Property | Value |
Target Table | CD_ADDR |
Table Type | Dimension |
SCD Type | Type 2 |
Source System Driver Table | M1_TASK_ADDR M1_LOCATION M1_POU M1_RESRC |
Stage Table | STG_CD_ADDR |
ODI Package | B1_PKG_CD_ADDR |
ETL View | B1_D_ADDR_VW |
Target Field | Description | Source Field | Transformation Logic |
Surrogate Key | |||
ADDR_KEY | Address Dimension Surrogate Key | This field is populated from the SPL_ADDR_SEQ sequence. | |
Natural Keys | |||
SRC_ADDR_ID | Premise ID | M1_TASK_ADDR.ADDRESS1 M1_TASK_ADDR.ADDRESS2 M1_TASK_ADDR.ADDRESS3 M1_TASK_ADDR.ADDRESS4 M1_TASK_ADDR.CROSS_STREET M1_TASK_ADDR.SUBURB M1_TASK_ADDR.CITY M1_TASK_ADDR.COUNTY M1_TASK_ADDR.STATE M1_TASK_ADDR.POSTAL M1_TASK_ADDR.COUNTRY | This natural key is the concatenation of all address attributes, in uppercase. |
Attributes | |||
ADDR_LINE1 | Address Line 1 | M1_TASK_ADDR.ADDRESS1 | |
ADDR_LINE2 | Address Line 2 | M1_TASK_ADDR.ADDRESS2 | |
ADDR_LINE3 | Address Line 3 | M1_TASK_ADDR.ADDRESS3 | |
ADDR_LINE4 | Address Line 4 | M1_TASK_ADDR.ADDRESS4 | |
ADDR_INFO | Address Information | M1_TASK_ADDR.ADDRESS1 M1_TASK_ADDR.CITY M1_TASK_ADDR.STATE M1_TASK_ADDR.POSTAL | This field is populated from the Task Address table based on the concatenation of the address, city, state, and postal code. |
CITY | City | M1_TASK_ADDR.UPPER(CITY) | |
COUNTY | County | M1_TASK_ADDR.COUNTY | |
POSTAL | Postal Code | M1_TASK_ADDR.POSTAL | |
STATE_DESCR | State Description | CI_STATE_L.DESCR | |
COUNTRY_DESCR | Country Description | CI_COUNTRY_L.DESCR | |
CROSS_STREET | Cross Street | M1_TASK_ADDR.CROSS_STREET | |
SUBURB | Suburb | M1_TASK_ADDR.SUBURB | |
STATE_CD | State Code | M1_TASK_ADDR.STATE | |
COUNTRY_CD | Country Code | M1_TASK_ADDR.COUNTRY | |
GEO_CODE | Geographical Code | ||
User Defined Attributes | |||
UDF1_CD | City Code | M1_TASK_ADDR.UPPER(CITY) | |
UDF1_DESCR | City Description | M1_TASK_ADDR.UPPER(CITY) | |
UDF2_CD | County Code | M1_TASK_ADDR.COUNTY | |
UDF2_DESCR | County Description | M1_TASK_ADDR.COUNTY | |
UDF3_CD | Postal Code | M1_TASK_ADDR.POSTAL | |
UDF3_DESCR | Postal Code | M1_TASK_ADDR.POSTAL | |
UDF4_CD | State Code | M1_TASK_ADDR.STATE | |
UDF4_DESCR | State Description | CI_STATE_L.DESCR | |
UDF5_CD | Country Code | M1_TASK_ADDR.COUNTRY | |
UDF5_DESCR | Country Description | CI_COUNTRY_L.DESCR | |
UDF6_CD | Geo Code Value | ||
UDF6_DESCR | Geo Code | ||
UDF7_CD | Premise Char 1 Code | ||
UDF7_DESCR | Premise Char 1 | ||
UDF8_CD | Premise Char 2 Code | ||
UDF8_DESCR | Premise Char 2 | ||
UDF9_CD | Premise Char 3 Code | ||
UDF9_DESCR | Premise Char 3 | ||
UDF10_CD | Premise Char 4 Code | ||
UDF10_DESCR | Premise Char 4 Code | ||
UDF11_CD | User Defined Field 11 Code | ||
UDF11_DESCR | User Defined Field 11 Description | ||
UDF12_CD | User Defined Field 12 Code | ||
UDF12_DESCR | User Defined Field 12 Description | ||
UDF13_CD | User Defined Field 13 Code | ||
UDF13_DESCR | User Defined Field 13 Description | ||
UDF14_CD | User Defined Field 14 Code | ||
UDF14_DESCR | User Defined Field 14 Description | ||
UDF15_CD | User Defined Field 15 Code | ||
UDF15_DESCR | User Defined Field 15 Description | ||
UDF16_CD | User Defined Field 16 Code | ||
UDF16_DESCR | User Defined Field 16 Description | ||
UDF1_NUM | User Defined Field 1 Number | ||
UDF2_NUM | User Defined Field 2 Number | ||
UDF3_NUM | User Defined Field 3 Number | ||
UDF4_NUM | User Defined Field 4 Number | ||
UDF5_NUM | User Defined Field 5 Number | ||
UDF6_NUM | User Defined Field 6 Number | ||
UDF7_NUM | User Defined Field 7 Number | ||
UDF8_NUM | User Defined Field 8 Number | ||
UDF9_NUM | User Defined Field 9 Number | ||
UDF10_NUM | User Defined Field 10 Number | ||
UDF1_DATE | User Defined Field 1 Date | ||
UDF2_DATE | User Defined Field 2 Date | ||
UDF3_DATE | User Defined Field 3 Date | ||
UDF4_DATE | User Defined Field 4 Date | ||
UDF5_DATE | User Defined Field 5 Date | ||
UDF6_DATE | User Defined Field 6 Date | ||
UDF7_DATE | User Defined Field 7 Date | ||
UDF8_DATE | User Defined Field 8 Date | ||
UDF9_DATE | User Defined Field 9 Date | ||
UDF10_DATE | User Defined Field 10 Date | ||
FLEXFIELD1 | Flex Field 1 | ||
FLEXFIELD2 | Flex Field 2 | ||
FLEXFIELD3 | Flex Field 3 | ||
FLEXFIELD4 | Flex Field 4 | ||
FLEXFIELD5 | Flex Field 5 | ||
FLEXFIELD6 | Flex Field 6 | ||
FLEXFIELD7 | Flex Field 7 | ||
FLEXFIELD8 | Flex Field 8 | ||
FLEXFIELD9 | Flex Field 9 | ||
FLEXFIELD10 | Flex Field 10 | ||
Data Load Attributes | |||
EFF_END_DTTM | Effective End Date/Time | ||
EFF_START_DTTM | Effective Start Date/Time | ||
DATA_LOAD_DTTM | Data Load Date/Time | This field is populated with the load timestamp value. | |
DATA_SOURCE_IND | Data Source Indicator | CI_INSTALLATION.ENV_ID | This field is populated with the DSI value on the source product instance configuration. The table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system. |
JOB_NBR | Job Number | This field is populated with the ODI job execution session number. | |
Surrogate Key | |||
Natural Keys | |||
SRC_ADDR_ID | Premise ID | M1_LOCATION.ADDRESS1 M1_LOCATION.ADDRESS2 M1_LOCATION.ADDRESS3 M1_LOCATION.ADDRESS4 M1_LOCATION.CROSS_STREET M1_LOCATION.SUBURB M1_LOCATION.CITY M1_LOCATION.COUNTY M1_LOCATION.STATE M1_LOCATION.POSTAL M1_LOCATION.COUNTRY | This natural key is the concatenation of all address attributes, in uppercase. |
Attributes | |||
ADDR_LINE1 | Address Line 1 | M1_LOCATION.ADDRESS1 | |
ADDR_LINE2 | Address Line 2 | M1_LOCATION.ADDRESS2 | |
ADDR_LINE3 | Address Line 3 | M1_LOCATION.ADDRESS3 | |
ADDR_LINE4 | Address Line 4 | M1_LOCATION.ADDRESS4 | |
ADDR_INFO | Address Information | M1_LOCATION.ADDRESS1 M1_LOCATION.CITY M1_LOCATION.STATE M1_LOCATION.POSTAL | This field is populated from the Location table based on the concatenation of the address, city, state, and postal code. |
CITY | City | M1_LOCATION.UPPER(CITY) | |
COUNTY | County | M1_LOCATION.COUNTY | |
POSTAL | Postal Code | M1_LOCATION.POSTAL | |
CROSS_STREET | Cross Street | M1_LOCATION.CROSS_STREET | |
SUBURB | Suburb | M1_LOCATION.SUBURB | |
STATE_CD | State Code | M1_LOCATION.STATE | |
COUNTRY_CD | Country Code | M1_LOCATION.COUNTRY | |
UDF1_CD | City Code | M1_LOCATION.UPPER(CITY) | |
UDF1_DESCR | City Description | M1_LOCATION.UPPER(CITY) | |
UDF2_CD | County Code | M1_LOCATION.COUNTY | |
UDF2_DESCR | County Description | M1_LOCATION.COUNTY | |
UDF3_CD | Postal Code | M1_LOCATION.POSTAL | |
UDF3_DESCR | Postal Code | M1_LOCATION.POSTAL | |
UDF4_CD | State Code | M1_LOCATION.STATE | |
UDF5_CD | Country Code | M1_LOCATION.COUNTRY | |
Surrogate Key | |||
Natural Keys | |||
SRC_ADDR_ID | Premise ID | M1_POU.ADDRESS1 M1_POU.ADDRESS2 M1_POU.ADDRESS3 M1_POU.ADDRESS4 M1_POU.CROSS_STREET M1_POU.SUBURB M1_POU.CITY M1_POU.COUNTY M1_POU.STATE M1_POU.POSTAL M1_POU.COUNTRY | This natural key is the concatenation of all address attributes, in uppercase. |
Attributes | |||
ADDR_LINE1 | Address Line 1 | M1_POU.ADDRESS1 | |
ADDR_LINE2 | Address Line 2 | M1_POU.ADDRESS2 | |
ADDR_LINE3 | Address Line 3 | M1_POU.ADDRESS3 | |
ADDR_LINE4 | Address Line 4 | M1_POU.ADDRESS4 | |
ADDR_INFO | Address Information | M1_POU.ADDRESS1 M1_POU.CITY M1_POU.STATE M1_POU.POSTAL | This field is populated from the POU table based on the concatenation of the address, city, state, and postal code. |
CITY | City | M1_POU.UPPER(CITY) | |
COUNTY | County | M1_POU.COUNTY | |
POSTAL | Postal Code | M1_POU.POSTAL | |
CROSS_STREET | Cross Street | M1_POU.CROSS_STREET | |
SUBURB | Suburb | M1_POU.SUBURB | |
STATE_CD | State Code | M1_POU.STATE | |
COUNTRY_CD | Country Code | M1_POU.COUNTRY | |
UDF1_CD | City Code | M1_POU.UPPER(CITY) | |
UDF1_DESCR | City Description | M1_POU.UPPER(CITY) | |
UDF2_CD | County Code | M1_POU.COUNTY | |
UDF2_DESCR | County Description | M1_POU.COUNTY | |
UDF3_CD | Postal Code | M1_POU.POSTAL | |
UDF3_DESCR | Postal Code Description | M1_POU.POSTAL | |
UDF4_CD | State Code | M1_POU.STATE | |
UDF5_CD | Country Code | M1_POU.COUNTRY | |
Surrogate Key | |||
Natural Keys | |||
SRC_ADDR_ID | Premise ID | M1_RESRC.BO_DATA_ AREA | This natural key is the concatenation of all address attributes, in uppercase. |
Attributes | |||
ADDR_LINE1 | Address Line 1 | M1_RESRC.BO_DATA_ AREA | |
ADDR_LINE2 | Address Line 2 | M1_RESRC.BO_DATA_ AREA | |
ADDR_LINE3 | Address Line 3 | M1_RESRC.BO_DATA_ AREA | |
ADDR_LINE4 | Address Line 4 | M1_RESRC.BO_DATA_ AREA | |
ADDR_INFO | Address Information | M1_RESRC.BO_DATA_ AREA | This field is populated from the Task Address table based on the concatenation of the address, city, state, and postal code. |
CITY | City | M1_RESRC.BO_DATA_ AREA | |
COUNTY | County | M1_RESRC.BO_DATA_ AREA | |
POSTAL | Postal Code | M1_RESRC.BO_DATA_ AREA | |
CROSS_STREET | Cross Street | M1_RESRC.BO_DATA_ AREA | |
SUBURB | Suburb | M1_RESRC.BO_DATA_ AREA | |
STATE_CD | State Code | M1_RESRC.BO_DATA_ AREA | |
COUNTRY_CD | Country Code | M1_RESRC.BO_DATA_ AREA | |
UDF1_CD | City Code | M1_RESRC.BO_DATA_ AREA | |
UDF1_DESCR | City Description | M1_RESRC.BO_DATA_ AREA | |
UDF2_CD | County Code | M1_RESRC.BO_DATA_ AREA | |
UDF2_DESCR | County Description | M1_RESRC.BO_DATA_ AREA | |
UDF3_CD | Postal Code | M1_RESRC.BO_DATA_ AREA | |
UDF3_DESCR | Postal Code Description | M1_RESRC.BO_DATA_ AREA | |
UDF4_CD | State Code | M1_RESRC.BO_DATA_ AREA | |
UDF4_DESCR | State Description | CI_COUNTRY_L.DESCR | |
UDF6_DESCR | Geo Code Description | ||
UDF7_DESCR | Premise Char 1 Description | ||
UDF8_DESCR | Premise Char 2 Description | ||
UDF9_DESCR | Premise Char 3 Description | ||
UDF10_DESCR | Premise Char 4 Description | ||
Property | Value |
Target Table | CD_CREW |
SCD Type | Type 2 |
Source System Driver Table | M1_RESRC M1_RESRC_TYPE M1_HIERARCHY |
Stage Table | STG_CD_CREW |
ODI Package | B1_PKG_CD_CREW |
ETL View | B1_D_CREW_VW |
Surrogate Key | |||
CREW_KEY | Crew Dimension Surrogate Key | This field is populated from the SPL_CREW_SEQ sequence. | |
Natural Keys | |||
SRC_CREW_ID | Crew ID | M1_RESRC.RESRC_ID | |
Attributes | |||
CREW_DESCR | Crew Description | M1_RESRC_ID.RESRC_ID_VAL | |
CREW_TYPE_DESCR | Crew Type Description | M1_RESRC_TYPE_L.DESCR | |
CREW_CD | Crew Code | Note: This field is populated only for the Oracle Utilities Network Management System source product. | |
CREW_TYPE_CD | Crew Type Code | M1_RESRC.RESRC_TYPE_CD | |
ORG_UNIT1_CD | Crew Hierarchy-1 Code | M1_HIER_UPSTREAM.M1_PARENT_HIER_CD | This field is populated from the Hierarchy Upstream table based on the hierarchy and hierarchy level. Note: The hierarchy is based on the reporting hierarchy stored on the crew’s characteristic (where characteristic type is Crew Hierarchy ‘M1CRHIER’) and for which the hierarchy level is Level 1 (‘M101’). |
ORG_UNIT2_CD | Crew Hierarchy-2 Code | M1_HIER_UPSTREAM.M1_PARENT_HIER_CD | This field is populated from the Hierarchy Upstream table based on the hierarchy and hierarchy level. Note: The hierarchy is based on the reporting hierarchy stored on the crew’s characteristic (where characteristic type is Crew Hierarchy ‘M1CRHIER’) and for which the hierarchy level is Level 1 (‘M102’). |
ORG_UNIT3_CD | Crew Hierarchy-3 Code | M1_HIER_UPSTREAM.M1_PARENT_HIER_CD | This field is populated from the Hierarchy Upstream table based on the hierarchy and hierarchy level. Note: The hierarchy is based on the reporting hierarchy stored on the crew’s characteristic (where characteristic type is Crew Hierarchy ‘M1CRHIER’) and for which the hierarchy level is Level 1 (‘M103’). |
ORG_UNIT1_DESCR | Crew Hierarchy-1 Description | M1_HIERARCHY_L.DESCR | This field is populated from the hierarchy description based on the parent hierarchy code and language configured. Note: To retrieve the parent hierarchy code, see the transformation logic of the ORG_UNIT1_CD column. |
ORG_UNIT2_DESCR | Crew Hierarchy-2 Description | M1_HIERARCHY_L.DESCR | This field is populated from the hierarchy description based on the parent hierarchy code and language configured. Note: To retrieve the parent hierarchy code, see the transformation logic of the ORG_UNIT2_CD column. |
ORG_UNIT3_DESCR | Crew Hierarchy-3 Description | M1_HIERARCHY_L.DESCR | This field is populated from the hierarchy description based on the parent hierarchy code and language configured. Note: To retrieve the parent hierarchy code, see the transformation logic of the ORG_UNIT3_CD column. |
UDF1_CD | User Defined Field 1 Code | ||
UDF1_DESCR | User Defined Field 1 Description | ||
UDF2_CD | User Defined Field 2 Code | ||
UDF2_DESCR | User Defined Field 2 Description | ||
UDF3_CD | User Defined Field 3 Code | ||
UDF3_DESCR | User Defined Field 3 Description | ||
UDF4_CD | User Defined Field 4 Code | ||
UDF4_DESCR | User Defined Field 4 Description | ||
UDF5_CD | User Defined Field 5 Code | ||
UDF5_DESCR | User Defined Field 5 Description | ||
UDF6_CD | User Defined Field 6 Code | ||
UDF6_DESCR | User Defined Field 6 Description | ||
UDF7_CD | User Defined Field 7Code | ||
UDF7_DESCR | User Defined Field 7 Description | ||
UDF8_CD | User Defined Field 8 Code | ||
UDF8_DESCR | User Defined Field 8 Description | ||
UDF9_CD | User Defined Field 9 Code | ||
UDF9_DESCR | User Defined Field 9 Description | ||
UDF10_CD | User Defined Field 10 Code | ||
UDF10_DESCR | User Defined Field 10 Description | ||
