Recommended Hardware
This section focuses on the hardware requirements that are necessary to install Oracle Utilities Analytics Warehouse.
RAM Requirements
Make sure that your system meets the following recommended RAM requirements.
Minimum RAM
28 GB
Recommended RAM
32 GB or more
Swap the space allocation relative to RAM space. It is better to have half of the RAM size as Swap space.
Note: These are the minimum recommendations, but this can be increased if RAM and Swap space are required to improve or enhance the Oracle Utilities Analytics Warehouse performance.
Disk Space Requirements
Installing Oracle Utilities Analytics Warehouse may require the following disk space:
• 20 GB of free space for the Oracle Utilities Analytics Warehouse software files on the file system.
• Terabytes of free space for Oracle Utilities Analytics Warehouse tablespaces (increase the size as per the number of source connections).
