Demo Data Information
The Oracle Utilities Analytics Warehouse V25.10.0.0.0 demo database contains sample data based on the application versions provided with this release.
Demo data provides sample configuration and data for key application features. It is delivered as part of the base installation. Refer to the Install and Configure Oracle Utilities Analytics Warehouse With Demo Data section in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide included in the Oracle Utilities Analytics Warehouse documentation for more information or contact My Oracle Support.
Oracle recommends that you do not clone the demonstration environment as a basis for a new production environment. The demonstration environment typically includes transactional data that will be irrelevant to your production environment and can cause unexpected issues if it is not purged correctly. The recommended process is to start a new production environment from a new installation and migrate “clean” system data (such as business objects and algorithms) and administrative data from the demonstration and/or test or development environments as applicable.
