Perform Demo Pre-Installation Steps for OUAW
This page provides the information necessary to plan and execute the demo data import, installation, and configuration required for Oracle Utilities Analytics Warehouse (OUAW).
  • Before installing the prerequisite software, the user must perform a sequence of downloads and installations, as well as necessary validations on the database and application servers.
  • The person responsible to install OUAW must have database and middleware administrator knowledge.
System Requirements and Supported Platforms
Before you begin the installation, note the following:
  • Both the hardware and the network requirements must be met. See System Requirements and Supported Platforms.
  • You must determine your installation target. The Oracle Utilities Analytics Warehouse can be installed on either the database or the application servers.
  • The OUAW deployment topology option is a multi-nodes topology that deploys the database and application components into separate dedicated servers, while a higher capacity server can have both OUAW database and application components on one single server.
Demo Pre-Installation Requisites for OUAW Database Server
This section lists the prerequisite software required to install OUAW on the database server target, which is going to be used by the demo database component and the repositories created for the OUAW dashboards component.
The following table includes some directory structures examples.
  • Customers can decide where to install this software. Make sure to note all the home directories on this list, as they will be used during OUAW installation.
  • Make sure to do every installation using a single OS user and replace all parameters enclosed in <> with the appropriate values.
Task Description
Download and install the database
  1. Download Oracle Database Server Enterprise Edition 19c from Oracle Software Delivery Cloud to a temporary directory.
    Example: </u01/ouaw/temp/database>
  2. Installation can be done at the customized location.
    Example: </u01/ouaw/database> (referred to as ORACLE HOME).
Download and apply the database patch
  1. Download the database server patch 37960098 from My Oracle Support to a temporary directory.
  2. Unzip the patch and navigate to the patch top directory run the $ORACLE_HOME/OPatch/opatch apply
    Follow the readme file for applying patch which is under the patch top directory.
Create the database Create the database for OUAW installation using the AL32UTF8 character set.
Download the OUAW database software
  1. The OUAW media pack can be downloaded from Oracle Software Delivery Cloud (Oracle Utilities Analytics Warehouse v25.10.0.0 Oracle Database Multiplatform.zip file).
  2. Unzip Oracle Utilities Analytics Warehouse v25.10.0.0 Oracle Database Multiplatform.zip to a temporary directory using any zip command utility.
  3. After unzip, find the OUAW Database Installers at the following location:
    </u01/ouaw/temp/database/BI251000>
Download the OUAW demo data
  1. Download Oracle Utilities Analytics v25.10.0.0 Oracle Demo Data part from the Oracle_Utilities_Analytics_Warehouse_v25.10.0.0_Demo_Data.zip file.
  2. Unzip Oracle_Utilities_Analytics_Warehouse_v25.10.0.0_Demo_Data.zip to a temporary directory.
    Example: </u01/ouaw/temp/demo>
  3. After unzip, find the Demo Data dump file and users.sql at the following location after unzip:
    </u01/ouaw/temp/demo/BI251000/Demo>
Demo Pre-Installation Requisites for OUAW Application Server
This section covers the downloads and install instructions that can be performed on the OUAW application server.
Task Description
Download and install the JDK
Java 8
  1. Download Oracle Java Development Kit (JDK) 1.8 from My Oracle Support to a temporary directory on the application server.
    Example: </u01/ouaw/temp/java>
  2. Install the JDK on a customized location.
    Example: </u01/ouaw/java8> (referred to as JAVA_HOME for FMW 12c and OAS installation).
Java 17
  1. Download Oracle Java Development Kit (JDK) 17.0.16+ from My Oracle Support to a temporary directory on the application server.
    Example: </u01/ouaw/temp/java17> (referred to as JAVA_HOME for OUAW installation).
Download and install Database Client
Download the Oracle Database Client from Oracle Software Delivery Cloud and install it at a customized location.
Example: </u01/ouaw/clientBase>.
This task is optional if both the OUAW application and database servers are installed on the same machine. See Install Oracle Database Client for more information.
Download and install Oracle Fusion Middleware Infrastructure
  1. Download the Oracle Fusion Middleware Infrastructure 12.2.1.4 Version from Oracle Software Delivery Cloud into a temporary directory.
    Example:
    </u01/ouaw/temp/middleware>
  2. Install the software on a customized location.
    Example: </u01/ouaw/middleware>. This will be referred to as FMW Home. This installation path can be used for Oracle Analytics Server's ORACLE_HOME.
See Install Oracle Fusion Middleware Infrastructure for more information.
Download and install Oracle Analytics Server (OAS)
  1. Download the latest Oracle Analytics Server (OAS) version 8.2 (OAS 2025) from Oracle Software Delivery Cloud into a temporary directory.
    Example: </u01/ouaw/temp/oas>
  2. Install the OAS software at the <FMW Home> location considering the ORACLE_HOME path. See Install Oracle Analytics Server for more information.
    After installation, the "bi" directory will be located inside the FMW home as <FMW Home>/bi.
Download and apply Oracle Analytics Server (OAS) Patch
Download and apply the Oracle Analytics Server (OAS) patch 38161336 and 34809489 from My Oracle Support.
Follow the README of each Patch Package for applying the patch.
Configure OAS domain
  1. Navigate to the OAS installed $ORACLE_HOME/bi/bin location.
    Example: <FMW Home>/bi/bin
  2. Run the ./config.sh file.
  3. Configure Oracle Analytics Server domain with a customized name on the customized location.
    Example: <oas_domain>
    Example: </u01/ouaw/domains/oas_domain> (referred to as OAS DOMAIN Home). See Configure the Oracle Analytics Server Domain with the Configuration Assistant for more information.
  4. While running RCU as part of domain configuration:
    • Enter the connection string based on the type of database as 'Oracle'.
    • Enter a unique schema prefix.
      Example: '<OAS>'
Download the OUAW application software
  1. The OUAW media pack can be downloaded from Oracle Software Delivery Cloud (Oracle Utilities Analytics Warehouse v25.10.0.0 Dashboard Component.zip file).
  2. Unzip Oracle Utilities Analytics Warehouse v25.10.0.0 Dashboard Component.zip to a temporary directory.
    Example: </u01/ouaw/temp/application>
  3. After unzipping, the Dashboard Component folders are <OAS Version>/rpd, catalog, and WriteBackTemplates.
OUAW Directory Structure and Other Required Information
The software installation directories can be used for OUAW installations and configurations. The locations specified on the following table will be respectively referred to as JAVA Home, Oracle Home, FMW Home, Domain Home and Dashboards Home.
Information Type Description
JAVA_HOME
This is the Java installed location on the OUAW database and application servers.
Example: </u01/ouaw/java8> or </u01/ouaw/java17>
Database Home
The Oracle database installed path on the OUAW database server.
Database Client
The Oracle database client installed path on the OUAW application server.
FMW Home
Oracle Fusion Middleware Infrastructure installation location on the OUAW application server.
Domain Home
The WebLogic Domains (OAS Domain) will be configured in this directory on the OUAW application server.
Dashboards Home
The OUAW installation location where OUAW_DASHBOARD directory will be created after its installation on the application server.
Example: /u01/ouaw/deployment/OUAW_DASHBOARD>
