Verifying Model Setup
After the initial sync process is complete:
1. Verify that the model is set up.
select *
from mdadm.b1_checkpoint
where group_name = 'CCB1AE';
If the record does not exist, it indicates that the Oracle GoldenGate scripts for CCB1AE model were not deployed.
2. Verify that the table data is in sync.
select *
from mdadm.b1_table_sync
where model_cd = 'CCB1AE';
select *
from ccb1rep.ci_acct_char;
If there is no entry it indicates that the B1_SYNC_CONTEXT scenario was not executed. Or, if it was executed, the Oracle GoldenGate scripts were not deployed at that time.
Important:
Enable all the replication tables required for customization and follow the steps mentioned in the Creating Replicated Tables and Executing Initial Sync sections.
Ensure that each model does not include more than 100 tables.
