Facts
Important! As of the 2.7.0.1 release, materialized views are removed from Oracle Utilities Analytics Warehouse.
Activity
An accumulation of activities associated to work orders in the source system, with a refresh of certain measures on a day-to-day basis.
Entity Relationship Diagram
ER diagram of the Activity fact.
Properties
Property
Value
Target Table Name
CF_WO_ACTIVITY
Table Type
Fact
Fact Type
Accumulation
Source System Driver Table
W1_ACTIVITY
ODI Package Name
B1_PKG_CF_WO_ACTIVITY
ETL View Name
B1_F_WO_ACTIVITY_KVW
Fields
Target Field
Description
Source Field
Transformation Logic
Surrogate Key
WO_ACTIVITY_KEY
Activity Surrogate Key
This field is populated from the B1_F_WO_ACTIVITY_SEQ sequence.
Natural Keys
SRC_ACTIVITY_ID
Source Activity ID
W1_ACTIVITY.ACT_ID
Measures
NBR_DAYS_OVERDUE
Number of Days Overdue
This field is calculated for non-finalized activities with Calendar Anniversary/Interval trigger types.
If the original work date has been crossed, the measure is calculated as the difference between the current date and the original work date.
NBR_CYC_OVERDUE
Number of Cycles Overdue
This field is calculated based on the number of days overdue and the trigger frequency.
Trigger frequency is determined in days based on the information on the maintenance trigger.
PLANNED_DUR
Planned Duration
This field is calculated (in hours) based on the duration on the activity's non-canceled labor resource requirements.
FACT_CNT
Count
This field is populated with the standard value of ‘1’.
Degenerate Dimensions
TRIGGER_TYPE_CD
Trigger Type Flag
W1_MAINT_TRIGGER. TRIGGER_TYPE_FLG
This field is populated with the trigger type of the maintenance trigger of the activity.
TRIGGER_TYPE_DESCR
Trigger Type Flag Description
CI_LOOKUP_VAL_L.DESCR_OVRD
This field is populated with the description of the trigger type from Lookup Language table for TRIGGER_TYPE_FLG lookup field.
If an override description is not available, the regular description is extracted.
SCHEDULED_IND
Scheduled Indicator
If at least one labor resource requirement is scheduled in a shift, this field is populated with ‘1’. Else, it is set to ‘0’.
BREAK_IN_IND
Break-in Indicator
If at least one labor resource booked time on this activity but the work spent is not scheduled in a shift, this field is set to 1. Else, it is set to 0.
Note: This field is refreshed if any changes to timesheets occur.
NO_COST_IND
No Cost Indicator
No Cost Indicator is determined by summing the amount of frozen FTs associated with the activity.
If the sum is ‘0’, this field is set to ‘1’. Else, it is set to ‘0’.
NO_LABOR_IND
No Labor Indicator
The No Labor Indicator is used to indicate if any labor resources are used for this activity. It is determined by looking for any posted timesheet details for the activity that has resource requirements of Craft.
ORIGINAL_WORK_DT
Original Work Date
W1_ACTIVITY. ORIGINAL_WORK_DT
This field is populated based on the original work date of the activity.
REQUIRED_BY_DT
Required By Date
W1_ACTIVITY. REQUIRED_BY_DT
This field is populated based on the required date of the activity.
Foreign Keys
WO_KEY
Work Order Dimension Surrogate Key
W1_ACTIVITY.WO_ID
This is populated with the foreign key of the Work Order dimension based on the work order of the activity.
WO_ACTIVITY_D_KEY
Activity Dimension Surrogate Key
W1_ACTIVITY.ACT_ID
This field is populated with the foreign key of the Work Activity dimension for this activity.
UTIL_ASSET_KEY
Utility Asset Dimension Surrogate Key
W1_ACTIVITY. ASSET_ID
This field is populated with the foreign key of the Utility Asset dimension based on the asset associated with this activity.
LOCATION_KEY
Location Dimension Surrogate Key
W1_ACTIVITY.NODE_ID
This field is populated with the foreign key of the Location dimension based on the node associated with this activity.
ADDR_KEY
Address Dimension Surrogate Key
W1_ACTIVITY.NODE_ID
This field is populated with the foreign key of the Address dimension based on the node associated with this activity.
OWNING_ORG_KEY
Owning Organization Dimension Surrogate Key
W1_ACTIVITY. OWNING_ACCESS_GRP_CD
This field is populated with the foreign key of the Owning Organization dimension based on the owning access group code associated with this activity.
CREW_KEY
Crew Dimension Surrogate Key
W1_TIMESHEET_DETAIL. W1_CREW_ID
W1_CREW_SHIFT.W1_CREW_ID
W1_ACTIVITY.W1_CREW_ID
This field is populated with the foreign key of the Crew dimension based on the crew associated with the activity.
The crew is determined by one of the following:
• Looking up the crew via the time sheet detail associated with the activity.
• Looking into the crew shifts associated with the activity's resource requirements.
• Looking up the recommended crew on the activity.
W_PLANNER_KEY
Planner Dimension Surrogate Key
W1_ACTIVITY. PLANNER_CD
This field is populated with the foreign key of the Planner dimension based on the planner code associated with this activity.
ORIGINAL_WORK_DT_KEY
Original Work Date Key
This field is populated from the Date table based on original work date populated into the Original Work Date field.
REQUIRED_BY_DT_KEY
Required By Date Key
This field is populated from the Date table based on the required by date populated into the Required By Date field.
NUM_CYC_OD_KEY
Number of Cycles Overdue Dimension Surrogate Key
This field is populated from the Number of Cycles Overdue table based on the number of cycles overdue start/end bucket range.
WO_ACTIVITY_STATUS_KEY
Activity BO Status Dimension Surrogate Key
W1_ACTIVITY.BUS_OBJ_CD
W1_ACTIVITY.BO_STATUS_CD
W1_ACTIVITY.BO_STATUS_REASON_CD
This field is populated from the Activity table based on the BO code, status, and reason associated with the current activity ID.
WO_ACTIVITY_UDD1_
KEY
Activity User Defined Dimension 1 Surrogate Key
WO_ACTIVITY_UDD2_
KEY
Activity User Defined Dimension 2 Surrogate Key
User Defined Attributes
UDM1
User Defined Measure 1
UDM2
User Defined Measure 2
UDM3
User Defined Measure 3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDM11
User Defined Measure 11
UDM12
User Defined Measure 12
UDM13
User Defined Measure 13
UDM14
User Defined Measure 14
UDM15
User Defined Measure 15
UDM16
User Defined Measure 16
UDM17
User Defined Measure 17
UDM18
User Defined Measure 18
UDM19
User Defined Measure 19
UDM20
User Defined Measure 20
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGEN6
User Defined Degenerate Dimension 6
UDDGEN7
User Defined Degenerate Dimension 7
UDDGEN8
User Defined Degenerate Dimension 8
UDDGEN9
User Defined Degenerate Dimension 9
UDDGEN10
User Defined Degenerate Dimension 10
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDGENL6
User Defined Long Degenerate Dimension 6
UDDGENL7
User Defined Long Degenerate Dimension 7
UDDGENL8
User Defined Long Degenerate Dimension 8
UDDGENL9
User Defined Long Degenerate Dimension 9
UDDGENL10
User Defined Long Degenerate Dimension 10
UDDFK1_KEY
User Defined Dimension Foreign Key 1
UDDFK2_KEY
User Defined Dimension Foreign Key 2
UDDFK3_KEY
User Defined Dimension Foreign Key 3
UDDFK4_KEY
User Defined Dimension Foreign Key 4
UDDFK5_KEY
User Defined Dimension Foreign Key 5
UDDFK6_KEY
User Defined Dimension Foreign Key 6
UDDFK7_KEY
User Defined Dimension Foreign Key 7
UDDFK8_KEY
User Defined Dimension Foreign Key 8
UDDFK9_KEY
User Defined Dimension Foreign Key 9
UDDFK10_KEY
User Defined Dimension Foreign Key 10
UD_DATE1
User Defined Field Date 1
UD_DATE2
User Defined Field Date 2
UD_DATE3
User Defined Field Date 3
UD_DATE4
User Defined Field Date 4
UD_DATE5
User Defined Field Date 5
UD_DATE1_KEY
User Defined Field Date Key 1
UD_DATE2_KEY
User Defined Field Date Key 2
UD_DATE3_KEY
User Defined Field Date Key 3
UD_DATE4_KEY
User Defined Field Date Key 4
UD_DATE5_KEY
User Defined Field Date Key 5
Data Load Attributes
DATA_SOURCE_IND
Data Source Indicator
CI_INSTALLATION.ENV_ID
This field is populated with the DSI value on the source product instance configuration.
The table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system.
JOB_NBR
Job Number
This field is populated with the ODI job execution session number.
Asset FT
An accumulation of every financial transactions of an asset. It captures the financial information at the FT and asset level.
ER diagram of the Asset FT fact.
Properties
Property
Value
Target Table Name
CF_ASSET_FT
Table Type
Fact
Fact Type
Accumulation
W1_FT
W1_ACTIVITY
W1_ASSET
ODI Package Name
B1_PKG_CF_ASSET_FT
ETL View Name
n/a
Fields
Target Field
Description
Source Field
Surrogate Key
ASSET_FT_KEY
Asset FT Fact Surrogate Key
This field is populated from the B1_ASSET_FT_SEQ sequence.
Natural Keys
SRC_FT_ID
Source FT ID
W1_FT.W1_FT_ID
SRC_ASSET_ID
Source Utility Asset ID
W1_ACTIVITY_ASSET.ASSET_ID
Measures
PM_LABOR_HRS
PM Labor Hours
If the work order associated with this FT is for Preventive Maintenance, this field is populated with the labor hours associated with the FT's timesheet detail prorated by the asset's percentage in the cost distribution.
The field is mutually exclusive with CM Labor Hours.
Labor Hours = Hours in Timesheet Detail * Asset share percentage on FT Activity
CM_LABOR_HRS
CM Labor Hours
If the work order associated with this FT is for Corrective Maintenance, this field is populated with the labor hours associated with this FT's timesheet detail prorated by the asset's percentage in the cost distribution.
This field is mutually exclusive with PM Labor Hours.
PM_COST
PM Cost
If the work order associated with this FT is for Preventive Maintenance, this field is populated with the amount associated with this FT prorated by the asset's percentage in the cost distribution.
This field is mutually exclusive with CM Cost.
Cost = (FT amount * percentage)/100
CM_COST
CM Cost
If the work order associated with this FT is for Corrective Maintenance, this field is populated with the amount associated with this FT prorated by the asset's percentage in the cost distribution.
This field is mutually exclusive with PM Cost.
FACT_CNT
Count
OVERTIME _IND
Overtime Indicator
W1_TIMESHEET_DETAIL.REG_OVERTIME_
FLG
This field is used to indicate if the FT is for overtime work. This is determined by checking the regular/overtime flag on the timesheet detail associated with the FT.
PARTICIPATION_CD
Participation Flag
W1_ACTIVITY_ASSET.
PARTICIPATION_FLG
This field is populated based on the participation flag associated with this FT's activity and asset on the activity cost distribution table.
PARTICIPATION_DESCR
Participation Description
CI_LOOKUP_VAL_L.
DESCR_OVRD
CI_LOOKUP_VAL_L.
DESCR
This field is populated with the description of the participation flag from Lookup Language table for PARTICIPATION_FLG lookup field.
ACCOUNTING_DT
Accounting Date
W1_FT.W1_
ACCOUNTING_DT
Foreign Keys
WO_KEY
W1_ACTIVITY.WO_ID
This field is populated with the foreign key of the Work Order dimension based on the work order of the activity.
WO_ACTIVITY_KEY
Work Order Activity Dimension Surrogate Key
W1_FT.ACT_ID
This field is populated with the foreign key of the Activity table based on the activity associated with the financial transaction.
UTIL_ASSET_KEY
W1_ACTIVITY_ASSET.A SSET_ID
This field is populated with the foreign key of the Asset table based on the activity associated with the financial transaction.
LOCATION_KEY
W1_ACTIVITY.NODE_ID
This field is populated with the foreign key of the Location table based on the node ID associated with the financial transaction.
ADDR_KEY
W1_ACTIVITY.NODE_ID
This field is populated with the foreign key of the Address table based on the node ID associated with the financial transaction.
RESRC_TYPE_KEY
Resource Type Dimension Surrogate Key
W1_TIMESHEET_DETAIL.RESRC_TYPE_ID
W1_STOCK_ITEM_DTL.RESRC_TYPE_ID
W1_ODC_DTL.RESRC_TYPE_ID
This field is populated based on the resource type on the timesheet detail of the FT.
If unavailable, the resource type of the material issue line's stock detail is used. Else, the resource type on the ODC details is used.
OWNING_ORG_KEY
W1_ASSET. OWNING_ACCESS_GRP_CD
This field is populated based on the owning access group of the asset.
FISCAL_CAL_KEY
Fiscal Period Dimension Surrogate Key
W1_FT.W1_ACCOUNTING_DT
W1_CALENDAR_PERIOD. W1_CALENDAR_CD
W1_CALENDAR_PERIOD. W1_FISCAL_YEAR
W1_CALENDAR_PERIOD. ACCTG_PERIOD
This field is populated based on the accounting date on the financial transaction. The fiscal calendar record where the accounting date falls into is used.
W_PLANNER_KEY
W1_ACTIVITY.PLANNER_CD
This field is populated based on the planner code associated with the activity ID from the Activity table.
ACCOUNTING_DT_KEY
Accounting Date Key
This field is populated from the Date table based on the date part of the accounting date/time (which is populated into the Accounting Date field).
ASSET_FT_UDD1_KEY
Asset FT User Defined Dimension 1 Surrogate Key
ASSET_FT_UDD2_KEY
Asset FT User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE1_KEY
User Defined Field Date 1 Key
UD_DATE2_KEY
User Defined Field Date 2 Key
UD_DATE3_KEY
User Defined Field Date 3 Key
UD_DATE4_KEY
User Defined Field Date 4 Key
UD_DATE5_KEY
User Defined Field Date 5 Key
DATA_SOURCE_IND
This field is populated with the DSI value on the source product instance configuration. The table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system.
JOB_NBR
Job Number
Asset Snapshot
A periodic snapshot of the asset details in the source system. It stores information, such as the asset's disposition at the end of the snapshot, how long the asset has been installed, how old since it was received, and more. Only those assets are extracted whose business object names have been configured as part of the extract parameter setup in source system.
For more details, see Configuring Source in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
ER relationship diagram of Asset Snapshot fact
Properties
Property
Value
Target Table Name
CF_ASSET_SNAP
Table Type
Fact
Fact Type
Snapshot
W1_ASSET
ODI Package Name
B1_PKG_CF_ASSET_SNAP
ETL View Name
n/a
Fields
Target Field
Description
Source Field
Surrogate Key
ASSET_SNAP_KEY
Asset Snapshot Fact Surrogate Key
This field is populated from the B1_ASSET_SNAP_SEQ sequence.
Natural Keys
SRC_ASSET_ID
Source Asset ID
W1_ASSET.ASSET_ID
SNAP_TYPE_CD
Snapshot Type Code
This field is populated based on the ETL job configuration.
Measures
AGE
Age in Days
W1_ASSET_NODE.EFF_DTTM
This field is populated with the asset’s age that is calculated as the difference (in days) between the earliest asset disposition date and the snapshot period end date.
INSTALL_AGE
Install Age in Days
W1_ASSET_NODE.ASSET_DPOS_FLG
This field is populated with the asset's install age if the asset disposition at the end of the snapshot is ‘Installed’ or ‘In Service’. It is calculated as the difference (in days) between the latest asset disposition date and the snapshot period end date.
FAIL_CNT_LIFETIME
Count of Failures (Lifetime)
This field is populated with the number of times this asset failed in its lifetime.
The failure count is determined by counting the number of completed/closed high priority, regular work orders that were created against the asset from its very first installation until the snapshot period end date.
MTBF_LIFETIME
Mean Time Between Failures (Lifetime)
Mean Time Between Failure is the average length of operating time between failures for an asset.
This field is calculated by looking at the total operating hours of the asset divided by the number of failures.
Duration (in hours) = Snapshot end date - First installation of the asset
MTTR_LIFETIME
Mean Time to Repair (Lifetime)
Mean Time To Repair is the average time needed to restore an asset to its full operational condition upon a failure.
This field is calculated by summing the duration of all asset downtime (in hours) and dividing by the number of failures.
FAIL _CNT_BUCKET1
Count of Failures in Bucket 1
This is the total count of failures that falls within the first configurable bucket range.
FAIL _CNT_BUCKET2
Count of Failures in Bucket 2
This is the total count of failures that falls within the second configurable bucket range.
FAIL _CNT_BUCKET3
Count of Failures in Bucket 3
This is the total count of failures that falls within the third configurable bucket range.
FAIL _CNT_BUCKET4
Count of Failures in Bucket 4
This is the total count of failures that falls within the fourth configurable bucket range.
FAIL _CNT_BUCKET5
Count of Failures in Bucket5
This is the total count of failures that falls within the fifth configurable bucket range.
FAIL _CNT_BUCKET6
Count of Failures in Bucket 6
This is the total count of failures that falls within the sixth configurable bucket range.
FAIL_CNT_BUCKET7
Count of Failures in Bucket 7
This is the total count of failures that falls within the seventh configurable bucket range.
FAIL_CNT_BUCKET8
Count of Failures in Bucket 8
This is the total count of failures that falls within the eighth configurable bucket range.
FAIL_CNT_BUCKET9
Count of Failures in Bucket 9
This is the total count of failures that falls within the ninth configurable bucket range.
FAIL_CNT_BUCKET10
Count of Failures in Bucket 10
This is the total count of failures that falls within the last configurable bucket range.
MTBF_BUCKET1
Mean Time Between Failures in Bucket 1
This is the mean time between failures that falls within the first configurable bucket range.
MTBF_BUCKET2
Mean Time Between Failures in Bucket 2
This is the mean time between failures that falls within the second configurable bucket range.
MTBF_BUCKET3
Mean Time Between Failures in Bucket 3
This is the mean time between failures that falls within the third configurable bucket range.
MTBF_BUCKET4
Mean Time Between Failures in Bucket 4
This is the mean time between failures that falls within the fourth configurable bucket range.
MTBF_BUCKET5
Mean Time Between Failures in Bucket 5
This is the mean time between failures that falls within the fifth configurable bucket range.
MTBF_BUCKET6
Mean Time Between Failures in Bucket 6
This is the mean time between failures that falls within the sixth configurable bucket range.
MTBF_BUCKET7
Mean Time Between Failures in Bucket 7
This is the mean time between failures that falls within the seventh configurable bucket range.
MTBF_BUCKET8
Mean Time Between Failures in Bucket 8
This is the mean time between failures that falls within the eighth configurable bucket range.
MTBF_BUCKET9
Mean Time Between Failures in Bucket 9
This is the mean time between failures that falls within the ninth configurable bucket range.
MTBF_BUCKET10
Mean Time Between Failures in Bucket 10
This is the mean time between failure that falls within the last configurable bucket range.
MTTR_BUCKET1
Mean Time to Repair in Bucket 1
This is the mean time to repair that falls within the first configurable bucket range.
MTTR_BUCKET2
Mean Time to Repair in Bucket 2
This is the mean time to repair that falls within the second configurable bucket range.
MTTR_BUCKET3
Mean Time to Repair in Bucket 3
This is the mean time to repair that falls within the third configurable bucket range.
MTTR_BUCKET4
Mean Time to Repair in Bucket 4
This is the mean time to repair that falls within the fourth configurable bucket range.
MTTR_BUCKET5
Mean Time to Repair in Bucket 5
This is the mean time to repair that falls within the fifth configurable bucket range.
MTTR_BUCKET6
Mean Time to Repair in Bucket 6
This is the mean time to repair that falls within the sixth configurable bucket range.
MTTR_BUCKET7
Mean Time to Repair in Bucket 7
This is the mean time to repair that falls within the seventh configurable bucket range.
MTTR_BUCKET8
Mean Time to Repair in Bucket 8
This is the mean time to repair that falls within the eight configurable bucket range.
MTTR_BUCKET9
Mean Time to Repair in Bucket 9
This is the mean time to repair that falls within the ninth configurable bucket range.
MTTR_BUCKET10
Mean Time to Repair in Bucket 10
This is the mean time to repair that falls within the last configurable bucket range.
FACT_CNT
Count
SNAPSHOT_DT
Snapshot Date
This field is populated with the last date of the current snapshot period (only the date part is populated).
LAST_FAIL_DTTM
Last Failure Date
W1_WO.CRE_DTTM
W1_WORK_REQ.CRE_DTTM
This field is populated with the date/time of the asset's latest failure.
See Count of Failures (Lifetime) field for definition of failure.
Foreign Keys
SNAPSHOT_DATE_KEY
Snapshot Date Key
This field is populated with the foreign key of the Date table based on the snapshot date/time associated with the asset.
W_ASSET_AGE_KEY
Asset Age Dimension Surrogate Key
This field is populated with the foreign key of the Asset Age Bucket dimension for which the asset's age falls into.
ASSET_DISP_START_
KEY
Asset Disposition Start Dimension Surrogate Key
This field is populated with the foreign key of the Asset Disposition dimension that was effective on the start date of the snapshot period.
ASSET_DISP_END_KEY
Asset Disposition End Dimension Surrogate Key
This field is populated with the foreign key of the Asset Disposition dimension that was effective on the end date of the snapshot period.
UTIL_ASSET_KEY
W1_ASSET.ASSET_ID
This field is populated with the foreign key of the Asset table based on the asset associated.
LOCATION_KEY
W1_ASSET_NODE.NODE_ID
This field is populated with the foreign key of the Location table based on the node associated with the asset’s location.
ADDR_KEY
This field is populated with the foreign key of the Address table based on the node associated with the asset’s location.
W_ASSET_INSTALL_AGE_KEY
Asset Install age Dimension Surrogate Key
This field is populated with the foreign key of the Asset Install Age Bucket dimension for which the asset's installation age falls into.
LAST_FAIL_DT_KEY
Last Failure Date Key
W1_WO.CRE_DTTM
This field is populated from the Date table based on the date part of the last failure date/time (which is populated in the Last Failure Date field).
LAST_FAIL_TM_KEY
Last Failure Time Key
W1_WO.CRE_DTTM
This field is populated from the Time table based on the time part of the last failure date/time (which is populated in the Last Failure Date field).
OWNING_ORG_KEY
W1_ASSET.OWNING_ACCESS_GRP_CD
This field is populated from the Owning Organization table based on the owning access group associated.
ASSET_SNAP_UDD1_
KEY
User Defined Dimension Key for Asset Snapshot
ASSET_SNAP_UDD2_
KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Location Snapshot
Captures a weekly/monthly snapshot of the information related to a location, including mean time between failures and mean time to repair.
ER diagram for location snapshot fact.
Properties
Property
Value
Target Table Name
CF_LOCATION_SNAP
Table Type
Fact
Fact Type
Snapshot
W1_NODE
ODI Package Name
B1_PKG_CF_LOCATION_SNAP
ETL View Name
n/a
Fields
Target Field
Description
Source Field
Surrogate Key
LOCATION_SNAP_KEY
Location Snapshot Fact Key
This field is populated from the B1_LOCATION_SNAP_SEQ sequence.
Natural Keys
SRC_LOCATION_ID
Source Location ID
W1_NODE.NODE_ID
SNAP_TYPE_CD
Snapshot Type Code
Measures
FAIL_CNT_LIFETIME
This field is populated with the number of times this asset failed in its lifetime. The failure count is determined by counting the number of completed/closed High priority, regular work orders that were created against the asset from its very first installation until the snapshot period end date.
MTBF_LIFETIME
Duration (in hours) = Snapshot end date - First installation date of the asset
MTTR_LIFETIME
FAIL _CNT_BUCKET1
FAIL _CNT_BUCKET2
FAIL _CNT_BUCKET3
FAIL _CNT_BUCKET4
FAIL _CNT_BUCKET5
FAIL _CNT_BUCKET6
FAIL_CNT_BUCKET7
FAIL_CNT_BUCKET8
FAIL_CNT_BUCKET9
FAIL_CNT_BUCKET10
MTBF_BUCKET1
This is the mean time between failure that falls within the first configurable bucket range.
MTBF_BUCKET2
This is the mean time between failure that falls within the second configurable bucket range.
MTBF_BUCKET3
This is the mean time between failure that falls within the third configurable bucket range.
MTBF_BUCKET4
This is the mean time between failure that falls within the fourth configurable bucket range.
MTBF_BUCKET5
This is the mean time between failure that falls within the fifth configurable bucket range.
MTBF_BUCKET6
This is the mean time between failure that falls within the sixth configurable bucket range.
MTBF_BUCKET7
This is the mean time between failure that falls within the seventh configurable bucket range.
MTBF_BUCKET8
This is the mean time between failure that falls within the eighth configurable bucket range.
MTBF_BUCKET9
This is the mean time between failure that falls within the ninth configurable bucket range.
MTBF_BUCKET10
MTTR_BUCKET1
MTTR_BUCKET2
MTTR_BUCKET3
MTTR_BUCKET4
MTTR_BUCKET5
MTTR_BUCKET6
MTTR_BUCKET7
MTTR_BUCKET8
MTTR_BUCKET9
MTTR_BUCKET10
FACT_CNT
Count
SNAPSHOT_DT
Snapshot Date
LAST_FAIL_DTTM
Last Failure Date
W1_WO.CRE_DTTM
See the Count of Failures (Lifetime) field for the definition of failure.
Foreign Keys
ADDR_KEY
This field is populated with the foreign key of the Address dimension based on the node associated with the asset’s location.
LOCATION_KEY
This field is populated with the foreign key of the Location dimension based on the node associated with the asset’s location.
LAST_FAIL_DT_KEY
W1_WO.CRE_DTTM
LAST_FAIL_TM_KEY
W1_WO.CRE_DTTM
OWNING_ORG_KEY
This field is populated from the Owning Organization table based on the owning access group.
SNAPSHOT_DATE_KEY
Snapshot Date Key
This field is populated from the Date table based on the snapshot date/time.
UTIL_ASSET_KEY
W1_ASSET.ASSET_ID
LOCATION_SNAP_UDD1_KEY
LOCATION_SNAP_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Service History
Accumulates the maintenance, inspection, failure, and downtime service histories created in the Oracle Utilities Work and Asset Management source system.
ER diagram for Service History fact.
Properties
Property
Value
Target Table Name
CF_SERVICE_HIST
Table Type
Fact
Fact Type
Accumulation
W1_SVC_HIST
ODI Package Name
B1_PKG_CF_SERVICE_HIST
ETL View Name
B1_F_SERVICE_HIST_VW
Fields
Target Field
Description
Source Field
Surrogate Key
SERVICE_HIST_KEY
Service History Fact Key
This field is populated from the B1_SERVICE_HIST_SEQ sequence.
Natural Keys
SRC_SERVICE_HIST_ID
Source Service History ID
W1_SVC_HIST.SVC_HIST_ID
Measures
PLANNED_DOWNTIME_DUR
Planned Downtime Duration
This field is populated with the planned downtime duration if the service history is categorized as Downtime or Failure.
If it's a Failure, the downtime information is retrieved from its corresponding downtime Service History. The service history is planned if it has a characteristic of type Downtime Reason with a value of Planned.
UNPLANNED_
DOWNTIME_DUR
Unplanned Downtime Duration
COST
Cost
This field is populated with the cost incurred for the service history's activity taking into consideration the cost distribution of the service history's asset in the activity.
FACT_CNT
Count
SERVICE_HIST_END_
DTTM
Service History End Date/Time
W1_SVC_HIST.END_DTTM
SERVICE_HIST_START_DTTM
Service History Start Date/Time
W1_SVC_HIST.BO_DATA_AREA
Note: This field is populated only for Downtime service histories.
SERVICE_HIST_DTTM
Service History Date/Time
W1_SVC_HIST.EFF_DTTM
Foreign Keys
SERVICE_HIST_END_DT_KEY
Service History End Date Dimension Surrogate Key
W1_SVC_HIST.END_DT TM
This field is populated with the foreign key of the Service History End Date dimension based on the end date of the service history.
SERVICE_HIST_END_TM_KEY
Service History End Time Dimension Surrogate Key
This field is populated with the foreign key of the Service History End Time dimension based on the end tine of the service history.
SERVICE_HIST_START_DT_KEY
Service History Start Date Dimension Surrogate Key
This field is populated with the foreign key of the Service History Start Date dimension based on the start date of the service history.
SERVICE_HIST_START_
TM_KEY
Service History Start Time Dimension Surrogate Key
This field is populated with the foreign key of the Service History Start Time dimension based on the start time of the service history.
SERVICE_HIST_D_KEY
Service History Dimension Surrogate Key
This field is populated with the foreign key of the Service History dimension based on the asset associated with the service history.
WO_KEY
W1_ACTIVITY.WO_ID
This field is populated with the foreign key of the Work Order dimension based on the work order ID of the activity associated with the service history.
WO_ACTIVITY_KEY
W1_SVC_HIST.ACT_ID
This field is populated with the Work Order Activity dimension based on the activity associated with the service history.
OWNING_ORG_KEY
W1_SVC_HIST. OWNING_ACCESS_GRP_CD
This field is populated from the Owning Organization dimension based on the owning access group.
W_PLANNER_KEY
This field is populated with the foreign key from the Planner dimension based on the planner code associated with the activity.
CREW_KEY
This field is populated with the foreign key from the Crew dimension based on the crew ID associated with the activity.
SERVICE_HIST_TYPE_
KEY
Service History Type Dimension Surrogate Key
W1_SVC_HIST.SVC_HIST_TYPE_CD
This field is populated with the foreign key from the Service History Type dimension based on the service history type code associated with the service history.
OPR_DEVICE_KEY
Operational Device Dimension Surrogate Key
W1_SVC_HIST.ASSET_ID
This field is populated from the Operational Device table.
Note: It is always populated with ‘0’.
UTIL_ASSET_KEY
LOCATION_KEY
W1_ASSET_NODE.ATTCH_TO_ASSET_ID
This field is populated based on the current location of the asset associated with the Service History.
If it is a component and its current disposition is “Attached”, its disposition will follow the disposition of the asset it is currently attached to.
ADDR_KEY
The source for this column will be the asset's location.
ASSET_INSP_STATUS_
KEY
Asset Inspection Status Dimension Surrogate Key
W1_SVC_HIST_TYPE.SVC_HIST_CATEGORY_FLG
W1_SVC_HIST_CHAR.CHAR_TYPE_CD
W1_SVC_HIST_CHAR.CHAR_VAL
This field is populated only for Service Histories of Inspection Category. It is populated based on the characteristic value configured for the 'Operational Status' characteristic type.
If no value is configured, then the default value of 'NA' is mapped.
SP_KEY
Service Point Dimension Surrogate Key
W1_NODE_IDENTIFIER.W1_ID_VALUE
This field is not used for Oracle Utilities Work and Asset Management source product.
MTR_DEVICE_KEY
US_KEY
Usage Subscription Dimension Surrogate Key
CONTACT_KEY
Contact Dimension Surrogate Key
PER_KEY
Person Dimension Surrogate Key
ACCT_KEY
Account Dimension Surrogate Key
SA_KEY
Service Agreement Dimension Surrogate Key
This field is populated based on the service agreement ID stored on the task as part of MWM-MDM integration.
PREM_KEY
Premise Dimension Surrogate Key
SERVICE_HIST_DATE_
KEY
Service History Date Dimension Surrogate Key
This field is populated with the foreign key of the Date dimension based on date associated with the service history.
SERVICE_HIST_TIME_
KEY
Service History Time Dimension Surrogate Key
This field is populated with the foreign key of the Time dimension based on time associated with the service history.
SERVICE_HIST_UDD1_
KEY
Service History User Defined Dimension 1 Surrogate Key
SERVICE_HIST_UDD2_
KEY
Service History User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Work Order
An accumulation of work orders in the source system, with a daily refresh of certain measures.
ER diagram for Work Order fact.
Properties
Property
Value
Target Table Name
CF_WO
Table Type
Fact
Fact Type
Accumulation
W1_WO
ODI Package Name
B1_PKG_CF_WO
ETL View Name
B1_F_WO_VW
Fields
Target Field
Description
Source Field
Surrogate Key
WO_KEY
Work Order Fact Surrogate Key
This field is populated from the B1_F_WO_SEQ sequence.
Natural Keys
SRC_WO_ID
Source Work Order ID
W1_WO. WO_ID
Measures
FACT_CNT
Count
CRE_DTTM
Creation Date Time
W1_WO. CRE_DTTM
CMP_DTTM
Completion Date Time
W1_WO_LOG.LOG_DTTM
This field is populated with the log date/time when the work order was transitioned to the Completed state.
REQUIRED_BY_DT
Required By Date
W1_WO.REQUIRED_BY_DT
ORIGINAL_WORK_DT
Original Work Date
This field is populated with the original work date of the activity related to work order.
If there are multiple activities for a work order with different original work dates, the earliest original work date is populated.
OVERDUE_IND
Overdue Indicator
This field is used to indicate if the Work Order is overdue.
If the work order is not finalized yet, it is considered overdue if today's date is past the Original Work Date. If the work order has been completed, it is considered overdue if it is completed past the Original Work Date.
The overdue indicator is populated with '1' if the work order is overdue. Else, it is set to '0'.
Note: This if refreshed daily if the Work Order is in a non-finalized state.
NO_COST_IND
No Cost Indicator
This field is populated based on the sum of frozen financial transactions associated with the work order's non-canceled activities.
If the total is 0, the field is set to ‘1’. Else, it is set to ‘0’.
NO_LABOR_IND
No Labor Indicator
This field is populated based on the timesheet details posted once the work order is closed.
The indicator is set to ‘1’ only when such timesheet details exist. Else, it is set to ‘0’.
Foreign Keys
This field is populated with the foreign key of the Date dimension based on the original work date associated with the activity.
CMP_DT_KEY
Completion Date Key
W1_WO_LOG.LOG_DTTM
This field is populated with the foreign key of the Date dimension based on the completion date associated with the activity.
REQUIRED_BY_DT_KEY
This field is populated with the foreign key of the Date dimension based on the required by date associated with the activity.
CRE_DT_KEY
Creation Date Key
W1_WO.CRE_DTTM
This field is populated with the foreign key of the Date dimension based on the creation date associated with the activity.
CRE_TM_KEY
Creation Time Key
W1_WO.CRE_DTTM
This field is populated with the foreign key of the Date dimension based on the creation time associated with the activity.
CMP_TM_KEY
Completion Time Key
W1_WO_LOG.LOG_DTTM
This field is populated with the foreign key of the Date dimension based on the completion time associated with the activity.
WO_D_KEY
W1_WO.WO_ID
This field is populated with the foreign key of the Work Order dimension based on the work order ID associated with the activity.
LOCATION_KEY
W1_ACTIVITY.NODE_ID
This field is populated based on the node ID of the primary non-cancelled activity for the work order.
ADDR_KEY
W1_ACTIVITY.NODE_ID
This field is populated with the foreign key of the Address dimension based on the node ID of the activity.
OWNING_ORG_KEY
W1_WO.OWNING_ACCESS_GRP_CD
This field is populated with the foreign key of the Owning Organization table based on the owning access group.
W_PLANNER_KEY
W1_WO.PLANNER_CD
This field is populated with the foreign key of the Planner dimension based on the planner code.
WO_STATUS_KEY
Work Order BO Status Dimension Surrogate Key
W1_WO.BUS_OBJ_CD
W1_WO.BO_STATUS_CD
W1_WO.BO_STATUS_REASON_CD
This field is populated with the foreign key of the Work Order BO Status dimension based on the BO status code and BO status reason code associated with the work order.
UTIL_ASSET_KEY
W1_ACTIVITY.ASSET_ID
This field is populated based on the asset of the primary activity for the work order.
CREW_KEY
W1_WO. W1_CREW_ID
WO_UDD1_KEY
Work Order User Defined Dimension 1 Surrogate Key
WO_UDD2_KEY
Work Order User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
