety of data visualization and analysis tasks. See Connect to Your Data Using Datasets for more information, and review the following applicable topics:
- About Opening Datasets
- What Are Datasets?
- Typical Workflow to Create a Dataset from a Connection
- Typical Workflow to Create a Dataset from a File
- View Available Connections
- Data Sources Available for Use in Datasets Containing Multiple Tables
- About the Dataset Editor
- Create a Dataset From a Connection
- Add Multiple Connections to a Dataset
- Add a Table to a Dataset Using a SQL Statement
- Create Datasets from Files
Note: Oracle Utilities Analytics Visualization (OUAV) only supports creating or opening datasets from spreadsheets and the source database. See the restrictions described in Connect to Your Data for more information.
