Bug Fixes
The following bugs from previous Oracle Utilities Analytics Warehouse releases have been fixed in V25.10.0.0.x:
Bug Number
Description
37464844
Control zone keys in CF_SW_PLAN_SEG is populated as -99
37539603
Performance issues with Switch Plan State fact in Outage Analytics
37424465
Duplicates on Merge Columns in B1_F_DAMAGE_ASMT_DETAIL_NEW_VW
37839205
CF_CUST_RECENT_OUTG fact load is not getting completed (Index on CCH) - Copy of Bug 36451591 for 25.10 release
37755927
Apex 24.2 - Issue when trying to edit 'SCD Type 2 Dimension page' in Admin tool
37839226
CF_DAMAGE_ASMT load fails with ORA-01427 - Copy of Bug 36711505 for 25.10 release
37839466
CF_CTRL_ZONE_OUTG session in ODI is taking too long to complete - Copy of Bug 36027250 for 25.10 release
37825482
Columns are mapped from DAMAGE_REPORT instead of DAMAGE_ASSETS for CF_DAMAGE_ASMT & CD_DAMAGE_ASMT - Copy of Bug 36983723 for 25.10 release
37825449
CF_CUST_RST_OUTG fact is taking a long time to sync - Copy of Bug 36855992 for 25.10 release
37825325
CF_OUTG_HIST fact is taking a long time to complete loads - Copy of Bug 36882901 for 25.10 release
37825279
ETL performance issues in Storm Procedures - Copy of Bug 36912554 for 25.10 release
37854585
CD_STORM Dimension load is failing with an error ORA-00957: duplicate column name
38252121
Error in execution of B1_SYNC_CONTEXT job for WAM source
37978414
Latency with the B1_RUN_ALL schedule
37876122
B1_UPD_NMS_SCEN_FROM_260 procedure is failing when executed multiple times - Copy of Bug 37876114 for 25.10 release
37846760
CD_SW_PLAN dimension is failing in OUA ETL - Copy of Bug 36863228 for 25.10 release
37869480
Impact of Start Date update in CI_SA on child table records -Copy of Bug 36127413 for 25.10 release
37869868
Error in execution of B1_SYNC_CONTEXT job - Copy of Bug 37691731 for 25.10 release
37869489
Long running job CF_COLL_PROC - Copy of Bug 36563969 for 25.10 release
37846719
PREM_KEY is getting populated as 0 IN CF_FT, CF_FT_GL & CF_BILLED_USAGE - Copy of Bug 35616482 for 25.10 release
37869665
'Update RATE_SPLIT_FLAG' step updating incorrect value - Copy of Bug 36109589 for 25.10 release
38117553
Ora-01722 Error in View B1_F_PA_VW & ODI LOADS (B1_PKG_CF_PA_SNAP, B1_PKG_CF_SP_SNAP) - Copy of Bug 36358069 for 25.10 release
38117534
Performance issues with CF_RECENT_CREW and CF_RST_CREW facts - Copy of Bug 37951044 for 25.10 release
38147383
NMS Crew Facts are taking very long time to load
38153792
Performance issues with Customer Outage facts - Copy Bug For 33866860 for 25.10 release
Refer to the product fix design documents provided in the Oracle Utilities Analytics Warehouse v25.10.0.0 PFDs.zip file for detailed information about the respective bugs.
Important! Please note that the “Oracle Utilities Analytics Warehouse v25.10.0.0 PFDs.zip” file is part of the Oracle Utilities Analytics Warehouse Documentation 25.10.0.0.x package.
You can view the product fix design documents in either of the following ways:
• In a browser by using the HTML-based files.
a. Copy the “css”, “html”, “images”, and “bug-pfds-25.10.0.0.0.html” files to a local directory.
b. Select and open the “bug-pfds-25.10.0.0.0.html” file to access the Home page.
You can view the list of bugs and the respective links to the product fix design documents.
• Using the bug-pfds-25.10.0.0.0.csv file. Import the content of the csv file. It contains one row for each bug, and each column contains the same fields that are shown in the HTML-based files.
