Related Documents
Refer to the Oracle Utilities Analytics Warehouse Installation and Configuration Checklist for high-level steps to install and configure the Oracle Utilities Analytics Warehouse product. Note that this checklist includes information for V25.10.0.0.0.
The following documentation is included in this release.
Installation, Administration, and Release Notes
• Oracle Utilities Analytics Warehouse Release Notes
• Oracle Utilities Analytics Warehouse Getting Started Guide
• Oracle Utilities Analytics Warehouse Licensing Information User Manual
• Oracle Utilities Analytics Warehouse Installation and Configuration Guide
• Oracle Utilities Analytics Warehouse Quick Install Guide
• Oracle Utilities Analytics Warehouse Developer’s Guide
Metric Reference Guides
Refer to the Oracle Utilities Analytics Warehouse documentation on Oracle Help Center for details about the metric reference guides included in this release.
Data Mapping Guides
Refer to the Oracle Utilities Analytics Warehouse documentation on Oracle Help Center for details about the data mapping guides included in this release.
Conventions
The following text conventions are used in this document:
Convention
Meaning
boldface
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary.
italic
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values.
monospace
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter.
Abbreviations
The following table lists the commonly used abbreviations used in this document:
Abbreviation
Expanded Form
OUAW
APEX
Oracle Application Express
CCB
Oracle Utilities Customer Care and Billing
CDC
Changed Data Capture
ELT
Extraction, Loading and Transformation
ETL
Extraction, Transformation and Loading
MDM
Oracle Utilities Meter Data Management
MWM
Oracle Utilities Mobile Workforce Management
NMS
Oracle Utilities Network Management System
OAS
Oracle Analytics Server
ODI
Oracle Data Integrator
ODM
Oracle Utilities Operational Device Management
OGG
Oracle GoldenGate
OWB
Oracle Warehouse Builder
WAM
Oracle Utilities Work and Asset Management
OUAF
Oracle Utilities Application Framework
Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website.
Documentation Roadmap
This guide is organized based on the typical flow you need to follow during the Oracle Utilities Analytics Warehouse implementation. Use the following documentation roadmap to find the information that you need to implement Oracle Utilities Analytics Warehouse.
• Getting Started: Find out what you need to begin customizing the product.
• Chapter 2: User Extension Methods: Gain a high-level understanding of the characteristics and extensible attributes needed to customize and extend the product.
• Chapter 3: Extending Replication: Understand the replication capabilities of the product. This chapter discusses the replication of tables required for processing and loading data into the data warehouse.
• Chapter 4: Extending Star Schema: Find out how a schema can be extended using user-defined constructs, such as User Defined Fields (UDFs), User Defined Measures (UDMs), User Defined Degenerate Dimensions (UDDGENs), User Defined Foreign Keys (UDDFKs), and User Defined Dimensions (UDDs).
• Chapter 5: Extending Analytics: Explains how to use Oracle Analytics Server to extend the analytics in Oracle Utilities Analytics Warehouse.
• Chapter 6: Migrating Environments: Discusses about the environments needed to carry out the implementation.
