Verifying Model Setup
After the initial sync process is complete:
1. Verify that the model is set up.
select *
from mdadm.b1_checkpoint
where group_name = 'CCB1AE';
If the record does not exist, it indicates that the Oracle GoldenGate scripts for CCB1AE model were not deployed.
2. Verify that the table data is in sync.
select *
from mdadm.b1_table_sync
where model_cd = 'CCB1AE';
select *
from ccb1rep.ci_acct_char;
If there is no entry it indicates that the B1_SYNC_CONTEXT scenario was not executed. Or, if it was executed, the Oracle GoldenGate scripts were not deployed at that time.
Important:
• Enable all the replication tables required for customization and follow the steps mentioned in the Creating Replicated Tables and Executing Initial Sync sections.
• Ensure that each model does not include more than 100 tables.
