Property | Value |
Target Table | CD_APPT_TM |
Table Type | Dimension |
SCD Type | Type 1 |
Source System Driver Table | F1_BKT_CONFIG |
Stage Table | STG_CD_APPT_TM |
ODI Package | B1_PKG_CD_APPT_TM |
ETL View | B1_D_APPT_VW |
Target Field | Description | Source Field | Transformation Logic |
Surrogate Key | |||
APPT_TM_KEY | Appointment Time Dimension Surrogate Key | This field is populated from the OUBI_APPT_TM_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Appointment Time Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | This field is populated with the bucket start range based on the bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for appointment time. |
END_RANGE | Appointment Time End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on the bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for appointment time. |
Attributes | |||
APPT_TM_DESCR | Appointment Time Description | F1_BKT_CONFIG_VAL_L.DESCR | |
APPT_STATUS_DESCR | Appointment Status Description | CI_LOOKUP_VAL_L.DESCR_OVRD CI_LOOKUP_VAL_L.DESCR | This field is populated with the description from Lookup Language table for M1_APPT_STATUS_FLG lookup field. If override description is not available, regular description is extracted. |
APPT_STATUS_CD | Appointment Status Code | F1_BKT_CONFIG_VAL.BKT_VAL_TYPE_CD | |
APPT_TM_CD | Appointment Time Code | Note: This field is obsolete and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
User Defined Attributes | |||
UDF1_CD | User Defined Field 1 Code | ||
UDF1_DESCR | User Defined Field 1 Description | ||
UDF2_CD | User Defined Field 2 Code | ||
UDF2_DESCR | User Defined Field 2 Description | ||
UDF3_CD | User Defined Field 3 Code | ||
UDF3_DESCR | User Defined Field 3 Description | ||
UDF4_CD | User Defined Field 4 Code | ||
UDF4_DESCR | User Defined Field 4 Description | ||
UDF5_CD | User Defined Field 5 Code | ||
UDF5_DESCR | User Defined Field 5 Description | ||
UDF6_CD | User Defined Field 6 Code | ||
UDF6_DESCR | User Defined Field 6 Description | ||
UDF7_CD | User Defined Field 7 Code | ||
UDF7_DESCR | User Defined Field 7 Description | ||
UDF8_CD | User Defined Field 8 Code | ||
UDF8_DESCR | User Defined Field 8 Description | ||
UDF9_CD | User Defined Field 9 Code | ||
UDF9_DESCR | User Defined Field 9 Description | ||
UDF10_CD | User Defined Field 10 Code | ||
UDF10_DESCR | User Defined Field 10 Description | ||
Data Load Attributes | |||
UPDATE_DTTM | Update Date and Time | ||
DATA_LOAD_DTTM | Data Load Date/Time | This field is populated with the load timestamp value. | |
DATA_SOURCE_IND | Data Source Indicator | CI_INSTALLATION.ENV_ID | This field is populated with the DSI value on the source product instance configuration. The table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system. |
JOB_NBR | Job Number | This field is populated with the ODI job execution session number. | |
Property | Value |
Target Table | CD_APPT_TM_OF_DAY |
SCD Type | Type 1 |
Stage Table | STG_CD_APPT_TM_OF_DAY |
ODI Package | B1_PKG_CD_APPT_TM_OF_DAY |
ETL View | B1_D_APPT_OF_DAY_VW |
Surrogate Key | |||
APPT_TM_OF_DAY_KEY | Appointment Time of Day Dimension Surrogate Key | This field is populated from the OUBI_APPT_TM_OF_DAY_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Appointment Time of Day Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | The field is populated with the bucket start range based on the bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for appointment time of day. |
END_RANGE | Appointment Time of Day End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on the bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for appointment time of day. |
Attributes | |||
APPT_TM_OF_DAY_DESCR | Appointment Time of Day Description | F1_BKT_CONFIG_VAL_L.DESCR | |
APPT_TM_OF_DAY_CD | Appointment Time Of Day Code | Note: This field is obsolete and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_CREW_SHIFT |
SCD Type | Type 2 |
Source System Driver Table | M1_CREW_SHFT F1_BUS_OBJ |
Stage Table | STG_CD_CREW_SHIFT |
ODI Package | B1_PKG_CD_CREW_SHIFT |
ETL View | B1_D_CREW_SHIFT_VW |
Surrogate Key | |||
CREW_SHIFT_KEY | Crew Shift Surrogate Key | This field is populated from the SPL_CREW_SHIFT_SEQ sequence. | |
Natural Keys | |||
SRC_CREW_SHIFT_ID | Crew Shift ID | M1_CREW_SHFT.CREW_SHFT_ID | |
Attributes | |||
CREW_SHIFT_TYPE_DESCR | Crew Shift Type Description | M1_CREW_SHFT_TYPE_L.DESCR | |
PRIMARY_FN_DESCR | Primary Function Description | M1_SVC_CLS_L.DESCR | |
CREW_SHIFT_INFO | Crew Shift Description | M1_RESRC_ID.RESRC_ID_VAL M1_CREW_SHFT_TYPE_L.DESCR M1_CREW_SHFT.PLAN_START_DTTM M1_CREW_SHFT.PLAN_END_DTTM F1_BUS_OBJ_STATUS_L.DESCR | This field is a concatenation of crew name, crew shift type, planned start date, planned end date, and shift status. |
CREW_SHIFT_TYPE_CD | Crew Shift Type Code | M1_CREW_SHFT.CREW_SHFT_TYPE_CD | |
PRIMARY_FN_CD | Primary Function Code | M1_CREW_SHFT_SVC_CLS.SVC_CLS_CD | This field is populated from the Crew Shift Service Class table based on the usage flag (set as 'Primary') associated with the current shift ID. |
UDF1_CD | Shift Type | ||
UDF1_DESCR | Shift Type Code | ||
UDF7_CD | User Defined Field 7Code | ||
EFF_END_DTTM | Effective End Date/Time | ||
EFF_START_DTTM | Effective Start Date/Time | ||
Property | Value |
Target Table | CD_CREW_TM_USG |
SCD Type | Type 1 |
Source System Driver Table | F1_EXT_LOOKUP_VAL |
Stage Table | STG_CD_CREW_TM_USG |
ODI Package | B1_PKG_CD_CREW_TM_USG |
ETL View | B1_D_CREW_TM_USG_VW |
Surrogate Key | |||
CREW_TM_USG_KEY | Crew Time Usage Dimension Surrogate Key | This field is populated from the OUBI_CREW_TM_USG_SEQ sequence. | |
Natural Keys | |||
CREW_TM_USG_CD | Crew Time Usage Code | F1_EXT_LOOKUP_VAL.F1_EXT_LOOKUP_VALUE | This field extracts the records defined only for the M1-CrewTimeUsageLookup lookup business object. |
Attributes | |||
CREW_TM_USG_DESCR | Crew Time Usage Description | F1_EXT_LOOKUP_VAL_L.DESCR_OVRD F1_EXT_LOOKUP_VAL_L.DESCR | If override description is not available, regular description is extracted. |
PRODUCTIVITY_DESCR | Productivity Description | CI_LOOKUP_VAL_L.DESCR_OVRD CI_LOOKUP_VAL_L.DESCR | This field is populated with description from the Lookup Language table for the M1_CREW_TM_USG_CLS_FLG lookup field. If override description is not available, regular description is extracted. |
PRODUCTIVITY_CD | Productivity Code | F1_EXT_LOOKUP_VAL.BO_DATA_AREA | This field is populated with the productivity code from the CLOB column. |
UPDATE_DTTM | Update Date/Time | ||
Property | Value |
Target Table | CD_EARLY_LOGOFF_TM |
SCD Type | Type 1 |
Stage Table | STG_CD_EARLY_LOGOFF_TM |
ODI Package | B1_PKG_CD_EARLY_LOGOFF_TM |
ETL View | B1_D_EARLY_LOGOFF_TM_VW |
Surrogate Key | |||
EARLY_LOGOFF_TM_ KEY | Early Logoff Time Dimension Surrogate Key | This field is populated from the OUBI_EARLY_LOGOFF_TM_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Early Logoff Time Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | The field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for early logoff time. |
END_RANGE | Early Logoff Time End Ran | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for early log off time. |
Attributes | |||
EARLY_LOGOFF_TM_ DESCR | Early Logoff Time Description | F1_BKT_CONFIG_VAL_L.DESCR | |
CONSIDERED_ONTIME_CD | Considered On Time Code | F1_BKT_CONFIG_VAL.BKT_VAL_TYPE_CD | |
CONSIDERED_ONTIME_DESCR | Considered On Time Description | CI_LOOKUP_VAL_L. DESCR_OVRD CI_LOOKUP_VAL_L. DESCR | This field is populated with description from the Lookup Language table for the M1_CONSD_ON_TIME_FLG lookup field. If override description is not available, regular description is extracted. |
EARLY_LOGOFF_TM_ CD | Early Logoff Time Code | Note: This field is obsolete and is not be populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_LATE_LOGON_TM |
SCD Type | Type 1 |
Stage Table | STG_CD_LATE_LOGON_TM |
ODI Package | B1_PKG_CD_LATE_LOGON_TM |
ETL View | B1_D_LATE_LOGON_TM_VW |
Surrogate Key | |||
LATE_LOGON_TM_KEY | Late Logon Time Dimension Surrogate Key | This field is populated from the OUBI_LATE_LOGON_TM_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Late Logon Time Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | The field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for late logon time. |
END_RANGE | Late Logon Time End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for late logon time. |
Attributes | |||
LATE_LOGON_TM_DESCR | Late Logon Time Description | F1_BKT_CONFIG_VAL_L.DESCR | |
CONSIDERED_ONTIME_DESCR | Considered On Time Description | CI_LOOKUP_VAL_L.DESCR_OVRD CI_LOOKUP_VAL_L.DESCR | This field is populated with description from the Lookup Language table for the M1_CONSD_ON_TIME_FLG lookup field. If override description is not available, regular description is extracted. |
LATE_LOGON_TM_CD | Late Logon Time Code | Note: This field is obsolete now and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_RESP_TM_DEV |
SCD Type | Type 1 |
Stage Table | STG_CD_RESP_TM_DEV |
ODI Package | B1_PKG_CD_RESP_TM_DEV |
ETL View | B1_D_RESP_TM_DEV_VW |
Surrogate Key | |||
RESP_TM_DEV_KEY | Response Time Deviation Dimension Surrogate Key | This field is populated from the OUBI_RESP_TM_DEV_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Response Time Deviation Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | The field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for response time deviation. |
END_RANGE | Response Time Deviation End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for response time deviation. |
Attributes | |||
RESP_TM_DEV_DESCR | Response Time Deviation Description | F1_BKT_CONFIG_VAL_L.DESCR | |
SLA_STATUS_DESCR | SLA Status Description | CI_LOOKUP_VAL_L.DESCR_OVRD CI_LOOKUP_VAL_L.DESCR | This field is populated with description from the Lookup Language table for the M1_SLA_STATUS_FLG lookup field. If override description is not available, regular description is extracted. |
SLA_STATUS_CD | SLA Status Code | F1_BKT_CONFIG_VAL.BKT_VAL_TYPE_CD | |
RESP_TM_DEV_CD | Response Time Deviation Code | Note: This field is obsolete and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_SHIFT_BO_STATUS |
SCD Type | Type 1 |
Source System Driver Table | F1_BUS_OBJ F1_BUS_OBJ_STATUS_RSN |
Stage Table | STG_CD_SHIFT_BO_STATUS |
ODI Package | B1_PKG_CD_SHIFT_BO_STATUS |
ETL View | B1_D_SHIFT_BO_STATUS_VW |
Surrogate Key | |||
SHIFT_BO_STATUS_KEY | Shift BO Status Surrogate Key | This field is populated from the OUBI_SHIFT_BO_STAT_SEQ sequence. | |
Natural Keys | |||
BUS_OBJ_CD | Business Object | F1_BUS_OBJ.BUS_OBJ_CD | This field extracts all business objects of the Crew Shift maintenance object only. |
STATUS_CD | BO Status Code | F1_BUS_OBJ_STATUS.BO_STATUS_CD | |
REASON_CD | Status Reason Code | F1_BUS_OBJ_STATUS_RSN.BO_STATUS_REASON_CD | |
Attributes | |||
BUS_OBJ_DESCR | Business Object Description | F1_BUS_OBJ_L.DESCR | |
STATUS_DESCR | Status Description | F1_BUS_OBJ_STATUS_L.DESCR | |
STATUS_COND_CD | Status Condition Code | F1_BUS_OBJ_STATUS.BO_STATUS_COND_FLG | |
STATUS_COND_DESCR | Status Condition Description | CI_LOOKUP_VAL_L.NVL(CI_LOOKUP_VAL_L.DESCR_OVRD,CI_LOOKUP_VAL_L.DESCR) | This field is populated with description from the Lookup Language table for the BO_STATUS_COND_FLG lookup field. If override description is not available, regular description is extracted. |
REASON_DESCR | Status Reason Description | F1_BUS_OBJ_STATUS_RSN_L.DESCR | |
Property | Value |
Target Table | CD_TASK_BO_STATUS |
SCD Type | Type 1 |
Stage Table | STG_CD_TASK_BO_STATUS |
ODI Package | B1_PKG_CD_TASK_BO_STATUS |
ETL View | B1_D_TASK_BO_STATUS_VW |
Surrogate Key | |||
TASK_BO_STATUS_KEY | Task BO Status Surrogate Key | This field is populated from the OUBI_TASK_BO_STAT_SEQ sequence. | |
Natural Keys | |||
BUS_OBJ_CD | Business Object | F1_BUS_OBJ.BUS_OBJ_CD | This field extracts all business objects of the Device Event maintenance object only. |
Attributes | |||
INCOMPLETE_IND | Incomplete Indicator | F1_BUS_OBJ_STATUS_OPT.BO_OPT_VAL | This field is populated based on the state condition defined on the business object status. If the status is ‘Postponed’, or ‘Completed’ with ‘Incomplete’ status reason, the indicator is populated as ‘1’, else ‘0’. |
Property | Value |
Target Table | CD_TASK_TYPE |
SCD Type | Type 1 |
Source System Driver Table | M1_TASK_TYPE |
Stage Table | STG_CD_TASK_TYPE |
ODI Package | B1_PKG_CD_TASK_TYPE |
ETL View | B1_D_TASK_TYPE_VW |
Surrogate Key | |||
TASK_TYPE_KEY | Task Type Dimension Surrogate Key | This field is populated from the OUBI_TASK_TYPE_SEQ sequence. | |
Natural Keys | |||
TASK_TYPE_CD | Activity Type Code | M1_TASK_TYPE.TASK_TYPE_CD | |
Attributes | |||
TASK_TYPE_DESCR | Task Type Description | M1_TASK_TYPE_L.DESCR | |
TASK_CLASS_CD | Task Class Code | M1_TASK_TYPE.TASK_CLS_FLG | |
PRIORITY_PROF_CD | Priority Profile Code | M1_TASK_TYPE.PRI_PROF_CD | |
SVC_CATEGORY_CD | Service Category Code | M1_TASK_TYPE.BO_DATA_AREA | This field is populated with the service category code from the CLOB column. |
TASK_CLASS_DESCR | Task Class Description | CI_LOOKUP_VAL_L.DESCR_OVRD CI_LOOKUP_VAL_L.DESCR | This field is populated with description from the Lookup Language table for the TASK_CLS_FLG lookup field. If override description is not available, regular description is extracted. |
PRIORITY_PROF_DESCR | Priority Profile Description | M1_PRI_PROF_L.DESCR | |
SVC_CATEGORY_DESCR | Service Category Description | F1_EXT_LOOKUP_VAL_L.DESCR_OVRD F1_EXT_LOOKUP_VAL_L.DESCR | This field is populated with description from the Lookup Language table for the M1-ServiceCategoryLookup lookup business object. If override description is not available, regular description is extracted. |
RESP_TM_SLA | Response Time SLA | M1_TASK_TYPE.BO_DATA_AREA | This field is populated with the response time SLA from the CLOB column. |
Property | Value |
Target Table | CD_TRAVEL_DIST_DEV |
SCD Type | Type 1 |
Stage Table | STG_CD_TRAVEL_DIST_DEV |
ODI Package | B1_PKG_CD_TRAVEL_DIST_DEV |
ETL View | B1_D_TRAVEL_DIST_DEV_VW |
Surrogate Key | |||
TRAVEL_DIST_DEV_ KEY | Travel Distance Deviation Dimension Surrogate Key | This field is populated from the OUBI_TRAVEL_DIST_DEV_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Travel Distance Deviation Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | This field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for travel distance deviation. |
END_RANGE | Travel Distance Deviation End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | This field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for travel distance deviation. |
Attributes | |||
TRAVEL_DIST_DEV_ DESCR | Travel Distance Deviation Description | F1_BKT_CONFIG_VAL_L.DESCR | |
TRAVEL_DIST_DEV_CD | Distance Deviation Code | Note: This field is obsolete and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_TRAVEL_DUR_DEV |
SCD Type | Type 1 |
Stage Table | STG_CD_TRAVEL_DUR_DEV |
ODI Package | B1_PKG_CD_TRAVEL_DUR_DEV |
ETL View | B1_D_TRAVEL_DUR_DEV_VW |
Surrogate Key | |||
TRAVEL_DUR_DEV_ KEY | Travel Duration Deviation Dimension Surrogate Key | This field is populated from the OUBI_TRAVEL_DUR_DEV_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Travel Duration Deviation Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | This field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for travel duration deviation. |
END_RANGE | Travel Duration Deviation End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for travel duration deviation. |
Attributes | |||
TRAVEL_DUR_DEV_ DESCR | Travel Duration Deviation | F1_BKT_CONFIG_VAL_L.DESCR | |
TRAVEL_DUR_DEV_CD | Travel Duration Deviation Code | Note: This field is obsolete and will not be populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
Property | Value |
Target Table | CD_WORK_DUR_DEV |
SCD Type | Type 1 |
Stage Table | STG_CD_WORK_DUR_DEV |
ODI Package | B1_PKG_CD_WORK_DUR_DEV |
ETL View | B1_D_WORK_DUR_DEV_VW |
Surrogate Key | |||
WORK_DUR_DEV_KEY | Work Duration Deviation Dimension Surrogate Key | This field is populated from the OUBI_WORK_DUR_DEV_SEQ sequence. | |
Natural Keys | |||
START_RANGE | Work Duration Deviation Start Range | F1_BKT_CONFIG_VAL.BKT_START_RANGE | This field is populated with the bucket start range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for work duration deviation. |
END_RANGE | Work Duration Deviation End Range | F1_BKT_CONFIG_VAL.BKT_END_RANGE | The field is populated with the bucket end range based on bucket configuration code. The bucket configuration code from the Bucket Configuration table is retrieved based on the bucket configuration BO defined for work duration deviation. |
Attributes | |||
WORK_DUR_DEV_ DESCR | Work Duration Deviation Description | F1_BKT_CONFIG_VAL_L.DESCR | |
WORK_DUR_DEV_CD | Work Duration Deviation Code | Note: This field is obsolete and is not populated. The new bucket configurations based on the OUAF bucket configuration tables do not need this. | |
