Upgrade OUAW Components
This page details how to upgrade the database, ETL, admin tool, and dashboard components for Oracle Utilities Analytics Warehouse v2.8.0.1.
On this page:
Upgrade the Database Component
This section details the steps to upgrade the Oracle Utilities Analytics Warehouse database component.
Copy and Decompress the Install Media
  1. Download Oracle Utilities Analytics v2.8.0.1 Oracle Database part file (Oracle Utilities Analytics v2.8.0.1 Oracle Database Multiplatform.zip) from Oracle Software Delivery Cloud onto the target database server.
  2. Create a temporary directory (example: </OUA/temp> for a Linux machine).  This directory (referred to as <TEMPDIR> below) must be located outside any current working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
  3. Unzip Oracle Utilities Analytics v2.8.0.1 Oracle Database Multiplatform.zip to <TEMPDIR> using any zip utility.
  4. Execute the SQL below before installing the RELADM, MDADM, and DWADM Schemas. This provides the required permissions to the users created.
    Copy
    Usersgrants.sql in <TEMPDIR>/BI2801/Scripts/Usersgrants.sql
Back to Top
Install the RELADM Schema
  1. Log in to the target database server.
  2. Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v2.8.0.1 Oracle Database Multiplatform zip file was extracted.
    Copy
    cd database/BI2801/RELADM/Install-Upgrade
  3. Review Storage.xml to ensure the RELADM user has quota on the mentioned tablespace in file. If not, edit the file with the correct tablespace name.
  4. Add JAVA_HOME/bin to the PATH variable.
  5. Set CLASSPATH pointing to the location where OraDBI.jar and all dependency jars exist.
    Copy
    export CLASSPATH=<TEMPDIR>/BI2801/RELADM/Jarfiles/*
  6. Execute the command below. Once complete, the utility creates the RELADM schema and system data definitions.
    Copy
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,RELADM,<Password of RELADM User>,,,,,RELADM -l 1,2 -o -q true
    Note: If an error occurs while executing a SQL or another utility, it logs and displays the error message and allows you to re-execute the current step.
  7. To generate database statistics after connecting to sys user, run the statement below:
    Copy
    exec DBMS_STATS.GATHER_SCHEMA_STATS('RELADM')
Back to Top
Install the MDADM Schema
    Copy
    cd database/BI2801/MDADM/Install-Upgrade
  3. Review Storage.xml to ensure the MDAM user has quota on the mentioned tablespace in file. If not, edit the file with the correct tablespace name.
    Copy
    export CLASSPATH=<TEMPDIR>/BI2801/MDADM/Jarfiles/*
  6. Execute  the command below. When completed, the utility creates the MDADM schema and system data definitions.
    Copy
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,MDADM,<Password of MDADM User>,,,,,MDADM -l 1,2 -o -q true
  7. Note: If an error occurs while executing a SQL or another utility, it logs and displays the error message and allows you to re-execute the current step.
  8. To generate database statistics after connecting to sys user, run the statement below:
    Copy
    exec DBMS_STATS.GATHER_SCHEMA_STATS('MDADM');
Back to Top
Install the DWADM Schema
  2. Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v2.8.0.1 Oracle Database Multiplatform.zip file was extracted.
    Copy
    cd database/BI2801/DWADM/Install-Upgrade
  3. Review Storage.xml to ensure the DWADM user has quota on the mentioned tablespace in file. If not, edit the file with the correct tablespace name.
    Copy
    export CLASSPATH=<TEMPDIR>/BI2801/DWADM/Jarfiles/*
  6. Execute the command below. When completed, the utility creates the DWADM schema and system data definitions.
    Copy
    java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,DWADM,<Password of DWADM User>,DWUSER,DWREAD,DW_USER,DW_READ,DWADM -p <Password of  DWUSER>,<Password of DWREAD> -l 1,2 -o -q true
    Note: If an error occurs while executing a SQL or another utility, it logs and displays the error message, allowing you to re-execute the current step.
    Copy
    exec DBMS_STATS.GATHER_SCHEMA_STATS('DWADM');
Back to Top
Upgrade the ETL Component
Prerequisites
Before installing the OUAW ETL component, verify the following:
  • Ensure latest Java version (Example: 1.8.341) is installed on the application server.
  • Ensure Oracle Fusion Middleware Infrastructure 12.2.1.4 installation and patches are applied on the target application server.
  • Ensure Oracle Data Integrator (ODI) 12.2.1.4 and patches are applied on the target application server.
  • Ensure GoldenGate MANAGER,JAGENT,PMSRVR process is running in both source and target database servers. Do not start any EXTRACT and REPLICATS.
  • Ensure ODI domain admin and managed servers are in stopped state.
  • Purge all the ODI operator logs.
Install the OUAW ETL Component
  1. Log in to the application server.
  2. Navigate to the temporary directory where OUAW installer is downloaded.
    Example: <TEMPDIR/application>.
  3. Set the JAVA HOME and add PATH.
    Copy
    export JAVA_HOME=<JAVA HOME>
    export PATH=$JAVA_HOME/bin:$PATH
  4. Launch the OUAW installer by running the command below. The OUAW installer Welcome page is displayed.
    Copy
    java -jar OUA_2.8.0.1.0_generic.jar -logLevel finest
  5. Review the information before you begin the installation. Click Next to continue.
  6. On the Installation Location page, define the installation location in the Oracle Home field and click Next.
    Note: The specified Oracle home directory must be an empty directory.
    Installation location section where the user is to browse for an empty directory to store the ETL component
    Field Name and Description
    Value
    Oracle Home: The directory where the Oracle Utilities Analytics Warehouse ETL is going to be installed.
    Note: This directory location is called the  ETL Home. Keep track of it, as it will be used during some deployment steps.
    Example: <ETL Home>
    </u01/ouaw/deployment/OUA_ETL>
  1. On the  Languages Selection page, select English and click Next.
    Languages Selection section that shows the available languages on the left column and the selected languages on the right
    Value
    Language Selection: The language for the installation process.
    English
  1. On the Installation Type page, select ODI based ETL and click Next.
    Note: Based on the selected installation type, the options on the left navigation panel change.
    Installation Type page showing the ODI based ETL option selected
    Value
    Installation Type: Select  ODI based ETL.
    ODI based ETL
  1. On the Database and Java Home Details page, enter the following and click Next.
    Database and Java Home Details page where the user is to enter the values provided.
    Value
    Database Client Home: Enter the Oracle Database Client installed location.
    Note: In case the same server is being used for both the application and the database, enter the Database Home location.
    Example: <Database Client> or <ORACLE_HOME>
    </u01/ouaw/dbclient> or </u01/ouaw/database>
    Java Home: Enter the location used for the Java install.
    Example: <JAVA HOME>
    </u01/ouaw/java>
  1. On the Target Database Connection Details page, populate the fields as detailed in the table below, and click Next.
    Target Database Connection Details page where the user is to populate several text fields.
    Value
    Host: The target database server where the database resides.
    Target Database server host name.
    <dbserver.hostname>
    Port: The target database server port number.
    Target Database port.
    Example: <1521>
    Service Name: The target database service name.
    <Database service name>
    Target Schema Password: Password for the target schema (DWADM).
    <DWADM user password>
    Confirm Target Schema Password: Confirm password for the target schema (DWADM).
    Target Schema Password: Password for the metadata schema (MDADM).
    <MDADM user password>
    Confirm Target Schema Password: Confirm password for the metadata (MDADM) schema.
  1. On the ODI Home and Schema Details page, populate the fields as detailed in the table below, and click Next.
    ODI Home and Schema Details page where the user is to populate several text fields.
    Value
    ODI Home: The directory where Oracle Data Integrator (ODI) is installed.
    Location of new FMW Home
    Example: </u01/ouaw/middleware>
    Supervisor User: Name of the Oracle Data Integrator Supervisor.
    SUPERVISOR
    Supervisor Password: Enter the Supervisor Password and store it for future reference.
    <Supervisor user password >
    Confirm Supervisor Password: Enter same as Supervisor Password.
    Master Repository Schema Name: Oracle Data Integrator master repository schema name.
    OUA_MASTER
    Master Repository Schema Password: Master Repository schema password.
    <OUA_MASTER user password>
    Confirm Master Repository Schema Password: Confirm password of the Oracle Data Integrator master repository schema.
    Work Repository Schema Name: Oracle Data Integrator work repository schema name.
    OUA_WORK
    Work Repository Schema Password: Work Repository schema password.
    <OUA_WORK user password>
    Confirm Work Repository Schema Password: Confirm password of Oracle Data Integrator work repository schema.
  1. On the Oracle Data Integrator Agent and Repository Details page, populate the fields as detailed in the table below, and click Next.
    ODI Agent and Repository Details page where the user is to enter a host and a port.
    Value
    ODI Agent Host: The application server hostname where the ODI application server is installed.
    Example:
    <appserver.hostname>
    ODI Agent Port: Enter the port which is the Oracle Data Integrator WebLogic Managed Server port. Make sure that you use the same port while creating Oracle Data Integrator managed server.
    Example: <11002>
  1. On the Target GoldenGate Details page, populate the fields as detailed in the table below, and click Next.
    Target GoldenGate Details page where the user is to populate several text fields.
    Value
    GoldenGate Host: Enter the Target database hostname where GoldenGate is  installed.
    Target database server host name
    Example: <dbserver.hostname>
    GoldenGate Home: Enter the GoldenGate installed location.
    Example: <GoldenGate Home.>
    Target Database Home: Enter the target database installed location.
    Example: <ORACLE HOME>
    GoldenGate Manager Port: The Oracle GoldenGate Manager port which is running on the database server host.
    <The default value is 7830>
    GoldenGate Algorithm: The algorithm configured in Oracle GoldenGate on the target database server
    The default value is  "BLOWFISH".
    GoldenGate Encryptkey: The Encrypt Key configured in Oracle GoldenGate on the target database server.
    The default value is “DEFAULT”
    GoldenGate Shared Secret: Shared secret key configured in Oracle GoldenGate on the target database server.
    Go to the Oracle GoldenGate prompt and run this command:
    Copy
    encrypt password <password of MDADM user>, encryptkey DEFAULT
    Provide the result of the command above as the value.
  1. On the Target JAgent Details page, populate the fields as detailed in the table below and click Next.
    Target JAgent Details page where the user is to populate several text fields.
    Value
    JAgent Host: Enter the target database hostname where GoldenGate JAgent is configured.
    The target database server host name
    JAgent GoldenGate Home: Enter the target database server GoldenGate Home installed location.
    Example: <GoldenGate Home>
    JAgent Port: Use the JAgent RMI port defined in the config properties file.
    Example: <5557>
    JAgent User: Enter the OS user that installed the JAgent.
    Example: <oracle>
    JAgent Wallet Password: Enter the JAgent Wallet password which was generated in the steps above.
    <JAGENT Wallet password>
    Confirm JAgent Wallet Password: Enter the same password as above.
  1. On the Java Home Location page, populate the fields as detailed in the table below and click Next.
    Java Home Location page where the user is to browse for the corresponding directory.
    Value
    Java Home: Enter the Java installed location (on the application server).
    Example: </u01/ouaw/java>
  1. On the Installation Summary page, a summary is displayed. Click the Install button to proceed.
    Installation Summary page, which contains information about the install location, the disk space, and the feature sets to install.
    An Installation Progress page with the progress percentage is displayed.
    Installation Progress page that shows the percentage of progress of the install.
  2. On the Installation Complete page, note the displayed details and click Finish to close the installer wizard. The ETL is now installed.
  3. Start the ODI Admin and Managed Server.
    Copy
    cd <ODI DOMAIN>/bin
    nohup ./startWebLogic.sh > startWebLogic.log 2>&1 &
    nohup ./startManagedWebLogic.sh <ODI_server1> > StartManagedWeblogic.log 2>&1 &
Back to Top
Upgrade the Administration Tool Component
Prerequisites
To remove the previously created Apex workspace from the database:
  1. Connect to the target database as SYSTEM user.
    Copy
    export ORACLE_HOME=<ORACLE_HOME>
    export ORACLE_SID=<DATABASE SERVICE NAME>
    export PATH=$ORACLE_HOME/bin:$PATH
    sqlplus system/<system user password>@<DATABASE SERVICE NAME>
  2. Run the following PL/SQL procedure.
    Copy
    BEGIN
    APEX_INSTANCE_ADMIN.REMOVE_WORKSPACE('OBIU_ADM');
    END;
  3. Make sure no workspace with “OBIU” exists in the database.
    Copy
    select WORKSPACE from APEX_WORKSPACES where WORKSPACE like '%OBIU%';
    Note: No rows should be returned from this query.
  4. Remove ords.war and i.war apps from APEX WebLogic console.
    1. Log in to APEX WebLogic console.
    2. Navigate to Deployments > Control.
    3. Click Stop and select Force Stop Now.
    4. Click Yes.
    5. On the Configuration tab, click Lock and Edit.
    6. Under Deployments, select both i and ords.
    7. Click Delete.
    8. Confirm the deletion and click Activate Changes.
  5. Uninstall the existing ords.war from the database by navigating to ords unzip location on the application server and executing the commands below.
    Copy
    cd </u01>/<ords>
    java -jar ords.war uninstall
    Note: Provide the necessary inputs for this command, and use JDK1.8 to run it.
  6. Download Apex 22.1 from Oracle and place it under a temporary directory in both the OUAW database and application servers.
    Example: </u01/temp>
  7. Download ORDS 21.1.3 from Oracle and place it under a temporary directory in the application server.
  8. Download the Admin tool (Oracle Utilities Analytics v2.8.0.1.0 Multiplatform.zip) file from the edelivery and place it under a temporary directory in the OUAW database server.
Back to Top
Admin Tool Installation Steps
  1. Log in to the target database server and navigate to the Apex extracted directory.
    Example: cd </u01/ouaw/apex>
  2. Connect to the Oracle Utilities Analytics Warehouse Database with the sys user and execute the following commands in order:
    Copy
    sqlplus sys/<sys user password>@<database service name> as sysdba
    @apxrtins.sql <Tablespace name> <Tablespace name> <Temp Tablespace name> /i/
    Example:
    @apxrtins.sql <CISTS_01> <CISTS_01> <TEMP> /i/
    Copy
    @apxchpwd.sql
  3. Run the following to install Apex for the first time:
    Copy
    EXEC DBMS_XDB.SETHTTPPORT(0);
    SELECT DBMS_XDB.GETHTTPPORT FROM DUAL;
    Note: This query should result in zero (0).
  4. Run the following SQL:
    Copy
    ALTER USER APEX_PUBLIC_USER ACCOUNT UNLOCK;
    ALTER USER APEX_PUBLIC_USER IDENTIFIED BY APEX_PUBLIC_USER;
    @apex_rest_config.sql
    Note: Make sure to note the password for these two users: APEX_LISTENER and APEX_REST_PUBLIC_USER.
Back to Top
Configure APEX Workspace for OUAW
To import the Admin tool to configure Oracle Data Integrator:
  1. Download and unzip the Oracle Utilities Analytics v2.8.0.1.0 Multiplatform.zip file, which includes the AdminTool folder.
  2. Copy the Multiplatform zip file into a temp directory within the target database server.
  3. Navigate to the TEMP directory and connect to the database using the system user.
    Copy
    cd </u01/temp/AdminTool>
    1. Create a workspace and configure the users.
      Copy
      @CreateAppWorkspace.sql
    2. Import the application.
      Copy
      @DeployAdminApp.sql
Back to Top
Install ORDS on the Application Server
  1. Navigate to the ORDS extracted directory on the application server and make sure that the APEX extracted directory is available in the location where the Admin tool is set up.
    Example:  </u01/ouaw/ords>
  2. Create a directory on the application server to configure Apex.
    Example:  mkdir -p </u01/ouaw/apex_configuration>
  3. Navigate back to the ords directory where Oracle REST Data source (ORDS) was extracted.
    Example:  cd </u01/ouaw/ords>
  4. To perform an advanced installation, execute the following commands:
    Copy
    export JAVA_HOME=</u01/ouaw/java>
    java -jar ords.war install advanced
    Note: Use JDK1.8 or a later version to run this command.
    See below an example of the command prompt, in which default options will appear enclosed in square brackets []. Use these options, or provide the necessary inputs for your requirements.
    Enter the location to store configuration data: </scratch/ouacicd/apex_configuration>
    Specify the database connection type to use.
    Enter number for [1] Basic  [2] TNS  [3] Custom URL [1]:
    Enter the name of the database server [localhost]:<dbserver.hostname>
    Enter the database listen port [1521]:<dbserver.port>
    Enter 1 to specify the database service name, or 2 to specify the database SID [1]:
    Enter the database service name:<database service name>
    Enter 1 if you want to verify/install Oracle REST Data Services schema or 2 to skip this step [1]:
    Enter the database password for ORDS_PUBLIC_USER:
    Confirm password:
    Requires to login with administrator privileges to verify Oracle REST Data Services schema.
    Enter the administrator username:sys
    Enter the database password for SYS AS SYSDBA:
    Confirm password:
    Connecting to database user: SYS AS SYSDBA url: jdbc:oracle:thin:@//<dbserver.hostname>:1521/<database service name>
    Retrieving information.
    Enter the default tablespace for ORDS_METADATA [SYSAUX]:
    Enter the temporary tablespace for ORDS_METADATA [TEMP]:
    Enter the default tablespace for ORDS_PUBLIC_USER [SYSAUX]:
    Enter the temporary tablespace for ORDS_PUBLIC_USER [TEMP]:
    Enter 1 if you want to use PL/SQL Gateway or 2 to skip this step.
    If using Oracle Application Express or migrating from mod_plsql then you must enter 1 [1]:
    Enter the PL/SQL Gateway database user name [APEX_PUBLIC_USER]:
    Enter the database password for APEX_PUBLIC_USER:
    Confirm password:
    Enter 1 to specify passwords for Application Express RESTful Services database users (APEX_LISTENER, APEX_REST_PUBLIC_USER) or 2 to skip this step [1]:
    Enter the database password for APEX_LISTENER:
    Confirm password:
    Enter the database password for APEX_REST_PUBLIC_USER:
    Confirm password:
    Enter a number to select a feature to enable:
       [1] SQL Developer Web  (Enables all features)
       [2] REST Enabled SQL
       [3] Database API
       [4] REST Enabled SQL and Database API
       [5] None
    Choose [1]:
    2021-12-08T16:43:47.300Z INFO        reloaded pools: []
    Installing Oracle REST Data Services version 21.1.3.r1531102
    ... Log file written to /scratch/gbuora/ords_install_core_2021-12-08_164347_00407.log
    ... Verified database prerequisites
    ... Created Oracle REST Data Services proxy user
    ... Created Oracle REST Data Services schema
    ... Granted privileges to Oracle REST Data Services
    ... Created Oracle REST Data Services database objects
    ... Log file written to /scratch/gbuora/ords_install_datamodel_2021-12-08_164359_00711.log
    ... Log file written to /scratch/gbuora/ords_install_apex_2021-12-08_164401_00030.log
    Completed installation for Oracle REST Data Services version 21.1.3.r1531102. Elapsed time: 00:00:15.52
    Enter 1 if you wish to start in standalone mode or 2 to exit [1]:2
  5. Navigate to the ORDS directory.
  6. Run the following command after setting JAVA HOME:
    Copy
    java -jar ords.war static </u01/ouaw/apex>/apex/images
    Note: The command above will create an i.war file in the ords folder.
Back to Top
Install the ords.war and i.war files
  1. Log in to <apex domain> WebLogic administration console and click the Lock & Edit button located in the Change Center.
  2. On the Domain Structure panel, select Deployments, then click Install.
    Domain Structure panel showing the apex domain options. Deployments, the second option, is selected here.
  3. Enter the appropriate path and then select the ords.war file. Click Next.
  4. Select the deployment target as <apex_server1>.
    Install Application Assistant page, where the user is to define the deployment target.
  5. On the application assistant, populate the fields as detailed in the table below.
    Install Application Assistant, where the user is to arrange the security and source accessibility settings.
    Value
    Name: Enter the deployment name.
    ords
    Security: Select the security model to be used.
    Select the Custom Roles  option.
    Source accessibility: Select the source accessibility option.
    Select the Use the defaults defined by the deployment's targets option.
  1. The location of ords.war file and target will appear on the Summary section. Click Finish.
    Install Application Assistant showing the Additional Configuration and Summary sections.
  2. After saving the ords.war deployment, click the Activate Changes button located in the Change Center.
  3. Repeat the steps above to deploy the i.war file.
  4. On the WebLogic administration console, navigate to Deployment and then Control.
  5. Select i and ords.
  6. Click Start and then Servicing All Requests.
  7. Restart the administration and managed servers.
Back to Top
Access the AdminTool
Use this URL to access the administration tool:
http://<hostname>:<apex_server1_port>/ords/f?p=104
  1. Provide the following credentials to access the Admintool:
    Username:  Admin
    Password:  Admin_123
    Oracle Utilities Analytics Administration login page where the user is to enter username and password.
    Note: After logging in to the application for the first time, you will be requested to change the password.
  2. After logging in, you can access the ETL Configuration and ETL Job Execution through the respective tabs.
    Administration tool home page showing the ETL Configuration, the NMS Configuration, and the ETL Job Execution menus.
Back to Top
Change the Default Password of Admin User
This section describes the APEX API used to change the admin user's password.
The script below should be run after connecting to the database as user SYSTEM.
Note: Replace the string 'New password' with the new password for the admin account before running the script.
Copy
begin
wwv_flow_api.set_security_group_id(p_security_group_id=>nvl(wwv_flow_application_install.get_workspace_id,2090606133849294));
end;
begin
apex_util.edit_user(
p_user_id => '1467765078687596',
p_user_name => 'ADMIN',
p_web_password => 'New password',
p_new_password => 'New password'
end;
commit;
Note: It is strongly recommended to change the default password after logging in.
Back to Top
Upgrade the Dashboards Component
Prerequisites
Before you begin installing the OUAW Dashboards component, note the following:
  • A single OS user must install all required software.
  • All required software (such as Java, Oracle Database Client, Oracle Fusion Middleware, Oracle Analytics Server) must be installed.
  • The Oracle Analytics Server (OAS) domain must be installed and configured, and all domain paths must be available.
  • OUAW Dashboards Component installer must be available in the <TEMPDIR>/application directory located on the application server.
Set Up the Dashboard Environment
  2. Navigate to the temporary directory where the OUAW installer was downloaded.
  3. Set the JAVA_HOME.
    Example: export JAVA_HOME=<JAVA HOME>
  4. Set the path to JAVA_HOME/bin.
    Example: export PATH=$JAVA_HOME/bin:$PATH
  5. Launch the OUAW installer by running the following command:
    Copy
Back to Top
Oracle Utilities Analytics Warehouse Dashboards Installation Wizard
  1. Run the Oracle Utilities Analytics Warehouse Installer. The Welcome page is displayed.
  2. Review the available information before you begin the installation. Click Next to continue.
  3. On the Installation Location page, select the installation location from the Oracle Home drop-down menu and click Next.
    Installation Location page where the user is to browse for the location directory.
    Value
    Oracle Home: The directory where the Oracle Utilities Analytics Warehouse Dashboards component is going to be installed.
    Note: In the documentation, this directory location is referred to as Dashboards Home. Keep note of it because it will be used during some deployment steps.
    Example: <Dashboards Home>
    </u01/ouaw/deployment/OUAW_DASHBOARD>
  1. On the Language Selection page, select English, then click Next.
    Languages Selection page, showing the available languages on the left column, and the selected ones on the right column.
    Value
    English
  1. On the Installation Type page, select the Dashboards option. The left navigation panel will change based on the installation type that was selected. You will need to enter details for the following: Database and Java Home Details, Target Database Connection Details, and OAS Home Details.
    Installation Type page. Within the three options shown, Dashboards, the second one, is selected here.
  2. Click Next.
  3. On the Database and Java Home Details page, populate the fields as detailed in the table below, then click Next.
    Database and Java Home Details page where the user is to browse for the appropriate directories.
    Value
    Database Client Home: The directory where the Oracle Database Client is installed. If you are installing the Dashboard component on the same machine as the Database component, then you can use Database Home.
    Example: <Database Client> or <ORACLE HOME>
    Java Home: The directory where Java is installed.
    </u01/ouaw/java>
  1. On the Target Database Connection Details page, populate the fields as detailed in the table below. Verify that tnsping Target-SERVICENAME gives you confirmed database connection details. Click Next.
    Value
    Host: The target database host name where the database resides.
    Target Database Server host name
    Port: The target database port number on the database server used for connecting.
    Target Database port. Example: <1521>
    <Target Database service name>
    Target Schema Password: The password for the target schema (DWADM).
    Confirm Target Schema Password: Same as the Target Schema Password.
    Metadata Schema Password: The password for the metadata schema (MDADM).
    Confirm Metadata Schema Password: The same password given for metadata schema.
  1. On the OAS Home Details page, enter the following details in the respective fields and click Next.
    OAS Home Details page where the user is to provide the BI directories, and the weblogic details.
    Value
    OAS Home: The location of the bi folder where OAS is installed on the application server.
    <FMW Home>/bi
    Example: </u01/ouaw/middleware/bi>
    OAS Domain Home: The OAS domain home location.
    <OAS Domain>
    Example: </u01/ouaw/domains/oas_domain>
    WebLogic Host: The application server hostname where the WebLogic server is running.
    WebLogic Port Number: A unique port number within the system that is assigned to the HTTP port. This port number is used as part of the client URL request to connect to the host. It is the OAS WebLogic console admin port number.
    <OAS weblogic Admin server port>
    Example: <9500>
    WebLogic User: WebLogic domain console login user name.
    Example: <weblogic>
  1. On the Java Home Location page, enter the proper file path and click Next.
    Java Home Location page where the user is to select the appropriate directory.
    Value
    Java Home: Enter the Java installed location.
    </u01/ouaw/java>
  1. On the Installation Summary page, verify the installation options and click Install. To make changes to the configuration before starting the installation, use the navigation pane and select the topic to edit.
    Installation Summary page showing install location, disk space and feature sets information.
    An Installation Progress page appears to track the installation. Detailed logs of the installation are available in the logs/system directory under the installation location.
    Installation Progress page where the percentage of progress of the installation appears.
  2. On the Installation Complete page, click Finish to close the installer.
    Installation Complete page that indicates that the install is finished.
Back to Top
Deploy the Web Catalog
On the Oracle Analytics Server, you can deploy the latest catalogs into the environment using the online mode.
  1. Optional. If you want to take a backup of the existing deployed catalog, follow the OAS Doc ID 2724149.1 in My Oracle Support.
  2. Navigate to <DOMAIN DOMAIN>/<OAS_DOMAIN>/bitools/bin.
  3. Create a new credentials file called boot.txt and add the following contents to it:
    Copy
    login=<OAS Weblogc admin user>
    pwd=<OAS Weblogic admin password>
    For each catalog present under <Dashboards Home>/Catalog directory, run the following command from the <OAS DOMAIN HOME>/bitools/bin location. Replace all parameters enclosed in <> with the appropriate values.
    Copy
    ./runcat.sh -cmd unarchive -folder "/shared" -online http://<OAS SERVER Host>:<OAS Managed SERVER PORT>/analytics-ws/saw.dll -credentials boot.txt -inputFile "<Dashboards Home>/Catalog/<Catalog Name>" -overwrite all
    Note: The  inputFile parameter must be in double quotes, and the catalog file name must include spaces.
  4. Deploy the 'Spatial Metadata Catalog' on the System folder. Replace all parameters enclosed in <> with the appropriate values.
    Copy
    ./runcat.sh -cmd unarchive -folder "/system" -online http://<OAS SERVER Host>:<OAS Managed SERVER PORT>/analytics-ws/saw.dll  -credentials boot.txt -inputFile "<Dashboards Home>/Catalog/Spatial Metadata.Catalog" -overwrite all
    Note: The inputFile parameter must be in double quotes, and the catalog filename must include spaces.
Back to Top
Deploy the Merged RPD File
To merge the customized 2.8.0.0.1 RPD file with the 2.8.0.1.0 RPD, which contains the database changes required:
  1. Copy both 2.8.0.1.0 and 2.8.0.0.1 RPD files to the Windows machine where Oracle Analytics Client Tool 6.4 is installed, then merge it.
    Note: RPD file merge steps can be found here:  Merging Repositories
  2. Once the RPD file merge is complete, copy the modified RPD back to the <install dir>/Reports/rpd/UtilitiesBusinessAnalytics.rpd, where <install_dir> is the Oracle Utilities Analytics Dashboard Component installation directory.
 Upload the RPD File
  1. Log in to the target application server where OAS is installed.
  2. Navigate to <DOMAIN HOME>/<OAS DOMAIN>/bitools/bin.
  3. Run the following command to deploy the RPD:
    Copy
    ./datamodel.sh uploadrpd -I <Dashboards Home>/Reports/rpd/UtilitiesBusinessAnalytics.rpd -W <rpd password, defaultpassword is oracle123> -U <Weblogic user name of OAS domain> -P <Weblogic password of OAS domain> -SI ssi
  4. Run the following commands from the <OAS_DOMAIN>/bitools/bin directory to stop and start the OAS domain services respectively.
    Copy
    ./stop.sh
    ./start.sh
Back to Top
Deploy Writeback Templates
  1. Log in to the application server and run the following commands to deploy writeback templates:
    Copy
    mkdir -p <FMW Home>/bi/bifoundation/web/msgdb/l_en/custommessages
    cp <Dashboards Home>/writeback/wbtemplates/*  <FMW Home>/bi/bifoundation/web/msgdb/l_en/custommessages/
  2. Restart the Oracle Analytics Server services after deploying these writeback templates in the specified path.
    Copy
    cd <OAS DOMAIN>/bitools/bin
    ./stop.sh
    ./start.sh
Back to Top
Configure MapViewer for OUAW
To work with OUAW Analytics, there are a few changes that need to be made in the mapViewerConfig file. The file is located in <OAS DOMAIN>/config/fmwconfig/mapviewer/conf.  Ensure you take a backup before updating it.
Note: Skip this task on AIX/Solaris. The Mapviewer URL is not supported in AIX/Solaris.
Update the MapViewer Configuration from the MapViewer Admin Console
Note: Ignore the following steps if the mapViewerConfig.xml file was restored during OAS domain upgrade.
  1. Log in to MapViewer (http://<Server>:<port>/mapviewer)
  2. Navigate to MapViewer > Administration > Configuration to edit the mapViewerConfig.xml file. If the customer environment runs behind the proxy, then insert the list of host names for all the third-party service providers in the security_config node.
    Example:
    <proxy_enabled_hosts>
    elocation.oracle.com
    </proxy_enabled_hosts>
  3. Add the following ns_data_provider node:
    Copy
    <ns_data_provider id="obieeNsdp" class="com.oracle.utilities.birdseye.BirdseyeNSDP" />
  4. Add the current map_tile_server with the following map_tile_server node:
    Copy
    <map_tile_server>
    <tile_storage default_root_path="/mytilecache/"/>
    </map_tile_server>
  5. Add the following map data source code in the mapViewerConfig.xml with the appropriate values as database server details:
    Copy
    <map_data_source name="mapconn"
    jdbc_host="<DB server name>"
    jdbc_sid="//<DB Service name>"
    jdbc_port="1521"
    jdbc_user="DWADM"
    jdbc_password="!<DWADM user password>"
    jdbc_mode="thin"
    number_of_mappers="32"
    allow_jdbc_theme_based_foi="true"
  6. Click Save and Restart.
Back to Top
Configure Spatial Data
  2. Navigate to the temporary directory where the Oracle Utilities Analytics Warehouse v2.8.0.1 Oracle Database Multiplatform.zip file was extracted.
    Copy
    cd database/BI2801/Spatial-Metadata
  3. Set the following environment variables.
    Copy
    export ORACLE_HOME=<ORACLE HOME>
  4. Create the database directory in the database after connecting to sys user.
    Copy
    sqlplus sys/<sys user password>@<DATABASE SERVICE NAME>
    Example: Create the directory <dump_dir> as '</u01/dumps>'.
  5. Copy the user_sdo.dmp dumpfile from the temporary directory <TEMPDIR>/database/BI2801/Spatial-Metadata to the database directory <dump_dir> location.
    Example: </u01/dumps>
  6. Execute the impdp command to import the USER_SDO* tables data.
    Copy
    impdp directory=dump_dir dumpfile=user_sdo.dmp logfile=impdp_user_sdo.log schemas=DWADM remap_tablespace=cists_01:<tablespace_name>
  7. Provide DWADM user name password when prompted.
    Note:  Ensure to change the tablespace_name to the name on which DWADM has the quota. If DWADM user have quota on cists_01 tablespace, then exclude the whole remap_tablespace clause from the command.
  8. Review the impdp_user_sdo.log file to ensure the tables are imported successfully.
  9. After importing the tables, run the following SQL scripts from the <TEMPDIR>/BI2801/Spatial-Metadata directory.
    Copy
    sqlplus dwadm/<dwadm user password>@<database service name>
    @copy_spatial_metadata.sql
    @clean_sdo_release_tbls.sql
  10. Review the log files.
Back to Top
Post-Upgrade Steps
Run Post-Upgrade Steps
  1. Run source configuration for Network Management System (NMS) in Upgrade mode.
  2. Start B1_RUN_ALL from ODI studio.
    1. Log in to Oracle Data Integrator Studio.
    2. Navigate to Designer > Load plan and Scenarios > Framework > B1_RUN_ALL > Scheduling.
    3. Double-click Global/WLS_AGENT, select Active, and save the changes.
    4. On Studio, navigate to the Topology tab. Right-click OracleDIAgent and select Update Schedule.
  3. Start the GG processes ( EXTRACTS & REPLICATS ) in both source and target databases.
  4. Change the value of the parameter Maximum Table Name Length to 128.
    1. In ODI studio, navigate to Topology > Physical Architecture > Technologies.
    2. Right-click Oracle and select Open.
    3. Navigate to the Advanced tab and change the parameter Maximum Table Name Length to 128.
    4. Click Save.
  5. Start the source application.
Back to Top
