Bug Fixes
The following bugs from previous Oracle Utilities Analytics Warehouse releases have been fixed in V2.8.0.2.0:
Bug Number
Description
36043358
Staging tables not being purged after X days
35884899
CF_OUTG_HIST initial load failing with UK constraint violation
35570111
CF_SERVICE_HIST job going into error as Crew_ID is not a key
35469626
Issue with CD_USER mapping
35121200
CD_EVENT is not updating OUAW when users update NMS data after the event is loaded into OUAW
34896707
ODI job B1_PKG_CF_DEVICE_EVT is stuck in step update US_ID_CCB in DWSTAGE.B1_F_DEVICE_EVT_AGG
36093831
Time zone changes for OUAW 2.8.0.2 codeline
36097751
Provision of MERGED_EVENTS table from NMS versions starting 2.6.0.0 in OUAW replication
Refer to the product fix design documents provided in the Oracle Utilities Analytics Warehouse v2.8.0.2 PFDs.zip file for detailed information about the respective bugs.
Important! Please note that the “Oracle Utilities Analytics Warehouse v2.8.0.2 PFDs.zip” file is part of the Oracle Utilities Analytics Warehouse Documentation 2.8.0.2.0 package.
You can view the product fix design documents in either of the following ways:
• In a browser by using the HTML-based files.
a. Copy the “css”, “html”, “images”, and “bug-pfds-2.8.0.2.0.html” files to a local directory.
b. Select and open the “bug-pfds-2.8.0.2.0.html” file to access the Home page.
You can view the list of bugs and the respective links to the product fix design documents.
• Using the bug-pfds-2.8.0.2.0.csv file. Import the content of the csv file. It contains one row for each bug, and each column contains the same fields that are shown in the HTML-based files.
