Upgrade OUAW Components
This page details how to upgrade the database, ETL, admin tool, and dashboard components for Oracle Utilities Analytics Warehouse v25.10.0.0.0.
Upgrade the Database Component
This section details the steps to upgrade the Oracle Utilities Analytics Warehouse database component.
Copy and Decompress the Install Media
  1. Download Oracle Utilities Analytics Warehouse v25.10.0.0.0. Oracle Database part file (Oracle Utilities Analytics v25.10.0.0.0. Oracle Database Multiplatform.zip) from Oracle Software Delivery Cloud onto the target database server.
  2. Create a temporary directory (example: </OUA/temp > for a Linux machine). This directory (referred to as <TEMPDIR> below) must be located outside any current working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
  3. Unzip Oracle Utilities Analytics Warehouse v25.10.0.0.0. Oracle Database Multiplatform.zip to <TEMPDIR> using any zip utility.
  4. Execute the SQL below before installing the RELADM, MDADM, and DWADM Schemas. This provides the required permissions to the users created.
    Usersgrants.sql in <TEMPDIR>/BI251000/Scripts/Usersgrants.sql
Install the RELADM Schema
  1. Log in to the target database server.
  2. Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v25.10.0.0.0. Oracle Database Multiplatform zip file was extracted.
    cd database/BI251000/RELADM/Install-Upgrade
  3. Review Storage.xml to ensure the RELADM user has quota on the mentioned tablespace in file. If not, edit the file with correct tablespace name.
  4. Add JAVA_HOME/bin (JDK 17) to the PATH variable.
  5. Set CLASSPATH pointing to the location where OraDBI.jar and all dependency jars exist.
    export CLASSPATH=<TEMPDIR>/BI251000/RELADM/Jarfiles/*
  6. Execute the command below. Once complete, the utility creates the RELADM schema and system data definitions.
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,RELADM,<Password of RELADM User>,,,,,RELADM -l 1,2 -o -q true
    If an error occurs while executing a SQL or another utility, it logs and displays the error message and allows you to re-execute the current step.
  7. To generate database statistics after connecting to sys user, run the statement below:
    exec DBMS_STATS.GATHER_SCHEMA_STATS('RELADM')
Install the MDADM Schema
    cd database/BI251000/MDADM/Install-Upgrade
  3. Review Storage.xml to ensure the MDADM user has quota on the mentioned tablespace in file. If not, edit the file with correct tablespace name.
    export CLASSPATH=<TEMPDIR>/BI251000/MDADM/Jarfiles/*
  6. Execute the command below. When completed, the utility creates the MDADM schema and system data definitions.
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,MDADM,<Password of MDADM User>,,,,,MDADM -l 1,2 -o -q true
    exec DBMS_STATS.GATHER_SCHEMA_STATS('MDADM');
Install the DWADM Schema
  2. Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v25.10.0.0.0 Oracle Database Multiplatform.zip file was extracted.
    cd database/BI251000/DWADM/Install-Upgrade
  3. Review Storage.xml to ensure the DWADM user has quota on mentioned tablespace in file. If not, edit the file with correct tablespace name.
    export CLASSPATH=<TEMPDIR>/BI251000/DWADM/Jarfiles/*
  6. Execute the command below. When completed, the utility creates the DWADM schema and system data definitions.
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,DWADM,<Password of DWADM User>,DWUSER,DWREAD,DW_USER,DW_READ,DWADM -p <Password of  DWUSER>,<Password of DWREAD> -l 1,2 -o -q true
    If an error occurs while executing a SQL or another utility, it logs and displays the error message, allowing you to re-execute the current step.
    exec DBMS_STATS.GATHER_SCHEMA_STATS('DWADM');
Upgrade the ETL Component
Prerequisites
Before installing the OUAW ETL component, verify the following:
  • Use the same operating system user used to install the required software.
  • Ensure Oracle GoldenGate Microservices is installed on the target database server.
  • Ensure that Oracle GoldenGate Microservices Manager, Admin, and Receiver Services are running on the target database server.
  • Ensure the latest Java 17 version (Example: 17.0.16+) is installed on the application server.
  • Ensure Oracle Fusion Middleware Infrastructure 14.1.2.0 installation and patches are applied on the target application server.
  • Ensure Oracle Data Integrator (ODI) 14.1.2.0 and patches are applied on the target application server.
  • Ensure ODI domain admin and managed servers are in stopped state.
  • Purge all the ODI operator logs.
Create a Security Wallet on the Target Database Server
  2. Create a directory which will be used for security wallet creation.
    Example:
    mkdir -p /scratch/ouawcicd/ouaw_target_wallet
  3. Copy the Target GoldenGate Microservice Root CA & Intermediate certificates (if any) to the created directory and create the wallet with orapki.
    orapki wallet create -wallet <wallet location> -auto_login -pwd <wallet password>
    Example:
    orapki wallet create -wallet /scratch/ouawcicd/ouaw_target_wallet/wallet -auto_login -pwd oracle123
    Where /scratch/ouawcicd/ouaw_target_wallet/wallet is Target Security Wallet location.
  4. Import the Target GoldenGate Microservice Root CA & Intermediate certificates to the created wallet.
    orapki wallet add -wallet <wallet location> -trusted_cert -cert <Root CA/Intermediate Certificate> -pwd <wallet password>
    Example:
    orapki wallet add -wallet /scratch/ouawcicd/ouaw_target_wallet/wallet -trusted_cert -cert DigiCert_Global_G2_TLS_RSA_SHA256_2020_CA1_INT.pem -pwd oracle123
Install the ETL Component
  1. Log in to Oracle Utilities Analytics Warehouse ODI server and start the ODI client.
    export JAVA_HOME=<JAVA 17 HOME>
    export PATH=$JAVA_HOME/bin:$PATH
    cd <FMW 14c Home>/odi/studio/bin
    ./odi
  2. Delete the SFOL framework.
    1. In ODI Studio, navigate to Designer Tab > Load Plans and Scenarios > Framework.
    2. Right-click on Framework then click Delete.
      Delete SFOL Framework from ODI
  3. Navigate to the temporary directory where OUAW installer is downloaded. Example: <TEMPDIR/application>
  4. Set the JAVA 17 HOME and add PATH.
    ETL Installer is now only supported with Java 17.0.16+.
  5. Launch the OUAW installer by running the command below. The OUAW installer Welcome page appears.
    java -jar OUAW_25.10.0.0.0_ETL_generic.jar -logLevel finest
  6. Review the information before you begin the installation. Click Next to continue.
    If you are installing Oracle software on the server for the first time, provide central inventory details such as the inventory directory location and operating system group.
  7. On the Installation Location page, define the installation location in the Oracle Home field and click Next.
    The specified Oracle home directory must be an empty directory.
    Installation Location screen displays a drop-down menu for the user to browse for the Oracle Home
    Field Name and Description Value
    Oracle Home: The directory where the Oracle Utilities Analytics Warehouse ETL is going to be installed.
    This directory location is called the ETL Home. Keep track of it as it will be used during some deployment steps.
    Example: <OUA ETL Home>
    </scratch/ouawcicd/deployments/OUAW_ETL>
  8. On the Languages Selection page, select English and click Next.
    Language Selection screen. The left-hand section shows the languages available, and the right-hand section shows the languages selected by the user. Use the arrows in the middle of these two sections to move an available language to the Selected section.
    Language Selection: The language for the installation process. English
  9. On the Database and Java Home Details page, enter the details as in the table below, and click Next.
    Database and Java Home Details screen, where the user is to browse for the appropriate Database Client and Java Home directories.
    Database Client Home: Enter the Oracle Database Client installed location or Database Home location in the case where the same server is being used for both the application and database server.
    Example: <Database Client> or <ORACLE_HOME>
    </scratch/ouawcicd/dbclient> or </scratch/ouawcicd/Database_base/Ora_home>
    Java Home: Enter the Java installed location.
    Example: <JAVA HOME>
    </scratch/ouawcicd/java/java>
  10. On the Target Database Connection Details page, enter the following and click Next.
    Target Database Connection Details screen shows seven text fields to be populated by the user.
    Host: The target database server where database resides.
    Target Database server host name.
    Example: target.dbserver.hostname
    Port: The target database server port number.
    Target Database port.
    Example: <1521>
    Service Name: The target database service name. <Database service name>
    Target Schema Password: Password for the target schema (DWADM). <DWADM user password>
    Confirm Target Schema Password: Confirm password for the target schema (DWADM). <DWADM user password>
    Target Schema Password: Password for the metadata schema (MDADM). <MDADM user password>
    Confirm Target Schema Password: Confirm password for the metadata (MDADM) schema. <MDADM user password>
    Adb Wallet Directory: Directory of ADB wallet location. Keep it blank
    Adb Service Name: ADB Service Name Keep it blank
  11. On the ODI Home and Schema Details page, enter the following and click Next.
    ODI Home: The directory where Oracle Data Integrator (ODI) is installed.
    Location of FMW Home
    Example: </scratch/ouawcicd/weblogic>
    Supervisor User: Name of the Oracle Data Integrator Supervisor. SUPERVISOR
    Supervisor Password: Enter the Supervisor Password and store it for future reference. <Supervisor user password >
    Confirm Supervisor Password: Enter same as Supervisor Password. <Supervisor user password >
    Master Repository Schema Name: Oracle Data Integrator master repository schema name. OUA_MASTER
    Master Repository Schema Password: Master Repository schema password. <OUA_MASTER user password>
    Confirm Master Repository Schema Password: Confirm password of the Oracle Data Integrator master repository schema. <OUA_MASTER user password>
    Work Repository Schema Name: Oracle Data Integrator work repository schema name. OUA_WORK
    Work Repository Schema Password: Work Repository schema password. <OUA_WORK user password>
    Confirm Work Repository Schema Password: Confirm password of Oracle Data Integrator work repository schema. <OUA_WORK user password>
  12. On the Oracle Data Integrator Agent and Repository Details page, enter the details as in the table below and click Next.
    ODI Agent and Repository Details screen displays two text fields to be populated by the user with the appropriate host and port.
    ODI Agent Host: The application server hostname where the ODI application server is installed.
    Target APP Server Host
    Example:
    <ODI.APP.SERVER.HOST>
    ODI Agent Port: Enter the port which is the Oracle Data Integrator WebLogic Managed Server port. Make sure that you use the same port while creating Oracle Data Integrator managed server. Example: <11002>
  13. On the Target GoldenGate Microservices Details page, enter the details as in the table below, and click Next.
    Target GoldenGate Microservices Details page displays seven text fields to be populated by the user.
    GoldenGate Host: Target Oracle GoldenGate Microservice Host.
    Enter the Target database hostname where GoldenGate Microservices is installed.
    Target database server host/Target GoldenGate Microservice Server Host
    Example: <target.ggms.server.host> = <dbserver.hostname>
    GoldenGate User: Enter the GoldenGate Microservices Admin user. Example: <ggadmin>
    GoldenGate Password: Enter the GoldenGate Microservices Admin user password. Example: <ggadmin user password>
    Confirm GoldenGate Password: Re-enter the GoldenGate Microservices Admin user password. Example: <ggadmin user password>
    GoldenGate Admin Service Port: The Target Oracle GoldenGate Microservices Admin Service port which is running on the target database server host. Example: <7861>
    Target Security Wallet Password: Enter the Wallet Password on the target database server host. <Target Security Wallet Password>
    Confirm Target Security Wallet Password: Re-enter the Wallet Password on the target database server host. <Target Security Wallet Password>
    Target Security Wallet Directory: Enter the Wallet directory path on the target database server host. See Create a Security Wallet on the Target Database Server section.
    Example: <scratch/ouawcicd/ouaw_target_wallet/wallet>
    GoldenGate Receiver Service Port: The Target Oracle GoldenGate Microservices Receiver Service port which is running on the target database server host. Example: <7863>
  14. On the Java Home Location page, enter the details as in the table below, and click Next.
    Java Home Location screen displays a dropdown menu where the user is to browse for the appropriate path.
    Java Home: Enter the Java installed location (on the Application server). Example: </scratch/ouawcicd/java/java>
  15. On the Installation Summary page, a summary is displayed. Click the Install button to proceed.
    Installation Summary page, where the user can find details on the installation.
  16. On the Installation Progress page, click Next when the progress reaches 100%.
    Installation Progress page shows the completion percentage of the installation.
  17. On the Installation Complete page, note the displayed details and click Finish to close the installer wizard. The ETL is now installed.
    Installation Completion page shows the details of the installed ETL.
    If the installation fails with "Error (ODI-10245: Cannot import SNP_SCENSTEP null … because its referenced object is not found in the target repository)" perform the steps below and run the installer again.
    Error Example
    ERROR (oua.base.BIScenario) Scenario Importing SFOL MDM execution failed after 3 attempt(s) Session Failed :54827 : ODI-1217: Session Importing SFOL MDM (54827) fails with return code 7000._ODI-1226: Step Import XML fails after 1 attempt(s)._ODI-1241: Oracle Data Integrator tool execution fails._Caused By: com.sunopsis.tools.core.exception.SnpsSimpleMessageException: ODI-10245: Cannot import SNP_SCENSTEP null (with global id: 976cdddc-dc61-44a7-88c0-65f63ea2d892 and internal id: 250 | 0) belonging to SNP_SCEN B1_PKG_B1_VEE_EXCP_TOPX_MON_MV1 Version 001 (with global id: e94e9d0b-792a-31e7-87aa-f164342ca5c6 and internal id: 250) because its referenced object is not found in the target repository.
    1. In ODI Studio, navigate to Designer Tab > Load Plans and Scenarios > Oracle Utilities BI > MDM (Select the product folder as per your error, here it is MDM.).
    2. Right-click on MDM then click Delete.
      Delete MDM Framework from ODI
    3. Run the ETL installer again.
  18. Start ODI Admin and Managed servers.
    nohup ./startWebLogic.sh > startWebLogic.log 2>&1 &
    nohup ./startManagedWebLogic.sh <ODI_server1> > StartManagedWeblogic.log 2>&1 &
Upgrade the Administration Tool Component
Prerequisites
To remove the previously created Apex workspace from the database:
  1. Connect to the target database as SYSTEM user.
    export ORACLE_HOME=<ORACLE_HOME>
    export ORACLE_SID=<DATABASE SERVICE NAME>
    export PATH=$ORACLE_HOME/bin:$PATH
    sqlplus system/<system user password>@<DATABASE SERVICE NAME>
  2. Run the following PL/SQL procedure to remove the workspace.
    BEGIN
    APEX_INSTANCE_ADMIN.REMOVE_WORKSPACE('OBIU_ADM');
    END;
  3. Make sure no workspace with “OBIU” exists in the database.
    select WORKSPACE from APEX_WORKSPACES where WORKSPACE like '%OBIU%';
    No rows should be returned from this query.
  4. Uninstall the existing ords.war from the database by navigating to ords unzip location on the application server and executing the commands below.
    cd </u01>/<ords>
    export JAVA_HOME=<JAVA 8 HOME>
    java -jar ords.war uninstall
    Provide the necessary inputs for this command and use JDK1.8 to run it.
  5. Download Apex 24.2 from Oracle APEX and place it under a temporary directory in both the OUAW database and application servers.
    Example: </u01/temp>
  6. Download ORDS 25.1.1 from Oracle REST Data Services and place it under a temporary directory in the application server.
  7. Download the Admin tool (Oracle Utilities Analytics Warehouse v25.10.0.0.0 Multiplatform.zip) file from the edelivery and place it under a temporary directory in the OUAW database server.
Admin Tool Installation Steps
  1. Log in to the target database server and navigate to the Apex extracted directory.
    Example: cd </u01/ouaw/apex>
  2. Connect to the Oracle Utilities Analytics Warehouse Database with sys user and execute the following commands in order:
    sqlplus sys/<sys user password>@<database service name> as sysdba
    @apxrtins.sql <Tablespace name> <Tablespace name> <Temp Tablespace name> /i/
    Example:
    @apxrtins.sql <CISTS_01> <CISTS_01> <TEMP> /i/
  3. Set Apex Admin account and password. Execute the following:
    @apxchpwd.sql
  4. Run the following to install Apex for the first time:
    EXEC DBMS_XDB.SETHTTPPORT(0);
    SELECT DBMS_XDB.GETHTTPPORT FROM DUAL;
    This query should result in zero (0).
  5. Run the following SQL:
    ALTER USER APEX_PUBLIC_USER ACCOUNT UNLOCK;
    ALTER USER APEX_PUBLIC_USER IDENTIFIED BY APEX_PUBLIC_USER;
    @apex_rest_config.sql
    Make sure to note the password for these two users: APEX_LISTENER user and APEX_REST_PUBLIC_USER.
Configure APEX Workspace for OUAW
To import the Admin tool to configure Oracle Data Integrator:
  1. Download and unzip the Oracle Utilities Analytics Warehouse v25.10.0.0.0 Multiplatform.zip file, which includes the AdminTool folder.
  2. Copy the Multiplatform zip file into a temp directory within the target database server.
  3. Navigate to the TEMP directory and connect to the database using the system user.
    cd </u01/temp/AdminTool>
    1. Create a workspace and configure the users.
      @CreateAppWorkspace.sql
    2. Import the application.
      @DeployAdminApp.sql
Install ORDS on the Application Server
  1. Create the configuration and installation log directories on the application server to configure ORDS.
    Example
    mkdir -p </u01/ouaw/ords_configuration>
    mkdir -p </u01/ouaw/ords_install_log>
  2. Navigate to the ORDS extracted directory on the application server and make sure that the APEX extracted directory is available in the location.
    Example: </u01/ouaw/ords>
  3. To install ords, execute the following commands:
    export JAVA_HOME=</u01/ouaw/java17>
    /u01/ouaw/ords/bin/ords --config
    /u01/ouaw/ords_configuration  install -interactive --log-folder
    See below an example of the command prompt, in which default options will appear enclosed in square brackets []. Use these options, or provide the necessary inputs for your requirements.
    ORDS: Release 25.1 Production on Fri Jun 06 14:16:28 2025 Copyright (c) 2010, 2025, Oracle.
    Configuration:
    The configuration folder /u01/ouaw/ords_configuration  does not contain any configuration files. Oracle REST Data Services - Interactive Install
    Enter a number to select the TNS net service name to use from /scratch/ ouawcicd/Database_base/Ora_home/network/admin/tnsnames.ora or specify the database connection [1] OUACICDB     SERVICE_NAME=OUACICDB
    [2] OUAW906DB    SERVICE_NAME=OUAW906DB
    [S] Specify the database connection
    Choose [1]: <select as per your target pdb service name>
    Provide database username with administrator privileges.
    Enter the administrator username: sys Enter the database password for SYS AS SYSDBA:
    Retrieving information.
    ORDS is not installed in the database. ORDS installation is required.
    Enter a number to update the value or select option A to Accept and
    Continue
    [1]	Connection Type: TNS
    [2]	TNS Connection: TNS_NAME=OUAW906DB TNS_FOLDER=/scratch/ouawcicd/
    Administrator User: SYS AS SYSDBA
    [3]	Database password for ORDS runtime user (ORDS_PUBLIC_USER): <generate> [4] ORDS runtime user and schema tablespaces:  Default: SYSAUX Temporary
    TEMP
    [5]	Additional Feature: Database Actions
    [6]	Configure and start ORDS in Standalone Mode: Yes
    [7]	Protocol: HTTP
    [8]	HTTP Port: 8080
    [9]	APEX static resources location: [A] Accept and Continue - Create configuration and Install ORDS in the database [Q] Quit - Do not proceed. No changes
    Choose [A]: 3
    Enter your choice for the runtime user password (ORDS_PUBLIC_USER)
    [S] Specify your own password
    [G] Generate password
    [C] Cancel - No Changes
    Choose [G]: S Enter the database password for ORDS_PUBLIC_USER:
    Confirm password:
    Continue
    Administrator User: SYS AS SYSDBA [3] Database password for ORDS runtime user (ORDS_PUBLIC_USER): <specified password> [4] ORDS runtime user and schema tablespaces:  Default: SYSAUX Temporary
    TEMP
    [7]	Protocol: HTTP
    [8]	HTTP Port: 8080 [9] APEX static resources location: [A] Accept and Continue - Create configuration and Install ORDS in the database [Q] Quit - Do not proceed. No changes
    Choose [A]: 6
    Continue
    TEMP
    [6]	Configure and start ORDS in Standalone Mode: No[A] Accept and Continue - Create configuration and Install ORDS in the database [Q] Quit - Do not proceed. No changes Choose [A]: The setting named: db.connectionType was set to: tns in configuration:
    default The setting named: db.tnsAliasName was set to: OUAW906DB in configuration: default The setting named: db.tnsDirectory was set to: /scratch/ouawcicd/
    Database_base/Ora_home/network/admin in configuration: default The setting named: plsql.gateway.mode was set to: proxied in configuration: default
    The setting named: db.username was set to: ORDS_PUBLIC_USER in configuration: default The setting named: db.password was set to: ****** in configuration: default
    The setting named: feature.sdw was set to: true in configuration: default
    The global setting named: database.api.enabled was set to: true The setting named: restEnabledSql.active was set to: true in configuration: default The setting named: security.requestValidationFunction was set to:
    ords_util.authorize_plsql_gateway in configuration: default 2025-06-06T14:19:34.025Z INFO        Installing Oracle REST Data Services version 25.1.1.r1411642 in OUAW906DB 2025-06-06T14:19:35.449Z INFO        ... Verified database prerequisites 2025-06-06T14:19:35.777Z INFO        ... Created Oracle REST Data Services proxy user 2025-06-06T14:19:36.214Z INFO        ... Created Oracle REST Data Services schema 2025-06-06T14:19:36.741Z INFO        ... Granted privileges to Oracle REST
    Data Services 2025-06-06T14:19:39.255Z INFO        ... Created Oracle REST Data Services database objects 2025-06-06T14:19:50.792Z INFO        Completed installation for Oracle
    REST Data Services version 25.1.1.r1411642. Elapsed time: 00:00:16.744
    2025-06-06T14:19:50.860Z INFO        Completed configuring PL/SQL gateway user for Oracle REST Data Services version 25.1.1.r1411642. Elapsed time: 00:00:00.67
    2025-06-06T14:19:50.862Z INFO        Log file written to /u01/ouaw/ ords_install_log/ords_install_2025-06-06_141933_94132.log
  4. Navigate to the ORDS directory. You will find ords.war.
    Example: cd </u01/ouaw/ords>
  5. To create i.war, complete these steps.
    1. Create a directory which is the source for your web archive. In that directory, create a WEB-INF directory with the following web.xml and weblogic.xml.
      mkdir -p /u01/ouaw/temp/WEB-INF
    2. Create web.xml and weblogic.xml inside WEB-INF folder.
      cd /u01/ouaw/temp/WEB-INF
      web.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE web-app PUBLIC
      "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
      "http://java.sun.com/j2ee/dtds/web-app_2_3.dtd">
      <web-app>
      <!-- This Web-App leverages the alternate doc-root functionality in WebLogic to serve static content
      For WebLogic refer to the weblogic.xml file in this folder
      </web-app>
      weblogic.xml
      <weblogic-web-app xmlns="http://www.bea.com/ns/weblogic/weblogic-web-app">
      <!-- This element specifies the context path the static resources are served from -->
      <context-root>/i</context-root>
      <virtual-directory-mapping>
          <!-- This element specifies the location on disk where the static resources are located -->
          <local-path></scratch/apex/apex_21.2_en/images></local-path>
          <url-pattern>/*</url-pattern>
      </virtual-directory-mapping>
      </weblogic-web-app>
      <local-path> is the path of apex image folder.
    3. To create i.war with the web.xml and weblogic.xml files, execute the following command:
      jar cMf i.war WEB-INF/web.xml WEB-INF/weblogic.xml
    For more information, refer to Deploying Oracle REST Data Services.
Install the ords.war and i.war files
To access the WebLogic 14c admin console, you need to install the WebLogic Remote Console in your system. Refer to WebLogic Remote Console for more information.
  1. Log in to the <apex domain> WebLogic administration console.
    This is the WebLogic administration console.
  2. Navigate to Edit Tree > Deployments > App Deployments > New.
    This allows you to maintain the configuration of the WebLogic domain you are currently working with.
    This allows you to create a Java EE application or standalone application module that will be installed in the domain you are currently working with.
  3. Enter the appropriate values for Name (Example: i), Targets (Example: Apex Managed Server apex_server1), and Source Path (Example: full path of the i.war file location).
    This populates the general information of the application deployment.
  4. Click Create and Save then the Commit Changes (img/ouaw-weblogic-remote-console-commit.png) button.
    This creates and saves your new application deployment.
  5. Repeat steps 2 to 4 to deploy the ords.war file.
  6. Navigate to Monitoring Tree > Deployments > Application Management.
    This enables you to view runtime MBean information for select resources in the WebLogic domain you are currently working with.
  7. Select the i and ords checkboxes then click Start > Servicing All Requests.
    This allows you to select and monitor the app deployment in the WebLogic domain you are currently working with.
  8. Stop the Apex administration and managed servers.
  9. Add this parameter to the end of setDomainEnv.sh, which is in the Apex Domain/bin folder.
    JAVA_OPTIONS="${JAVA_OPTIONS} -Dconfig.url=/u01/ouaw/ords_configuration"
    Dconfig.url is the path of ords configuration folder.
  10. Restart the Apex administration and managed servers.
Access the AdminTool
Use this URL to access the administration tool: http://<hostname>:<apex_server1_port>/ords/f?p=104
  1. Provide the following credentials to access the Admintool:
    Username: Admin
    Password: Admin_123
    Oracle Utilities Analytics Administration login page where the user is to enter username and password.
    After logging in to the application for the first time, you will be requested to change the password.
  2. After logging in, you can access the ETL Configuration and ETL Job Execution through the respective tabs.
    Administration tool home page showing the ETL Configuration, the NMS Configuration, and the ETL Job Execution menus.
Change the Default Password of Admin User
This section describes the APEX API used to change the admin user's password.
The script below should be run after connecting to the database as user SYSTEM.
Replace the string 'New password' with the new password for the admin account before running the script.
begin
wwv_flow_api.set_security_group_id(p_security_group_id=>nvl(wwv_flow_application_install.get_workspace_id,2090606133849294));
end;
begin
apex_util.edit_user(
p_user_id => '1467765078687596',
p_user_name => 'ADMIN',
p_web_password => 'New password',
p_new_password => 'New password'
end;
commit;
It is strongly recommended to change the default password after logging in.
Upgrade the Dashboards Component
Prerequisites
Before you begin installing the OUAW Dashboards component, note the following:
  • A single OS user must install all required software.
  • All required software (such as Java, Oracle Database Client, Oracle Fusion Middleware, Oracle Analytics Server) must be installed.
  • Verify that the OUAW Dashboards Components are unzipped and available in the <TEMPDIR>/application directory on the application server.
Set Up the Dashboard Environment
  1. Log in to the application server.
  2. Create a Dashboard Home directory.
    Example:
    mkdir -p </u01/ouaw/deployment/OUAW_DASHBOARD>
    In the documentation, this directory location is referred to as Dashboards Home. Keep note of it because it will be used during some deployment steps.
  3. Copy catalog, WriteBackTemplates, and rpd folders from <TEMPDIR/application> to Dashboard Home folder.
    cp -rp <TEMPDIR>/application/<OAS Version>/*  </u01/ouaw/deployment/OUAW_DASHBOARD>
Deploy the Web Catalog
On the Oracle Analytics Server, you can deploy the latest catalogs into the environment using the online mode.
To take a backup of the deployed catalog, follow the OAS Doc ID 2724149.1 in My Oracle Support.
  1. Navigate to <DOMAIN DOMAIN>/<OAS_DOMAIN>/bitools/bin.
  2. Create a new credentials file called boot.txt and add the following contents to it:
    login=<OAS Weblogc admin user>
    pwd=<OAS Weblogic admin password>
    For each catalog present under <Dashboards Home>/catalog directory, run the following command from the <OAS DOMAIN HOME>/bitools/bin location. Replace all parameters enclosed in <> with the appropriate values.
    ./runcat.sh -cmd unarchive -folder "/shared" -online http://<OAS SERVER Host>:<OAS Managed SERVER PORT>/analytics-ws/saw.dll -credentials boot.txt -inputFile "<Dashboards Home>/Catalog/<Catalog Name>" -overwrite all
    The inputFile parameter must be in double quotes, and the catalog file name must include spaces.
  3. Deploy the 'Spatial Metadata Catalog' on the System folder. Replace all parameters enclosed in <> with the appropriate values.
Deploy the Merged RPD File
To merge the customized 2.8.0.1.2 RPD file with the 25.10.0.0.0 RPD, which contains the database changes required:
  1. Copy both 25.10.0.0.0 and 2.8.0.1.2 RPD files to the Windows machine where Oracle Analytics Client Tool 2025 is installed, then merge it.
    RPD file merge steps can be found here: Merging Repositories
  2. Once the RPD file merge is complete, copy the modified RPD back to the <install dir>/rpd/UtilitiesBusinessAnalytics.rpd, where <install_dir> is the Oracle Utilities Analytics Warehouse Dashboard Component installation directory.
Upload the RPD File
  1. Log in to the target application server where OAS is installed.
  2. Navigate to <DOMAIN HOME>/<OAS DOMAIN>/bitools/bin.
  3. Run the following command to deploy the RPD:
    ./datamodel.sh uploadrpd -I <Dashboards Home>/rpd/UtilitiesBusinessAnalytics.rpd -W <rpd password, defaultpassword is oracle123> -U <Weblogic user name of OAS domain> -P <Weblogic password of OAS domain> -SI ssi
  4. Run the following commands from the <OAS_DOMAIN>/bitools/bin directory to stop and start the OAS domain services respectively.
    ./stop.sh
    ./start.sh
Deploy Writeback Templates
  1. Log in to the application server and run the following commands to deploy writeback templates:
    cp -rp <Dashboards Home>/WriteBackTemplates/*  <FMW 12c Home>/bi/bifoundation/web/msgdb/l_en/custommessages/
  2. Restart the Oracle Analytics Server services after deploying these writeback templates in the specified path.
    cd <OAS DOMAIN>/bitools/bin
    ./stop.sh
    ./start.sh
Configure Spatial Data
  2. Navigate to the temporary directory where the Oracle Utilities Analytics Warehouse v25.10.0.0 Oracle Database Multiplatform.zip file was extracted.
    cd database/BI251000/Spatial-Metadata
  3. Set the following environment variables.
    export ORACLE_HOME=<ORACLE HOME>
  4. Create the database directory in the database after connecting to sys user.
    sqlplus sys/<sys user password>@<DATABASE SERVICE NAME>
    CREATE DIRECTORY <dump_dir> AS '/u01/dumps';
  5. Copy the user_sdo.dmp dumpfile from the temporary directory <TEMPDIR>/database/BI251000/Spatial-Metadata to the database directory <dump_dir> location.
    Example: </u01/dumps>
  6. Execute the impdp command to import the USER_SDO* tables data.
    impdp directory=dump_dir dumpfile=user_sdo.dmp logfile=impdp_user_sdo.log schemas=DWADM remap_tablespace=cists_01:<tablespace_name>
  7. Provide DWADM username password when prompted.
    Ensure to change the tablespace_name to the name on which DWADM has the quota. If DWADM user have quota on cists_01 tablespace, then exclude the whole remap_tablespace clause from the command.
  8. Review the impdp_user_sdo.log file to ensure the tables are imported successfully.
  9. After importing the tables, run the following SQL scripts from the <TEMPDIR>/BI251000/Spatial-Metadata directory.
    sqlplus dwadm/<dwadm user password>@<database service name>
    @copy_spatial_metadata.sql
    @clean_sdo_release_tbls.sql
  10. Review the log files.
Upgrade Network Management System BI Publisher Reports
This section is applicable only if the source is configured with Oracle Utilities Network Management System.
To upgrade/install Oracle Utilities Network Management System BI Publisher Reports, refer to Install Network Management System BI Publisher Reports.
Post-Upgrade Steps
Run Post-Upgrade Steps
Steps 2, 3, 7, 11, 12, 13, 14 and 15 are only valid for the Oracle Utilities Network Management System (NMS) Source. Ignore these steps for Oracle Utilities Customer Care and Billing, Meter Data Management, Customer To Meter, and Work and Asset Management.
  1. Modify the value of the Maximum Table Name Length parameter to "128".
    1. In ODI studio, navigate to Topology > Physical Architecture > Technologies.
    2. Right-click Oracle and select Open
    3. Navigate to the Advanced tab and modify the value of the Maximum Table Name Length parameter to "128".
    4. Click Save.
  2. Perform the steps below in accordance with the upgraded NMS version in ODI Studio.
    The following steps are only valid for the NMS source application.
    For NMS Versions 2.6.0.0 and Later:
    1. Navigate to Load Plans and Scenarios > Framework > Data correction > Repository Fixes.
    2. Right-click the B1_UPD_NMS_SCEN_FROM_260 scenario.
    3. Click Run.
    4. Set Context as "Global".
    5. Click OK.
    For NMS Versions after 2.5.0.2 and below 2.6.0.0:
    2. Right-click the B1_UPD_NMS_SCEN_FROM_2502_UNDER_260 scenario.
    3. Click Run.
    5. Click OK.
    For NMS Versions after 2.4.0.1 and below 2.5.0.2:
    2. Right-click the B1_UPD_NMS_SCEN_FROM_2401_UNDER_2502 scenario.
    3. Click Run.
    5. Click OK.
    For NMS Versions below 2.4.0.1:
    2. Right-click the B1_UPD_NMS_SCEN_UNDER_2401 scenario.
    3. Click Run.
    5. Click OK.
  3. Rename the Account Dimension View scenario by performing the following steps:
    1. Navigate to Load Plans and Scenarios > Oracle Utilities BI > Shared > Dimensions > Account Dimension > Account Dimension Upto NMS 24013.
    2. On the Definition tab, double-click B1_NMS_D_ACCT_VW_UPTO_24013 Version 001 and rename it to B1_NMS_D_ACCT_VW Version 001.
    3. Click Save.
  4. Run the source configuration in REGISTER mode.
    • Context Code should be same with old Context Code which was cleaned during GoldenGate Classic cleanup process.
    • Perform the source configuration as per the steps mentioned in Configure ETL Source for OUAW (except all steps from section Set Up Source Database Server for Oracle GoldenGate Microservices and step 1 from section Source Configuration Using OUAW Wizard).
  5. Make sure that all EXTRACT, REPLICAT, Distribution Paths are up and running. Lag at the Chkpt and Time Since Chkpt should be zero (0). This can be confirmed through the info after logging in to Source and Target OGG MS Administration server console and the Source Distribution Server console.
  6. Stop the GoldenGate Microservice REPLICAT processes in the target server.
  7. Run the commands below to purge any data that is synchronized in the new NMS tables that are replicated after upgrade.
    DELETE FROM <NMS_REPLICATION_SCHEMA>.MERGED_EVENTS;
    DELETE FROM <NMS_REPLICATION_SCHEMA>.NMS_ACCOUNTS_HISTORY;
    COMMIT;
  8. Run B1_SYNC_CONTEXT Version 001 in ODI studio for the configured product context.
  9. Start the GoldenGate Microservice REPLICAT processes in the target server.
  10. Bring up the source application.
  11. Execute the below scenario for Backfilling of Storm changes in NMS Star Schema, based on the current configured source NMS version.
    For NMS Version 2.6.0 and Later:
    1. Navigate to ODI Designer > Load Plans and Scenarios > Framework > Data correction > Data Fixes.
    2. Right-click B1_STORM_DATA_FIX_2802 Version 001 and click Run.
      Select the appropriate context. If multiple contexts are configured, execute for each context separately.
  12. Perform the following steps to correct the historical data in CD_DAMAGE_ASMT and CF_DAMAGE_ASMT entities from DAMAGE_ASSETS source table.
    For NMS Versions 2.4.0.1 and Later:
    2. Right-click B1_UPD_DAMAGE_ASMT_29001.
    3. Click Run.
  13. Execute the following steps to update the Control zone secondary keys which are already loaded with -99 in the facts when the Control Zone secondary key exclusion is enabled.
    2. Right-click B1_UPD_CZS_KEY.
    3. Click Run.
      • The B1_UPD_CZS_KEY can be executed using any context.
  14. Disable all NMS facts and dimensions (including B1_BR_SW_PLAN_JOBS).
    This can be ensured by checking that there is no record for any entity in B1_READY_VW view in MDADM schema:
    select distinct entity_name from MDADM.b1_ready_vw;
  15. For Account Dimension (NMS) related changes, perform an incremental or complete load of the data from NMS_ACCOUNTS_HISTORY table into Account Dimension.
    Option 1: Incremental Data Load
    CD_ACCT dimension will load only the incremental data from NMS_ACCOUNTS_HISTORY table. The data which is already loaded in the dimension from CES_CUSTOMERS_HISTORY table will not be modified or updated and remains the same. The dependent facts will not be impacted while performing initial load.
    1. Ensure the NMS_ACCOUNTS_HISTORY is present in replication layer with data.
    2. Stop the GoldenGate REPLICAT.
    3. Navigate to Load Plans and Scenarios > Oracle Utilities BI > Shared > Dimensions > Account Dimension to load all the initial and incremental data from CES_CUSTOMERS_HISTORY table into the dimension.
    4. On the Definition tab, double-click B1_PKG_NMS_CD_ACCT_UPTO_24013 Version 001 and rename it to B1_PKG_NMS_CD_ACCT Version 001.
    5. On the Definition tab, double-click B1_NMS_D_ACCT_VW_UPTO_24013 Version 001 and rename (if not already done) it to B1_NMS_D_ACCT_VW Version 001.
    6. Click Save.
    7. Run the View generation script for the configured NMS Context.
    8. Enable the entity active flag for CD_ACCT dimension and B1_RUN_ALL to load the Account dimension. This loads data from CES_CUSTOMERS_HISTORY until latest checkpoint.
    9. Ensure that the CD_ACCT dimension data loads are completed until the checkpoint date. The output of below queries should result in same date:
      SELECT MAX (SLICE_END_DTTM) FROM MDADM.B1_JOBS_VW WHERE CONTEXT_CD= <NMS_context_code> AND ENTITY_NAME='CD_ACCT';
      SELECT LAST_UPDATE_TS FROM MDADM.B1_CHECKPOINT WHERE GROUP_NAME LIKE 'NMS%';
    10. Revert the changes for scenario names for CD_ACCT dimension upon completion of the job loads by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
    11. On the Definition tab, double-click B1_PKG_NMS_CD_ACCT Version 001 and rename it to B1_PKG_NMS_CD_ACCT_UPTO_24013 Version 001.
    12. On the Definition tab, double-click B1_NMS_D_ACCT_VW Version 001 and rename it to B1_NMS_D_ACCT_VW_UPTO_24013 Version 001.
    13. Click Save.
    14. Stop B1_RUN_ALL from ODI Studio.
    15. Start the GoldenGate REPLICAT.
    16. Load the incremental data into CD_ACCT dimension from NMS_ACCOUNTS_HISTORY table by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
    17. On the Definition tab, double-click B1_PKG_NMS_CD_ACCT_FROM_24013 Version 001 and rename it to B1_PKG_NMS_CD_ACCT Version 001.
    18. On the Definition tab, double-click B1_NMS_D_ACCT_VW_FROM_24013 Version 001 and rename it to B1_NMS_D_ACCT_VW Version 001.
    19. Click Save.
    20. Run the View generation for the Configured Context.
    21. Enable B1_RUN_ALL and load the Account dimension. At this point, the data is loaded from NMS_ACCOUNTS_HISTORY.
    22. Enable all other dimensions and facts, and perform incremental loads.
    Option 2: Complete Data Load
    CD_ACCT dimension will load the complete data from NMS_ACCOUNTS_HISTORY table. The data which is already loaded in the dimension from CES_CUSTOMERS_HISTORY table will be updated. All the dependent facts will also be updated with the latest ACCT_KEY values from CD_ACCT table. Once the loads are done, the older records in the account dimension (All the data loaded form CES_CUSTOMERS_HISTORY table) will be deleted.
    1. Stop B1_RUN_ALL from ODI studio. Run this query to ensure no ETL jobs are in the "Running" state:
      SELECT * FROM   MDADM.B1_JOBS_VW WHERE  STATUS_FLG in ('W','P', 'R');
      If there are entries found, wait for the jobs to finish.
    2. Ensure that the NMS_ACCOUNTS_HISTORY table is present and with data in the replication layer.
    3. Ensure the scenario names for the existing CD_ACCT NMS Dimension are renamed (if not already done) with suffix 'UPTO_24013' in ODI by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
    4. On the Definition tab, double-click B1_PKG_NMS_CD_ACCT Version 001 and rename it to B1_PKG_NMS_CD_ACCT_UPTO_24013 Version 001.
    5. On the Definition tab, double-click B1_NMS_D_ACCT_VW Version 001 and rename it to B1_NMS_D_ACCT_VW_UPTO_24013 Version 001.
    6. Click Save.
    7. Rename the scenario name for the new CD_ACCT NMS Dimension by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
    8. On the Definition tab, double-click B1_PKG_NMS_CD_ACCT_FROM_24013 Version 001 and rename it to B1_PKG_NMS_CD_ACCT Version 001.
    9. On the Definition tab, double-click B1_NMS_D_ACCT_VW_FROM_24013 Version 001 and rename it to B1_NMS_D_ACCT_VW Version 001.
    10. Click Save.
    11. Run the View generation for the Configured NMS Context.
    12. Run the B1_ACCT_DIM_UPD_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > Data Fixes > B1_ACCT_DIM_UPD_28020.
    13. Enable the entity active flag of CD_ACCT dimension.
    14. Enable B1_RUN_ALL and load the Account dimension, where data is loaded from NMS_ACCOUNTS_HISTORY.
    15. Run the B1_F_ACCT_KEY_UPD_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > Data Fixes > B1_F_ACCT_KEY_UPD_28020.
    16. Run the B1_ACCT_DIM_DEL_KEYS_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > Data Fixes B1_ACCT_DIM_DEL_KEYS_28020.
    17. Enable all other dimensions and facts and then perform the incremental loads.
