Target Field | Description |
Surrogate Key | |
<Fact_name_prefix>_UDDn_KEY For example: The surrogate key for Asset Location UDD is ASSET_LOC_UDD1_KEY | <Fact name> User Defined Dimension n Dimension Surrogate Key For example: Asset Location User Defined Dimension 1 Dimension Surrogate Key |
Natural Keys | |
UDD1_CD | User Defined Dimension 1 Code |
Attributes | |
UDD1_DESCR | User Defined Dimension 1 Description |
User Defined Attributes | |
UDF1_CD | User Defined Field 1 Code |
UDF1_DESCR | User Defined Field 1 Description |
UDF2_CD | User Defined Field 2 Code |
UDF2_DESCR | User Defined Field 2 Description |
UDF3_CD | User Defined Field 3 Code |
UDF3_DESCR | User Defined Field 3 Description |
UDF4_CD | User Defined Field 4 Code |
UDF4_DESCR | User Defined Field 4 Description |
UDF5_CD | User Defined Field 5 Code |
UDF5_DESCR | User Defined Field 5 Description |
UDF6_CD | User Defined Field 6 Code |
UDF6_DESCR | User Defined Field 6 Description |
UDF7_CD | User Defined Field 7 Code |
UDF7_DESCR | User Defined Field 7 Description |
UDF8_CD | User Defined Field 8 Code |
UDF8_DESCR | User Defined Field 8 Description |
UDF9_CD | User Defined Field 9 Code |
UDF9_DESCR | User Defined Field 9 Description |
UDF10_CD | User Defined Field 10 Code |
UDF10_DESCR | User Defined Field 10 Description |
UDF11_CD | User Defined Field 11 Code |
UDF11_DESCR | User Defined Field 11 Description |
UDF12_CD | User Defined Field 12 Code |
UDF12_DESCR | User Defined Field 12 Description |
UDF13_CD | User Defined Field 13 Code |
UDF13_DESCR | User Defined Field 13 Description |
UDF14_CD | User Defined Field 14 Code |
UDF14_DESCR | User Defined Field 14 Description |
UDF15_CD | User Defined Field 15 Code |
UDF15_DESCR | User Defined Field 15 Description |
UDF16_CD | User Defined Field 16 Code |
UDF16_DESCR | User Defined Field 16 Description |
UDF17_CD | User Defined Field 17 Code |
UDF17_DESCR | User Defined Field 17 Description |
UDF18_CD | User Defined Field 18 Code |
UDF18_DESCR | User Defined Field 18 Description |
UDF19_CD | User Defined Field 19 Code |
UDF19_DESCR | User Defined Field 19 Description |
UDF20_CD | User Defined Field 20 Code |
UDF20_DESCR | User Defined Field 20 Description |
UDF21_CD | User Defined Field 21 Code |
UDF21_DESCR | User Defined Field 21 Description |
UDF22_CD | User Defined Field 22 Code |
UDF22_DESCR | User Defined Field 22 Description |
UDF23_CD | User Defined Field 23 Code |
UDF23_DESCR | User Defined Field 23 Description |
UDF24_CD | User Defined Field 24 Code |
UDF24_DESCR | User Defined Field 24 Description |
UDF25_CD | User Defined Field 25 Code |
UDF25_DESCR | User Defined Field 25 Description |
UDF26_CD | User Defined Field 26 Code |
UDF26_DESCR | User Defined Field 26 Description |
UDF27_CD | User Defined Field 27 Code |
UDF27_DESCR | User Defined Field 27 Description |
UDF28_CD | User Defined Field 28 Code |
UDF28_DESCR | User Defined Field 28 Description |
UDF29_CD | User Defined Field 29 Code |
UDF29_DESCR | User Defined Field 29 Description |
UDF30_CD | User Defined Field 30 Code |
UDF30_DESCR | User Defined Field 30 Description |
UDF31_CD | User Defined Field 31 Code |
UDF31_DESCR | User Defined Field 31 Description |
UDF32_CD | User Defined Field 32 Code |
UDF32_DESCR | User Defined Field 32 Description |
UDF33_CD | User Defined Field 33 Code |
UDF33_DESCR | User Defined Field 33 Description |
UDF34_CD | User Defined Field 34 Code |
UDF34_DESCR | User Defined Field 34 Description |
UDF35_CD | User Defined Field 35 Code |
UDF35_DESCR | User Defined Field 35 Description |
UDF36_CD | User Defined Field 36 Code |
UDF36_DESCR | User Defined Field 36 Description |
UDF37_CD | User Defined Field 37 Code |
UDF37_DESCR | User Defined Field 37 Description |
UDF38_CD | User Defined Field 38 Code |
UDF38_DESCR | User Defined Field 38 Description |
UDF39_CD | User Defined Field 39 Code |
UDF39_DESCR | User Defined Field 39 Description |
UDF40_CD | User Defined Field 40 Code |
UDF40_DESCR | User Defined Field 40 Description |
UDF41_CD | User Defined Field 41 Code |
UDF41_DESCR | User Defined Field 41 Description |
UDF42_CD | User Defined Field 42 Code |
UDF42_DESCR | User Defined Field 42 Description |
UDF43_CD | User Defined Field 43 Code |
UDF43_DESCR | User Defined Field 43 Description |
UDF44_CD | User Defined Field 44 Code |
UDF44_DESCR | User Defined Field 44 Description |
UDF45_CD | User Defined Field 45 Code |
UDF45_DESCR | User Defined Field 45 Description |
UDF46_CD | User Defined Field 46 Code |
UDF46_DESCR | User Defined Field 46 Description |
UDF47_CD | User Defined Field 47 Code |
UDF47_DESCR | User Defined Field 47 Description |
UDF48_CD | User Defined Field 48 Code |
UDF48_DESCR | User Defined Field 48 Description |
UDF49_CD | User Defined Field 49 Code |
UDF49_DESCR | User Defined Field 49 Description |
UDF50_CD | User Defined Field 50 Code |
UDF50_DESCR | User Defined Field 50 Description |
COMMENT1 | Comment 1 |
COMMENT2 | Comment 2 |
COMMENT3 | Comment 3 |
COMMENT4 | Comment 4 |
COMMENT5 | Comment 5 |
Data Load Attributes | |
EFF_START_DTTM | Effective Start Date/Time |
EFF_END_DTTM | Effective End Date/Time |
DATA_LOAD_DTTM | Data Load Date/Time |
DATA_SOURCE_IND | Data Source Indicator |
JOB_NBR | Job Number |
Property | Value |
Target Table | CD_ASSET_LOC_UDD1 |
Table Type | Dimension |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_ASSET_LOC_UDD2 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_OPR_DEVICE_UDD1 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_OPR_DEVICE_UDD2 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_OPR_DEVICE_SNAP_UDD1 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_OPR_DEVICE_SNAP_UDD2 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_SERVICE_HIST_UDD1 |
SCD Type | Type 2 |
Property | Value |
Target Table | CD_SERVICE_HIST_UDD2 |
SCD Type | Type 2 |
