Upgrade OUAW Components
This page details how to upgrade the database, ETL, admin tool, and dashboard components for Oracle Utilities Analytics Warehouse v2.9.0.0.0.
On this page:
Upgrade the Database Component
This section details the steps to upgrade the Oracle Utilities Analytics Warehouse database component.
Copy and Decompress the Install Media
Download Oracle Utilities Analytics Warehouse v2.9.0.0.0. Oracle Database part file (Oracle Utilities Analytics v2.9.0.0.0. Oracle Database Multiplatform.zip) from Oracle Software Delivery Cloud onto the target database server.
Create a temporary directory (example: </OUA/temp> for a Linux machine). This directory (referred to as <TEMPDIR> below) must be located outside any current working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
Unzip Oracle Utilities Analytics Warehouse v2.9.0.0.0. Oracle Database Multiplatform.zip to <TEMPDIR> using any zip utility.
Execute the SQL below before installing the RELADM, MDADM, and DWADM Schemas. This provides the required permissions to the users created.
Copy
Usersgrants.sql in <TEMPDIR>/BI2900/Scripts/Usersgrants.sql
Install the RELADM Schema
Log in to the target database server.
Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v2.9.0.0.0. Oracle Database Multiplatform zip file was extracted.
Copy
cd database/BI2900/RELADM/Install-Upgrade
- Review Storage.xml to ensure the RELADM user has quota on the mentioned tablespace in file. If not, edit the file with correct tablespace name.
- Add JAVA_HOME/bin to the PATH variable.
Set CLASSPATH pointing to the location where OraDBI.jar and all dependency jars exist.
Copy
export CLASSPATH=<TEMPDIR>/BI2900/RELADM/Jarfiles/*
Execute the command below. Once complete, the utility creates the RELADM schema and system data definitions.
Copy
java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,RELADM,<Password of RELADM User>,,,,,RELADM -l 1,2 -o -q true
Note: If an error occurs while executing a SQL or another utility, it logs and displays the error message and allows you to re-execute the current step.
To generate database statistics after connecting to sys user, run the statement below:
Copy
exec DBMS_STATS.GATHER_SCHEMA_STATS('RELADM')
Install the MDADM Schema
Copy
cd database/BI2900/MDADM/Install-Upgrade
- Review Storage.xml to ensure the MDADM user has quota on the mentioned tablespace in file. If not, edit the file with correct tablespace name.
Copy
export CLASSPATH=<TEMPDIR>/BI2900/MDADM/Jarfiles/*
Execute the command below. When completed, the utility creates the MDADM schema and system data definitions.
Copy
java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,MDADM,<Password of MDADM User>,,,,,MDADM -l 1,2 -o -q true
Copy
exec DBMS_STATS.GATHER_SCHEMA_STATS('MDADM');
Install the DWADM Schema
- Navigate to the temporary directory into which the Oracle Utilities Analytics Warehouse v2.9.0.0.0 Oracle Database Multiplatform.zip file was extracted.
Copy
cd database/BI2900/DWADM/Install-Upgrade
Review Storage.xml to ensure the DWADM user has quota on mentioned tablespace in file. If not, edit the file with correct tablespace name.
Copyexport CLASSPATH=<TEMPDIR>/BI2900/DWADM/Jarfiles/*
Execute the command below. When completed, the utility creates the DWADM schema and system data definitions.
Copy
java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DATABASE SERVER>:<DATABASE PORT>/<ORACLE SERVICENAME>,DWADM,<Password of DWADM User>,DWUSER,DWREAD,DW_USER,DW_READ,DWADM -p <Password of DWUSER>,<Password of DWREAD> -l 1,2 -o -q true
Note: If an error occurs while executing a SQL or another utility, it logs and displays the error message, allowing you to re-execute the current step.
Copy
exec DBMS_STATS.GATHER_SCHEMA_STATS('DWADM');
Upgrade the ETL Component
Prerequisites
Before installing the OUAW ETL component, verify the following:
Use the same operating system user used to install the required software.
Ensure Oracle GoldenGate Microservices is installed on the target database server.
Ensure that Oracle GoldenGate Microservices Manager, Admin, and Receiver Services are running on the target database server.
Ensure latest Java version (Example: 1.8.411) is installed on the application server.
Ensure Oracle Fusion Middleware Infrastructure 12.2.1.4 installation and patches are applied on the target application server.
Ensure Oracle Data Integrator (ODI) 12.2.1.4 and patches are applied on the target application server.
Ensure ODI domain admin and managed servers are in stopped state.
Purge all the ODI operator logs.
Install the OUAW ETL Component
Log in to the application server.
Navigate to the temporary directory where the OUAW installer is downloaded.
Example: <TEMPDIR/application>.
Set the JAVA HOME and add PATH.
Copy
export JAVA_HOME=<JAVA HOME>
export PATH=$JAVA_HOME/bin:$PATH -
Launch the OUAW installer by running the command below. The OUAW installer Welcome page appears.
Copyjava -jar OUAW_2.9.0.0.0_ETL_generic.jar -logLevel finest
Note: For an AIX Operating System, set the following environment variable before starting the Oracle Utilities Analytics Warehouse installation:
Copyexport IBM_JAVA_OPTIONS="-Xmx2g -XX:PermSize=64m -XX:MaxPermSize=3200m"
Review the information before you begin the installation. Click Next to continue.
Note: If you are installing Oracle software on the server for the first time, provide central inventory details such as the inventory directory location and operating system group.
On the Installation Location page, define the installation location in the Oracle Home field and click Next.
Note: The specified Oracle home directory must be an empty directory.
Field Name and Description
Value
Oracle Home: The directory where the Oracle Utilities Analytics Warehouse ETL is going to be installed.
Note: This directory location is called the ETL Home. Keep track of it as it will be used during some deployment steps.
Example: <OUA ETL Home>
</u01/ouaw/OUAW_ETL>
On the Languages Selection page, select English and click Next.
Value
Language Selection: The language for the installation process.
English
On the Database and Java Home Details page, enter the details as in the table below, and click Next.
Value
Database Client Home: Enter the Oracle Database Client installed location or Database Home location in the case where the same server is being used for both the application and database server.
Example: <Database Client> or <ORACLE_HOME>
</u01/ouaw/dbclient> or </u01/ouawcicd/Database_base/Ora_home>
Java Home: Enter the Java installed location.
Example: <JAVA HOME>
</u01/ouaw/java/java>
On the Target Database Connection Details page, enter the following and click Next.
Value
Host: The target database server where database resides.
Target Database server host name.
Example: dbserver.hostname
Port: The target database server port number.
Target Database port.
Example: <1521>
Service Name: The target database service name.
<Database service name>
Target Schema Password: Password for the target schema (DWADM).
<DWADM user password>
Confirm Target Schema Password: Confirm password for the target schema (DWADM).
Target Schema Password: Password for the metadata schema (MDADM).
<MDADM user password>
Confirm Target Schema Password: Confirm password for the metadata (MDADM) schema.
On the ODI Home and Schema Details page, enter the following and click Next.
Value
ODI Home: The directory where Oracle Data Integrator (ODI) is installed.
Location of FMW Home
Example: </u01/ouaw/weblogic>
Supervisor User: Name of the Oracle Data Integrator Supervisor.
SUPERVISOR
Supervisor Password: Enter the Supervisor Password and store it for future reference.
<Supervisor user password >
Confirm Supervisor Password: Enter same as Supervisor Password.
Master Repository Schema Name: Oracle Data Integrator master repository schema name.
OUA_MASTER
Master Repository Schema Password: Master Repository schema password.
<OUA_MASTER user password>
Confirm Master Repository Schema Password: Confirm password of the Oracle Data Integrator master repository schema.
Work Repository Schema Name: Oracle Data Integrator work repository schema name.
OUA_WORK
Work Repository Schema Password: Work Repository schema password.
<OUA_WORK user password>
Confirm Work Repository Schema Password: Confirm password of Oracle Data Integrator work repository schema.
On the Oracle Data Integrator Agent and Repository Details page, enter the details as in the table below and click Next.
Value
ODI Agent Host: The application server hostname where the ODI application server is installed.
Target APP Server Host
Example:
<appserver.hostname>
ODI Agent Port: Enter the port which is the Oracle Data Integrator WebLogic Managed Server port. Make sure that you use the same port while creating Oracle Data Integrator managed server.
Example: <11002>
On the Target GoldenGate Microservices Details page, enter the details as in the table below, and click Next.
Value
GoldenGate Host: Target Oracle GoldenGate Microservice Host.
Enter the Target database hostname where GoldenGate Microservices is installed.
Target database server host/Target GoldenGate Microservice Server Host
Example: <target.ggms.hostname> or <dbserver.hostname>
GoldenGate User: Enter the GoldenGate Microservices Admin user.
Example: <ggadmin>
GoldenGate Password: Enter the GoldenGate Microservices Admin user password.
Example: <ggadmin user password>
Confirm GoldenGate Password: Re-enter the GoldenGate Microservices Admin user password.
GoldenGate Admin Service Port: The Target Oracle GoldenGate Microservices Admin Service port which is running on the target database server host.
Example: <7861>
GoldenGate Target Security Client Wallet Password: Enter the Client Wallet Password on the target database server host.
<Client Wallet Password>
Confirm GoldenGate Target Security Client Wallet Password: Re-enter the Client Wallet Password on the target database server host.
Target Security Client Wallet Directory: Enter the Client Wallet directory path on the target database server host.
Note: OGG client wallet location is under "<OGG Deploy Home>/etc/ssl/" after OGG MS deployment.
You can find the exact Target GoldenGate Microservices client wallet location from <Target GoldenGate Microservices Deployment Home>/etc/conf/deploymentConfiguration.dat> file and search for the outbound section, you can find the client wallet location under the file: tag.
Example:
"outbound": {
"authMode": "client_server",
"wrl": "file:/u01/ouaw/goldengate_Deploy/etc/ssl/distclient/target_client_wallet",Here, the Target Security Client Wallet Directory is <u01/ouaw/goldengate_Deploy/etc/ssl/distclient/<target_client_wallet>>
GoldenGate Receiver Service Port: The Target Oracle GoldenGate Microservices Receiver Service port which is running on the target database server host.
Example: <7863>
On the Java Home Location page, enter the details as in the table below, and click Next.
Value
Java Home: Enter the Java installed location (on the Application server).
Example: </u01/ouaw/java>
On the Installation Summary page, a summary is displayed. Click the Install button to proceed.
On the Installation Complete page, note the displayed details and click Finish to close the installer wizard. The ETL is now installed.
Start ODI Admin and Managed servers.
Copynohup ./startWebLogic.sh > startWebLogic.log 2>&1 &
nohup ./startManagedWebLogic.sh <ODI_server1> > StartManagedWeblogic.log 2>&1 &
Upgrade the Administration Tool Component
Prerequisites
To remove the previously created Apex workspace from the database:
Connect to the target database as SYSTEM user.
Copy
export ORACLE_HOME=<ORACLE_HOME>
export ORACLE_SID=<DATABASE SERVICE NAME>
export PATH=$ORACLE_HOME/bin:$PATH
sqlplus system/<system user password>@<DATABASE SERVICE NAME>
Run the following PL/SQL procedure.
Copy
BEGIN
APEX_INSTANCE_ADMIN.REMOVE_WORKSPACE('OBIU_ADM');
END;
Make sure no workspace with “OBIU” exists in the database.
Copy
select WORKSPACE from APEX_WORKSPACES where WORKSPACE like '%OBIU%';
Note: No rows should be returned from this query.
- Start apex Admin and Managed server in case it did not start during the apex domain upgrade. Copy
nohup ./startManagedWebLogic.sh <apex_server1> > StartManagedWeblogic.log 2>&1 & - Remove ords.war and i.war apps from APEX WebLogic console.
- Log in to APEX WebLogic console.
- Navigate to Deployments > Control.
- Click Stop and select Force Stop Now.
- Click Yes.
- On the Configuration tab, click Lock and Edit.
- Under Deployments, select both i and ords.
- Click Delete.
- Confirm the deletion and click Activate Changes.
Uninstall the existing ords.war from the database by navigating to ords unzip location on the application server and executing the commands below.
Copy
cd </u01>/<ords>
java -jar ords.war uninstall
Note: Provide the necessary inputs for this command and use JDK1.8 to run it.
Download Apex 23.2 from Oracle and place it under a temporary directory in both the OUAW database and application servers.
Example: </u01/temp> -
Download ORDS 21.4.3 from Oracle and place it under a temporary directory in the application server.
Download the Admin tool (Oracle Utilities Analytics Warehouse v2.9.0.0.0 Multiplatform.zip) file from the edelivery and place it under a temporary directory in the OUAW database server.
Admin Tool Installation Steps
Log in to the target database server and navigate to the Apex extracted directory.
Example: cd </u01/ouaw/apex> -
Connect to the Oracle Utilities Analytics Warehouse Database with sys user and execute the following commands in order:
Copy
sqlplus sys/<sys user password>@<database service name> as sysdba
@apxrtins.sql <Tablespace name> <Tablespace name> <Temp Tablespace name> /i/
Example:
@apxrtins.sql <CISTS_01> <CISTS_01> <TEMP> /i/
- Set Apex Admin account and password. Execute the following:
Copy
@apxchpwd.sql
Run the following to install Apex for the first time:
Copy
EXEC DBMS_XDB.SETHTTPPORT(0);
SELECT DBMS_XDB.GETHTTPPORT FROM DUAL;
Note: This query should result in zero (0).
Run the following SQL:
Copy
ALTER USER APEX_PUBLIC_USER ACCOUNT UNLOCK;
ALTER USER APEX_PUBLIC_USER IDENTIFIED BY APEX_PUBLIC_USER;
@apex_rest_config.sqlNote: Make sure to note the password for these two users: APEX_LISTENER user and APEX_REST_PUBLIC_USER.
Configure APEX Workspace for OUAW
To import the Admin tool to configure Oracle Data Integrator:
Download and unzip the Oracle Utilities Analytics Warehouse v2.9.0.0.0 Multiplatform.zip file, which includes the AdminTool folder.
Copy the Multiplatform zip file into a temp directory within the target database server.
Navigate to the TEMP directory and connect to the database using the system user.
Copy
cd </u01/temp/AdminTool>
Install ORDS on the Application Server
- Navigate to the ORDS extracted directory on the application server and make sure that the APEX extracted directory is available in the location where the Admin tool is set up.
Example: </u01/ouaw/ords>
- Create a directory on the application server to configure Apex.
Example: mkdir -p </u01/ouaw/apex_configuration>
- Navigate back to the ords directory where Oracle REST Data source (ORDS) was extracted.
Example: cd </u01/ouaw/ords>
To perform an advanced installation, execute the following commands:
Copy
export JAVA_HOME=</u01/ouaw/java>
java -jar ords.war install advancedNote: Use JDK1.8 or a later version to run this command.
See below an example of the command prompt, in which default options will appear enclosed in square brackets []. Use these options, or provide the necessary inputs for your requirements.
Enter the location to store configuration data: </scratch/ouacicd/apex_configuration>
Specify the database connection type to use.
Enter number for [1] Basic [2] TNS [3] Custom URL [1]:
Enter the name of the database server [localhost]:<dbserver.hostname>
Enter the database listen port [1521]:<dbserver.port>
Enter 1 to specify the database service name, or 2 to specify the database SID [1]:
Enter the database service name:<database service name>
Enter 1 if you want to verify/install Oracle REST Data Services schema or 2 to skip this step [1]:
Enter the database password for ORDS_PUBLIC_USER:
Confirm password:
Requires to login with administrator privileges to verify Oracle REST Data Services schema.Enter the administrator username:sys
Enter the database password for SYS AS SYSDBA:
Confirm password:
Connecting to database user: SYS AS SYSDBA url: jdbc:oracle:thin:@//<dbserver.hostname>:1521/<database service name>Retrieving information.
Enter the default tablespace for ORDS_METADATA [SYSAUX]:
Enter the temporary tablespace for ORDS_METADATA [TEMP]:
Enter the default tablespace for ORDS_PUBLIC_USER [SYSAUX]:
Enter the temporary tablespace for ORDS_PUBLIC_USER [TEMP]:
Enter 1 if you want to use PL/SQL Gateway or 2 to skip this step.
If using Oracle Application Express or migrating from mod_plsql then you must enter 1 [1]:
Enter the PL/SQL Gateway database user name [APEX_PUBLIC_USER]:
Enter the database password for APEX_PUBLIC_USER:
Confirm password:
Enter 1 to specify passwords for Application Express RESTful Services database users (APEX_LISTENER, APEX_REST_PUBLIC_USER) or 2 to skip this step [1]:
Enter the database password for APEX_LISTENER:
Confirm password:
Enter the database password for APEX_REST_PUBLIC_USER:
Confirm password:
Enter a number to select a feature to enable:
[1] SQL Developer Web (Enables all features)
[2] REST Enabled SQL
[3] Database API
[4] REST Enabled SQL and Database API
[5] None
Choose [1]:
2024-04-08T16:43:47.300Z INFO reloaded pools: []
Installing Oracle REST Data Services version 21.4.3.r1170405
... Log file written to /scratch/gbuora/ords_install_core_2024-04-08_164347_00407.log
... Verified database prerequisites
... Created Oracle REST Data Services proxy user
... Created Oracle REST Data Services schema
... Granted privileges to Oracle REST Data Services
... Created Oracle REST Data Services database objects
... Log file written to /scratch/gbuora/ords_install_datamodel_2024-04-08_164359_00711.log
... Log file written to /scratch/gbuora/ords_install_apex_2024-04-08_164401_00030.log
Completed installation for Oracle REST Data Services version 21.4.3.r1170405.Elapsed time: 00:00:15.52
Enter 1 if you wish to start in standalone mode or 2 to exit [1]:2
Navigate to the ORDS directory.
Run the following command after setting JAVA HOME:
Copyjava -jar ords.war static </u01/ouaw/apex>/apex/images>
Note: The command above will create an i.war file in the ords folder.
Install the ords.war and i.war files
- Log in to <apex domain> WebLogic administration console and click the Lock & Edit button located in the Change Center.
- On the Domain Structure panel, select Deployments, then click Install.
- Enter the appropriate path and then select the
ords.war
file. Click Next.Example: </u01/ouaw/ords>
- Select the deployment target as <apex_server1>.
On the application assistant, populate the fields as detailed in the table below.
Value
Name: Enter the deployment name.
ords
Security: Select the security model to be used.
Select the Custom Roles option.
Source accessibility: Select the source accessibility option.
Select the Use the defaults defined by the deployment's targets option.
- The location of ords.war file and target will appear on the Summary section. Click Finish.
- After saving the ords.war deployment, click the Activate Changes button located in the Change Center.
Repeat the steps above to deploy the i.war file.
On the WebLogic administration console, navigate to Deployment and then Control.
Select i and ords.
Click Start and then Servicing All Requests.
Restart the administration and managed servers.
Access the AdminTool
Use this URL to access the administration tool:
http://<hostname>:<apex_server1_port>/ords/f?p=104
Provide the following credentials to access the Admintool:
Username: Admin
Password: Admin_123Note: After logging in to the application for the first time, you will be requested to change the password.
After logging in, you can access the ETL Configuration and ETL Job Execution through the respective tabs.
Change the Default Password of Admin User
This section describes the APEX API used to change the admin user's password.
The script below should be run after connecting to the database as user SYSTEM.
Note: Replace the string 'New password' with the new password for the admin account before running the script.
begin
wwv_flow_api.set_security_group_id(p_security_group_id=>nvl(wwv_flow_application_install.get_workspace_id,2090606133849294));
end;
begin
apex_util.edit_user(
p_user_id => '1467765078687596',
p_user_name => 'ADMIN',
p_web_password => 'New password',
p_new_password => 'New password'
end;
commit;
Note: It is strongly recommended to change the default password after logging in.
Upgrade the Dashboards Component
Prerequisites
Before you begin installing the OUAW Dashboards component, note the following:
A single OS user must install all required software.
All required software (such as Java, Oracle Database Client, Oracle Fusion Middleware, Oracle Analytics Server) must be installed.
Verify that the OUAW Dashboards Components are unzipped and available in the
<TEMPDIR>/application
directory on the application server.
Set Up the Dashboard Environment
- Log in to the application server.
- Create a Dashboard Home directory.
Example:
mkdir -p </u01/ouaw/deployment/OUAW_DASHBOARD>
Note: In the documentation, this directory location is referred to as Dashboards Home. Keep note of it because it will be used during some deployment steps.
- Copy catalog, WriteBackTemplates, and rpd folders from <TEMPDIR/application> to Dashboard Home folder. Copy
cp -rp <TEMPDIR>/application/<OAS Version>/* </u01/ouaw/deployment/OUAW_DASHBOARD>
Deploy the Web Catalog
On the Oracle Analytics Server, you can deploy the latest catalogs into the environment using the online mode.
Note: In case you want to take a backup of the deployed catalog, follow the OAS Doc ID 2724149.1 in My Oracle Support.
- Navigate to <DOMAIN DOMAIN>/<OAS_DOMAIN>/bitools/bin.
Create a new credentials file called boot.txt and add the following contents to it:
Copy
login=<OAS Weblogc admin user>
pwd=<OAS Weblogic admin password>For each catalog present under
<Dashboards Home>/catalog
directory, run the following command from the<OAS DOMAIN HOME>/bitools/bin
location. Replace all parameters enclosed in <> with the appropriate values.Copy./runcat.sh -cmd unarchive -folder "/shared" -online http://<OAS SERVER Host>:<OAS Managed SERVER PORT>/analytics-ws/saw.dll -credentials boot.txt -inputFile "<Dashboards Home>/Catalog/<Catalog Name>" -overwrite all
Note: The inputFile parameter must be in double quotes, and the catalog file name must include spaces.
Deploy the 'Spatial Metadata Catalog' on the System folder. Replace all parameters enclosed in <> with the appropriate values.
Copy
./runcat.sh -cmd unarchive -folder "/system" -online http://<OAS SERVER Host>:<OAS Managed SERVER PORT>/analytics-ws/saw.dll -credentials boot.txt -inputFile "<Dashboards Home>/catalog/Spatial Metadata.Catalog" -overwrite all
Note: The inputFile parameter must be in double quotes, and the catalog filename must include spaces.
Deploy the Merged RPD File
To merge the customized 2.8.0.2.0 RPD file with the 2.9.0.0.0 RPD, which contains the database changes required:
- Copy both 2.9.0.0.0 and 2.8.0.2.0 RPD files to the Windows machine where Oracle Analytics Client Tool 7.0 is installed, then merge it.
Note: RPD file merge steps can be found here: Merging Repositories
Once the RPD file merge is complete, copy the modified RPD back to the
<install dir>/rpd/UtilitiesBusinessAnalytics.rpd
, where<install_dir>
is the Oracle Utilities Analytics Warehouse Dashboard Component installation directory.
Upload the RPD File
Log in to the target application server where OAS is installed.
Navigate to <DOMAIN HOME>/<OAS DOMAIN>/bitools/bin.
Run the following command to deploy the RPD:
Copy./datamodel.sh uploadrpd -I <Dashboards Home>/rpd/UtilitiesBusinessAnalytics.rpd -W <rpd password, defaultpassword is oracle123> -U <Weblogic user name of OAS domain> -P <Weblogic password of OAS domain> -SI ssi
Run the following commands from the <OAS_DOMAIN>/bitools/bin directory to stop and start the OAS domain services respectively.
Copy
./stop.sh
./start.sh
Deploy Writeback Templates
Log in to the application server and run the following commands to deploy writeback templates:
Copy
cp -rp <Dashboards Home>/WriteBackTemplates/* <FMW Home>/bi/bifoundation/web/msgdb/l_en/custommessages/ -
Restart the Oracle Analytics Server services after deploying these writeback templates in the specified path.
Copy
cd <OAS DOMAIN>/bitools/bin
./stop.sh
./start.sh
Configure Spatial Data
Navigate to the temporary directory where the Oracle Utilities Analytics Warehouse v2.9.0.0 Oracle Database Multiplatform.zip file was extracted.
Copy
cd database/BI2900/Spatial-Metadata
Set the following environment variables.
Copy
export ORACLE_HOME=<ORACLE HOME>
Create the database directory in the database after connecting to sys user.
Copy
sqlplus sys/<sys user password>@<DATABASE SERVICE NAME>
CREATE DIRECTORY <dump_dir> AS '/u01/dumps'; -
Copy the user_sdo.dmp dumpfile from the temporary directory <TEMPDIR>/database/BI2900/Spatial-Metadata to the database directory <dump_dir> location.
Example: </u01/dumps>
Execute the impdp command to import the USER_SDO* tables data.
Copy
impdp directory=dump_dir dumpfile=user_sdo.dmp logfile=impdp_user_sdo.log schemas=DWADM remap_tablespace=cists_01:<tablespace_name>
Provide DWADM username password when prompted.
Note: Ensure to change the tablespace_name to the name on which DWADM has the quota. If DWADM user have quota on cists_01 tablespace, then exclude the whole remap_tablespace clause from the command.
- Review the impdp_user_sdo.log file to ensure the tables are imported successfully.
After importing the tables, run the following SQL scripts from the <TEMPDIR>/BI2900/Spatial-Metadata directory.
Copy
sqlplus dwadm/<dwadm user password>@<database service name>
@copy_spatial_metadata.sql
@clean_sdo_release_tbls.sql
Review the log files.
Post-Upgrade Steps
Run Post-Upgrade Steps
Note: Steps 1, 2, 9, 10, and 11 are only valid for the Oracle Utilities Network Management System (NMS) Source. Ignore these steps for Oracle Utilities Customer Care and Billing, Meter Data Management, Customer To Meter, and Work and Asset Management.
- Perform the steps below in accordance with the upgraded NMS version in ODI Studio.
Note: The following steps are only valid for the NMS source application.
- Navigate to Load Plans and Scenarios > Framework > Data correction.
- Right-click the B1_UPD_NMS_SCEN_FROM_260 scenario.
- Click Run.
- Set Context as "Global".
- Click OK.
- Right-click the B1_UPD_NMS_SCEN_FROM_2502_UNDER_260 scenario.
- Click Run.
- Click OK.
- Right-click the B1_UPD_NMS_SCEN_FROM_2401_UNDER_2502 scenario.
- Click Run.
- Click OK.
- Right-click the B1_UPD_NMS_SCEN_UNDER_2401 scenario.
- Click Run.
- Click OK.
- Rename the Account Dimension View scenario by performing the following steps:
- Navigate to Load Plans and Scenarios > Oracle Utilities BI > Shared > Dimensions > Account Dimension > Account Dimension Upto NMS 24013.
- On the Definition tab, double-click B1_NMS_D_ACCT_VW_UPTO_24013 Version 001 and rename it to B1_NMS_D_ACCT_VW Version 001.
- Click Save.
- Run the source configuration in REGISTER mode.
- Context Code should be same with old Context Code which was cleaned during GoldenGate Classic cleanup process
- Perform the source configuration as per the steps mentioned in Configure ETL Source for OUAW (except all steps from section Set Up Source Database Server for Oracle GoldenGate Microservices and step 1 from section Source Configuration Using OUAW Wizard).
- Make sure that all EXTRACT, REPLICAT, Distribution Paths are up and running. Lag at the Chkpt and Time Since Chkpt should be zero (0). This can be confirmed through the info after logging in to Source and Target OGG MS Administration server console and the Source Distribution Server console.
- Stop the GoldenGate Microservice REPLICAT processes in the target server.
Run B1_SYNC_CONTEXT Version 001 in ODI studio for the configured product context.
Start the GoldenGate Microservice REPLICAT processes in the target server.
Bring up the source application.
- Perform the following steps for Backfilling of Storm changes in the NMS Star Schema in accordance with the upgraded NMS version.
For NMS Versions 2.6.0.0 and Later:
- Navigate to ODI Designer > Load Plans and Scenarios > Framework > Data correction.
- Right-click B1_STORM_DATA_FIX_2802 Version 001.
- Click Run.
Note: Select the appropriate context. If multiple contexts are configured, execute for each context separately.
Disable all NMS facts and dimensions (including B1_BR_SW_PLAN_JOBS).
This can be ensured by checking that there is no record for any entity in B1_READY_VW view in MDADM schema:
Copyselect distinct entity_name from mdadm.b1_ready_vw;
- For Account Dimension (NMS) related changes, perform an incremental or complete load of the data FROM NMS_ACCOUNTS_HISTORY table into Account Dimension.
Option 1: Incremental Data Load
CD_ACCT dimension will load only the incremental data FROM NMS_ACCOUNTS_HISTORY table. The data which is already loaded in the dimension FROM CES_CUSTOMERS_HISTORY table will not be modified or updated and remains the same. The dependent facts will not be impacted while performing initial load.
Ensure the NMS_ACCOUNTS_HISTORY is present in replication layer with data.
Stop the GoldenGate REPLICAT.
Navigate to Load Plans and Scenarios > Oracle Utilities BI > Shared > Dimensions > Account Dimension to load all the initial and incremental data FROM CES_CUSTOMERS_HISTORY table into the dimension.
On the Definition tab, double-click B1_PKG_NMS_CD_ACCT_UPTO_24013 Version 001 and rename it to B1_PKG_NMS_CD_ACCT Version 001.
On the Definition tab, double-click B1_NMS_D_ACCT_VW_UPTO_24013 Version 001 and rename (if not already done) it to B1_NMS_D_ACCT_VW Version 001.
Click Save.
Run the View generation script for the configured NMS Context.
Enable the entity active flag for CD_ACCT dimension and B1_RUN_ALL to load the Account dimension. This loads data from CES_CUSTOMERS_HISTORY until latest checkpoint.
Ensure that the CD_ACCT dimension data loads are completed until the checkpoint date. The output of below queries should result in same date:
CopySELECT MAX (SLICE_END_DTTM) FROM MDADM.B1_JOBS_VW WHERE CONTEXT_CD= <NMS_context_code> AND ENTITY_NAME='CD_ACCT';
SELECT LAST_UPDATE_TS FROM MDADM.B1_CHECKPOINT WHERE GROUP_NAME LIKE 'NMS%';Revert the changes for scenario names for CD_ACCT dimension upon completion of the job loads by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
- On the Definition tab, double-click B1_PKG_NMS_CD_ACCT Version 001 and rename it to B1_PKG_NMS_CD_ACCT_UPTO_24013 Version 001.
On the Definition tab, double-click B1_NMS_D_ACCT_VW Version 001 and rename it to B1_NMS_D_ACCT_VW_UPTO_24013 Version 001.
- Click Save.
- Stop B1_RUN_ALL from ODI Studio.
- Start the GoldenGate REPLICAT.
- Load the incremental data into CD_ACCT dimension FROM NMS_ACCOUNTS_HISTORY table by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
- On the Definition tab, double-click B1_PKG_NMS_CD_ACCT_FROM_24013 Version 001 and rename it to B1_PKG_NMS_CD_ACCT Version 001.
- On the Definition tab, double-click B1_NMS_D_ACCT_VW_FROM_24013 Version 001 and rename it to B1_NMS_D_ACCT_VW Version 001.
- Click Save.
- Run the View generation for the Configured Context.
- Enable B1_RUN_ALL and load the Account dimension. At this point, the data is loaded from NMS_ACCOUNTS_HISTORY.
- Enable all other dimensions and facts, and perform incremental loads.
Option 2: Complete Data Load
CD_ACCT dimension will load the complete data FROM NMS_ACCOUNTS_HISTORY table. The data which is already loaded in the dimension FROM CES_CUSTOMERS_HISTORY table will be updated. All the dependent facts will also be updated with the latest ACCT_KEY values FROM CD_ACCT table. Once the loads are done, the older records in the account dimension (All the data loaded form CES_CUSTOMERS_HISTORY table) will be deleted.
- Stop B1_RUN_ALL from ODI studio. Run this query to ensure no ETL jobs are in the "Running" state:Copy
SELECT * FROM MDADM.B1_JOBS_VW WHERE STATUS_FLG in ('W','P', 'R');
Note: If there are entries found, wait for the jobs to finish.
- Ensure that the NMS_ACCOUNTS_HISTORY table is present and with data in the replication layer.
- Ensure the scenario names for the existing CD_ACCT NMS Dimension are renamed (if not already done) with suffix 'UPTO_24013' in ODI by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
- On the Definition tab, double-click B1_NMS_D_ACCT_VW Version 001 and rename it to B1_NMS_D_ACCT_VW_UPTO_24013 Version 001.
- Click Save.
- Rename the scenario name for the new CD_ACCT NMS Dimension by navigating to Load Plans and Scenarios > Oracle Utilities BI > Shared> Dimensions > Account Dimension.
- Click Save.
- Run the View generation for the Configured NMS Context.
- Run the B1_ACCT_DIM_UPD_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > B1_ACCT_DIM_UPD_28020.
- Enable the entity active flag of CD_ACCT dimension.
- Enable B1_RUN_ALL and load the Account dimension, where data is loaded from NMS_ACCOUNTS_HISTORY.
- Run the B1_F_ACCT_KEY_UPD_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > B1_F_ACCT_KEY_UPD_28020.
- Run the B1_ACCT_DIM_DEL_KEYS_28020 scenario for the configured NMS Context by navigating to Load Plans and Scenarios > Framework > Data Correction > B1_ACCT_DIM_DEL_KEYS_28020.
For NMS Versions after 2.5.0.2 and below 2.6.0.0:
For NMS Versions after 2.4.0.1 and below 2.5.0.2:
For NMS Versions below 2.4.0.1:
