Incremental Star Schema Load
Once GoldenGate change synchronization processes are enabled, incremental data from the source application will automatically start flowing into the replication schema for all configured tables. As ETL jobs and the scheduler are enabled, target star schema objects (for example, Dimensions, Facts, etc.) will also be loaded automatically. No manual activity is required to load the incremental data into the target schema. At this point, both ETL and Analytics need to be monitored at a regular interval of time for the smooth function of this product and can be open for the business users to access.
