Oracle Utilities Analytics Warehouse Developer’s Guide
Welcome to the Oracle Utilities Analytics Warehouse Developer’s Guide. This guide focuses on how you can get started with configuring and administering Oracle Utilities Analytics Warehouse V25.10.0.0.0. It provides instructions to extend the product, replication, and star schemas, so you can carry out an out-of-the-box implementation.
The guide is organized based on the typical flow you need to follow during the Oracle Utilities Analytics Warehouse implementation. Use the following documentation roadmap to find the information that you need to implement Oracle Utilities Analytics Warehouse.
Quick Links
• Getting Started: Find out what you need to begin customizing the product.
• User Extension Methods: Gain a high-level understanding of the characteristics and extensible attributes needed to customize and extend the product.
• Extending Replication: Understand the replication capabilities of the product. This chapter discusses the replication of tables required for processing and loading data into the data warehouse.
• Extending Star Schema: Find out how a schema can be extended using user-defined constructs, such as User Defined Fields (UDFs), User Defined Measures (UDMs), User Defined Degenerate Dimensions (UDDGENs), User Defined Foreign Keys (UDDFKs), and User Defined Dimensions (UDDs).
• Extending Analytics: Explains how to use Oracle Analytics Server to extend the analytics in Oracle Utilities Analytics Warehouse.
• Migrating Environments: Discusses about the environments needed to carry out the implementation.
For more information, see the Oracle Utilities Analytics Warehouse documentation available on Oracle Help Center at: https://docs.oracle.com/en/industries/energy-water/analytics/index.html
Have a question? Contact your Delivery Team or visit My Oracle Support.
