Facts
Device Activity Fact
An activity is a record of a communication or event related to a device, measuring component, or another entity in the system. The Device Activity fact stores details about all activities in Oracle Utilities Meter Data Management system including their duration information.
Entity Relationship Diagram
Entity Relationship diagram of the Device Activity fact.
Properties
Property
Value
Target Table Name
CF_DEVICE_ACTIVITY
Table Type
Fact
Fact Type
Accumulation
Source System Driver Table
D1_ACTIVITY
D1_DVC_CFG
D1_INSTALL_EVT
D1_SP
D1_US
Stage Table Name
STG_CF_DEVICE_ACTIVITY
ODI Package Name
B1_PKG_CF_DEVICE_ACTIVITY
ETL View Name
B1_F_DEVICE_ACTIVITY_VW
Materialized View Name
B1_DEVICE_ACTIVITY_MON_MV1
B1_DEV_ACT_TOPX_MON_MV1
Fields
Target Field
Description
Source Field
Transformation Logic
Surrogate Key
DEVICE_ACTIVITY_KEY
Device Activity Key
This field is populated from the OUBI_DEVICE_ACTIVITY_SEQ sequence.
Natural Keys
SRC_DEVICE_ACTIVITY_ID
Device Activity ID
D1_ACTIVITY.D1_ACTIVITY_ID
Only those activities with activity type category in the list of activity type categories configured for inclusion via the extract parameters are extracted.
Measures
DURATION
Duration
D1_ACTIVITY.END_DTTM
D1_ACTIVITY.START_DTTM
This field is populated with the difference between end date/time and start date/time of the activity. For incomplete activities the current date/time is considered as the end date/time. The unit of measure is seconds.
FACT_CNT
Fact Count
This field is populated with the standard value of ‘1’.
Degenerate Dimensions
START_DTTM
Start Date/Time
This field is populated with the start date/time of the activity.
END_DTTM
End Date/Time
This field is populated with the end date/time of the activity.
Foreign Keys
DEVICE_ACTIVITY_
STATUS_KEY
Device Activity Status Dimension Surrogate Key
D1_ACTIVITY.D1_ACTIVITY.BUS_OBJ_CD
D1_ACTIVITY.D1_ACTIVITY.BO_STATUS_CD
D1_ACTIVITY.BO_STATUS_REASON_CD
This field is populated based on the device activity status.
MTR_DEVICE_KEY
Meter Device Dimension Surrogate Key
D1_ACTIVITY_REL_OBJ.PK_VALUE1
D1_DVC_CFG.D1_DEVICE_ID
This field is populated based on the device ID associated with the activity via its related object collection.
If there is no device ID associated with the activity, then the device ID is derived from the measuring component or service point associated with the activity.
MC_KEY
Measuring Component Dimension Surrogate Key
This field is populated based on the measuring component ID associated with the activity via its related object collection.
SPR1_KEY
Service Provider 1 Dimension Surrogate Key
D1_SP_MKT_PARTICIPANT.D1_SPR_CD
D1_MKT_FALLBACK_SPR.D1_SPR_CD
This field is populated based on the service point ID associated with the activity.
The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via the extract parameters.
SPR2_KEY
Service Provider 2 Dimension Surrogate Key
The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second one configured via the extract parameters.
SP_KEY
Service Point Dimension Surrogate Key
D1_INSTALL_EVT.D1_SP_ID
This field is populated based on the service point ID associated with the activity via its related object collection.
If there is no service point ID associated with the activity, then the service point ID is derived from the device associated with the activity.
ADDR_KEY
Address Dimension Surrogate Key
US1_KEY
Usage Subscription 1 Dimension Surrogate Key
D1_US_SP.US_ID
This field is populated based on the service point associated with the activity.
It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
Usage Subscription 2 Dimension Surrogate Key
D1_US_SP.US_ID
It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the second subscription type defined on the extract parameters.
USAGE_GROUP_KEY
Usage Group Dimension Surrogate Key
D1_US_USG_GRP_DL.USG_GRP_CD
This field is populated based on the usage group of the CCB-related usage subscription linked to the service point associated with the activity.
CONTACT_KEY
Contact Dimension Surrogate Key
D1_US_CONTACT.CONTACT_ID
This field is populated with the primary contact Id of the CCB-related usage subscription linked to the SP associated with the activity.
DEVICE_ACTIVITY_
TYPE_KEY
Device Activity Type Dimension Surrogate Key
D1_ACTIVITY.ACTIVITY_TYPE_CD
This field is populated based on the device activity type code associated with the activity.
START_DATE_KEY
Start Date (Date Dimension Surrogate Key)
This field is populated based on the activity start date.
START_TIME_KEY
Start Time Dimension Surrogate Key
This field is populated based on the activity start time.
END_DATE_KEY
End Date (Date Dimension Surrogate Key)
This field is populated based on the activity end date.
END_TIME_KEY
End Time (Time Dimension Surrogate Key)
This field is populated based on the activity end time.
PER_KEY
Person Dimension Surrogate Key
D1_CONTACT_IDENTIFIER.ID_VALUE
This field is populated based on the external person ID stored on the activity’s contact identifiers.
ACCT_KEY
Account Dimension Surrogate Key
D1_US_IDENTIFIER.ID_VALUE
This field is populated based on the external account ID stored on the activity’s CCB-related usage subscription’s identifiers.
SA_KEY
Service Agreement Dimension Surrogate Key
This field is populated based on the external service agreement ID stored on the activity’s CCB-related usage subscription’s identifiers.
PREM_KEY
Premise Dimension Surrogate Key
D1_SP_IDENTIFIER.ID_VALUE
This field is populated based on the external premise ID stored on the activity’s service point’s identifiers.
DEVICE_ACTIVITY_
UDD1_KEY
Device Activity User Defined Dimension 1 Surrogate Key
DEVICE_ACTIVITY_
UDD2_KEY
Device Activity User Defined Dimension 2 Surrogate Key
User Defined Attributes
UDM1
User Defined Measure 1
UDM2
User Defined Measure 2
UDM3
User Defined Measure 3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDFK1_KEY
User Defined Dimension Foreign Key 1
UDDFK2_KEY
User Defined Dimension Foreign Key 2
UDDFK3_KEY
User Defined Dimension Foreign Key 3
UDDFK4_KEY
User Defined Dimension Foreign Key 4
UDDFK5_KEY
User Defined Dimension Foreign Key 5
Data Load Attributes
DATA_SOURCE_IND
Data Source Indicator
CI_INSTALLATION.ENV_ID
This field is populated with the DSI value on the source product instance configuration. This table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system.
JOB_NBR
Job Number
This field is populated with the ODI job execution session number.
Device Event Fact
Device events are events of some sort that have taken place relative to a device, and can include power outages, power restorations, tampering alerts, command completions, and other events.
This fact stores details about all device events in the Oracle Utilities Meter Data Management system including their duration information.
Entity Relationship diagram of the Device Event fact.
Properties
Property
Value
Target Table Name
CF_DEVICE_EVT
Table Type
Fact
Fact Type
Accumulation
D1_DVC_EVT
D1_DVC_CFG
D1_INSTALL_EVT
D1_SP
D1_US
Stage Table Name
STG_CF_DEVICE_EVT
ODI Package Name
B1_PKG_CF_DEVICE_EVT
ETL View Name
B1_F_DEVICE_EVT_VW
B1_DEVICE_EVT_MON_MV1
B1_DEVICE_EVT_MON_TOPX_MV1
Fields
Target Field
Description
Source Field
Surrogate Key
DEVICE_EVT_KEY
Device Event Key
This field is populated from the OUBI_DEVICE_EVT_SEQ sequence.
Natural Keys
SRC_DEVICE_EVT_ID
Device Event ID
D1_DVC_EVT.DVC_EVT_ID
This field is populated with the primary keys of all device events from the Device Event table.
Only those device events whose business object codes are not present in the list of device event business objects to exclude as configured in the extract parameters are extracted.
Measures
DURATION
Duration
D1_DVC_EVT.DVC_EVT_END_DTTM
D1_DVC_EVT.DVC_EVT_DTTM
This field is populated with the difference between end date/time and start date/time of the device event.
For incomplete events the current date/time is considered as the end date/time. Unit of measure is seconds.
FACT_CNT
Fact Count
START_DTTM
Start Date/Time
END_DTTM
End Date/Time
Foreign Keys
DEVICE_EVT_STATUS_KEY
Device Event Status Dimension Surrogate Key
D1_DVC_EVT.D1_DVC_EVT.BUS_OBJ_CD
D1_DVC_EVT.D1_DVC_EVT.BO_STATUS_CD
D1_DVC_EVT.BO_STATUS_REASON_CD
This field is populated based on the current device event status.
MTR_DEVICE_KEY
D1_DVC_EVT.D1_DEVICE_ID
D1_DVC_EVT_REL_OBJ.PK_VALUE1
This field is populated based on the device ID associated with the device event (on the device event itself or via its related object collection.
If there is no device ID on the device event, the device ID is derived from the measuring component or service point associated with the device event.
MC_KEY
This field is populated based on the measuring component associated with the device event via its related object collection.
SPR_KEY
Service Provider Dimension Surrogate Key
This field is populated based on the service point ID associated with the device event. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via extract parameters.
SP_KEY
This field is populated based on the service point associated with the device event via its related object collection.
If there is no service point ID associated with the device event, then the service point ID is derived from the device associated with the device event.
ADDR_KEY
This field is populated based on the service point associated with the device event.
US1_KEY
D1_US_SP.US_ID
This field is populated based on the usage subscription linked to the service point associated with the device event. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
D1_US_SP.US_ID
This field is populated based on the usage subscription linked to the service point associated with the device event. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the second subscription type defined on the extract parameters.
USAGE_GROUP_KEY
CONTACT_KEY
This field is populated with the primary contact Id of the CCB-related usage subscription linked to the service point associated with the activity.
DEVICE_EVT_TYPE_
KEY
Device Event Type Dimension Surrogate Key
D1_DVC_EVT.DVC_EVT_TYPE_CD
This field is populated based on the device event type code associated with the activity.
START_DATE_KEY
START_TIME_KEY
Start Time (Time Dimension Surrogate Key)
This field is populated based on the device event start time.
END_DATE_KEY
This field is populated based on the device event end date.
END_TIME_KEY
This field is populated based on the device event end time.
PER_KEY
This field is populated based on the External Person ID stored on the activity’s contact identifiers.
ACCT_KEY
This field is populated based on the External Account ID stored on the activity’s CCB-related usage subscription’s identifiers
SA_KEY
This field is populated based on the External Service Agreement ID stored on the activity's CCB-related usage subscription's identifiers.
PREM_KEY
This field is populated based on the External Premise ID stored on the activity's service point's identifiers.
DEVICE_EVT_UDD1_
KEY
Device Event User Defined Dimension 1 Surrogate Key
DEVICE_EVT_UDD2_
KEY
Device Event User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Installation Event Fact
The Installation Event fact holds all the installation details of devices on service points in the Oracle Utilities Meter Data Management system. It holds the current installation status and the duration of installation.
Entity Relationship diagram of the Installation Event fact.
Properties
Property
Value
Target Table Name
CF_INSTALL_EVT
Table Type
Fact
Fact Type
Accumulation
D1_INSTALL_EVT
D1_SP
D1_US
Stage Table Name
STG_CF_INSTALL_EVT
ODI Package Name
B1_PKG_CF_INSTALL_EVT
ETL View Name
B1_F_INSTALL_EVT_VW
B1_INSTALL_EVT_MON_MV1
B1_INSTALL_EVT_MON_MV2
Fields
Target Field
Description
Source Field
Surrogate Key
INSTALL_EVT_KEY
Install Event Fact Key
This field is populated from the OUBI_INSTALL_EVT_SEQ sequence.
Natural Keys
SRC_INSTALL_EVT_ID
Install Event ID
D1_INSTALL_EVT.INSTALL_EVT_ID
This field is populated based on all the install events from the Install Event table.
Measures
DURATION
Duration
D1_INSTALL_EVT.D1_REMOVAL_DTTM,SYSDATE)-D1_INSTALL_EVT.D1_INSTALL_DTTM
This represents the time between installation and removal. If the removal date/time is blank, the time between the system date/time and installation date/time. Unit of measure is seconds.
FACT_CNT
Fact Count
INSTALL_DTTM
Install Date
REMOVAL_DTTM
Removal Date
Foreign Keys
IE_STATUS_KEY
Install Event Status Dimension Surrogate Key
D1_INSTALL_EVT.D1_INSTALL_EVT.BUS_OBJ_CD
D1_INSTALL_EVT.D1_INSTALL_EVT.BO_STATUS_CD
D1_INSTALL_EVT.BO_STATUS_REASON_CD
This field is populated based on the installation event's current status.
MTR_DEVICE_KEY
This is populated with the device associated with the installation event's device configuration.
SPR1_KEY
SPR2_KEY
The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second configured via extract parameters.
SP1_KEY
Service Point 1 Dimension Surrogate Key
This field is populated with the service point where the installation event is.
SP2_KEY
Service Point 2 Dimension Surrogate Key
D1_SP_REL.REL_SP_ID
This field is populated based on the parent service point of the installation event's service point.
ADDR_KEY
This field is populated based on the installation event's service point.
US1_KEY
D1_US_SP.US_ID
This field is populated based on the service point associated with the activity. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
D1_US_SP.US_ID
This field is populated based on the service point associated with the activity. It is populated with the usage subscription linked to the service point, whose usage subscription type's subscription type matches the second subscription type defined on the extract parameters.
USAGE_GROUP_KEY
CONTACT_KEY
This field is populated with the primary contact ID of the CCB-related usage subscription linked to the service point associated with the activity.
INSTALL_DATE_KEY
Install Event Date Dimension Surrogate Key
INSTALL_TIME_KEY
Install Event Time Dimension Surrogate Key
REMOVAL_DATE_KEY
Removal Date Dimension Surrogate Key
REMOVAL_TIME_KEY
Removal Time Dimension Surrogate Key
PER_KEY
This field is populated based on the External Person ID stored on the install event’s contact identifiers.
ACCT_KEY
This field is populated based on the External Account ID stored on the install event’s CCB-related usage subscription's identifiers.
SA_KEY
This field is populated based on the External Service Agreement ID stored on the install event’s CCB-related usage subscription's identifiers.
PREM_KEY
This field is populated based on the External Premise ID stored on the install event’s service point's identifiers.
INSTALL_EVT_UDD1_
KEY
Install Event User Defined Dimension 1 Surrogate Key
INSTALL_EVT_UDD2_
KEY
Install Event User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Service Point Accumulation Fact
The Service Point Accumulation fact holds the details of all service points defined in the Oracle Utilities Meter Data Management system along with its current installation status.
Entity Relationship diagram of the Service Point Accumulation fact.
Properties
Property
Value
Target Table Name
CF_SP
Table Type
Fact
Fact Type
Accumulation
D1_SP
D1_INSTALL_EVT
D1_US
Stage Table Name
STG_CF_SP
ODI Package Name
B1_PKG_CF_SP
ETL View Name
B1_F_SP_VW
B1_SP_MV1
Fields
Target Field
Description
Source Field
Surrogate Key
SP_KEY
This field is populated from the OUBI_SP_SEQ sequence.
Natural Keys
SRC_SP_ID
Service Point ID
D1_SP.D1_SP_ID
Measures
FACT_CNT
Fact Count
SP_CONN_STATUS
Service Point Connection Status
CI_LOOKUP_VAL_L.DESCR_OVRD
This field is populated with the description of the service point’s connection status.
If the override description is not available, the regular description is extracted.
DEVICE_STATUS
Device Status
This field is populated with the description of the status of the device currently installed on the service point.
Foreign Keys
SP_STATUS_KEY
Service Point Status Dimension Surrogate Key
D1_SP.D1_SP.BUS_OBJ_CD
D1_SP.D1_SP.BO_STATUS_CD
D1_SP.BO_STATUS_REASON_CD
This field is populated based on the service point’s current status.
IE_STATUS_KEY
MTR_DEVICE_KEY
This field is populated with the device associated with installation event's device configuration.
SPR1_KEY
This field is populated based on the service point ID associated with the activity. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via the extract parameters.
SPR2_KEY
This field is populated based on the service point ID associated with the activity. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second configured via the extract parameters.
SP1_KEY
D1_SP.D1_SP_ID
SP2_KEY
D1_SP_REL.REL_SP_ID
ADDR_KEY
D1_SP.D1_SP_ID
US1_KEY
D1_US_SP.US_ID
This field is populated based on the service point associated with the activity. It is populated with the usage subscription linked to the service point, whose usage subscription type's subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
D1_US_SP.US_ID
USAGE_GROUP_KEY
CONTACT_KEY
PER_KEY
This field is populated based on the External Person ID stored on the service point’s contact identifiers.
ACCT_KEY
This field is populated based on the External Account ID stored on the service point’s CCB-related usage subscription's identifiers.
SA_KEY
This field is populated based on the External Service Agreement ID stored on the service point’s CCB-related usage subscription's identifiers.
PREM_KEY
This field is populated based on the External Premise ID stored on the service point’s service point's identifiers.
SP_UDD1_KEY
Service Point User Defined Dimension 1 Surrogate Key
SP_UDD2_KEY
Service Point User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Service Point Snapshot Fact
The Service Point Snapshot fact stores periodic snapshot of all service points defined in the Oracle Utilities Meter Data Management system along with important metrics, such as device status, connection status, and measurement indicators.
Taking the Service Point Snapshot fact involves determining how long it has been since a normal measurement was received for the service point. Because of the potential huge volume of measurements, these data are not replicated on to the data warehouse. Instead, a download table for Service Point snapshot is populated in Oracle Utilities Meter Data Management through a specialized batch job. This job is responsible for taking the weekly or monthly service point snapshot, and inserting the results onto the download table. This download table is the one replicated and loaded by the ODI ETL process on to the data warehouse.
Note: There is no transformation logic to populate the target fields in the fact since they directly consume the data from the download table (populated by the batch programs in Oracle Utilities Meter Data Management).
For details about setting up snapshot fact extracts, see the Configuring Oracle Utilities Analytics Warehouse chapter in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
Entity Relationship diagram of the Service Point Snapshot fact.
Properties
Property
Value
Target Table Name
CF_SP_SNAP
Table Type
Fact
Fact Type
Snapshot
Source System Download Table
D1_SP_SNAP_DL
Stage Table Name
STG_CF_SP_SNAP
ODI Package Name
B1_PKG_CF_SP_SNAP
ETL View Name
B1_F_SP_SNAP_VW
B1_SP_SNAP_MON_MV1
B1_SP_SNAP_MON_TOPX_MV1
Source Batch Program
D1-SPSNAP-DL
Fields
Target Field
Description
Source Field
Surrogate Key
SP_SNAP_KEY
Service Point Snapshot Key
Natural Keys
SRC_SP_ID
Service Point ID
D1_SP_SNAP_DL.D1_SP_ID
SNAP_TYPE_CD
Snapshot Type Code
D1_SP_SNAP_DL.SNAPSHOT_TYPE_FLG
Measures
DEVICE_STATUS
Device Status
D1_SP_SNAP_DL.ONOFF_HIST_DESCR
This field is populated with the status of the device installed at the service point at the time of the snapshot.
SP_CONN_STATUS
D1_SP_SNAP_DL.SP_SRC_STAT_DESCR
DAYS_LAST_MSRMT
Days without Measurements
D1_SP_SNAP_DL.DAYS_LAST_NORMAL_MSRMT
This field is populated with the number of days since the last normal measurement was received for the service point.
If there are no normal measurements at all, the number of days is calculated based on the start date of the service point's installation event as of the snapshot end date.
If there is no installation event linked to the service point, the number of days is ‘0’.
NVR_RECD_MSRMT_
IND
Never Received Measurements
D1_SP_SNAP_DL.NEVER_RCVD_MSRMT_IND
If the service point never received measurements, this indicator is set to ‘1’.
Foreign Keys
DATE_KEY
D1_SP_SNAP_DL.SNAPSHOT_DTTM
This field is populated from the Date table based on the snapshot date/time.
SP_STATUS_KEY
D1_SP_SNAP_DL.SP_BUS_OBJ_CD
D1_SP_SNAP_DL.SP_BO_STATUS_CD
D1_SP_SNAP_DL.SP_BO_STATUS_REASON_CD
This field is populated based on the status of the service point at the end of the snapshot period.
IE_STATUS_KEY
D1_SP_SNAP_DL.IE_BUS_OBJ_CD
D1_SP_SNAP_DL.IE_BO_STATUS_CD
D1_SP_SNAP_DL.IE_BO_STATUS_REASON_CD
This field is populated based on the status of the installation event at the end of the snapshot period.
MTR_DEVICE_KEY
D1_SP_SNAP_DL.D1_DEVICE_ID
This is populated with the device that is installed at the service point at the end of the snapshot period.
SPR1_KEY
D1_SP_SNAP_DL.SPR1_CD
SPR2_KEY
D1_SP_SNAP_DL.SPR2_CD
This field is populated based on the service point ID associated with the activity. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second one configured via the extract parameters.
SP1_KEY
SP2_KEY
D1_SP_SNAP_DL.PARENT_SP_ID
ADDR_KEY
D1_SP_SNAP_DL.ADDRESS_ID
US1_KEY
D1_SP_SNAP_DL.US1_ID
US2_KEY
D1_SP_SNAP_DL.US2_ID
USAGE_GROUP_KEY
D1_SP_SNAP_DL.USG_GRP_C
CONTACT_KEY
D1_SP_SNAP_DL.CONTACT_ID
DAYS_LAST_MSRMT_
KEY
Days Since Last Measurement Dimension Surrogate Key
D1_SP_SNAP_DL.DAYS_LAST_MSRMT_BKT_CD
PER_KEY
D1_SP_SNAP_DL.CIS_EXT_PERSON_ID
ACCT_KEY
D1_SP_SNAP_DL.CIS_EXT_ACCT_ID
SA_KEY
D1_SP_SNAP_DL.CIS_EXT_SA_ID
PREM_KEY
D1_SP_SNAP_DL.CIS_EXT_PREM_ID
This field is populated from the Premise table based on external premise identifier associated with the service point.
SP_SNAP_UDD1_KEY
SP Snapshot User Defined Dimension 1 Surrogate Key
D1_SP_SNAP_DL.UDD1_CD
SP_SNAP_UDD2_KEY
SP Snapshot User Defined Dimension 2 Surrogate Key
D1_SP_SNAP_DL.UDD2_CD
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
SNAPSHOT_DT
Snapshot Date
DATA_SOURCE_IND
JOB_NBR
Job Number
Unreported Usage Analysis Snapshot Fact
The Unreported Usage Analysis snapshot fact stores the amount of consumption that has taken place since the last usage transaction was sent. The consumption data is captured for all active service points on a periodic basis.
Taking the Unreported Usage Analysis Snapshot involves determining the amount of consumption that has taken place since the most recent usage transaction was sent. Because of the potential huge volume of measurements, the data is not replicated on to the data warehouse. Instead, a download table for the Unreported Usage Analysis Snapshot is populated in Oracle Utilities Meter Data Management through a specialized batch job. This job is responsible for taking the weekly or monthly Unreported Usage Analysis Snapshot, and inserting the results onto the download table. This download table is the one replicated and loaded by the ODI ETL process on to the data warehouse.
Entity Relationship diagram of the Unreported Usage Analysis Snapshot fact.
Properties
Property
Value
Target Table Name
CF_SP_UT_AGE
Table Type
Fact
Fact Type
Snapshot
D1_SP_UNR_USG_SNAP_DL
Stage Table Name
STG_CF_SP_UT_AGE
ODI Package Name
B1_PKG_CF_SP_UT_AGE
ETL View Name
B1_F_SP_UT_AGE_VW
B1_SP_UT_AGE_MON_MV1
B1_SP_UT_AGE_MON_TOPX_MV1
D2-SPUT-DL
Fields
Target Field
Description
Source Field
Surrogate Key
SP_UT_AGE_KEY
Unreported Usage Analysis Snapshot Key
This field is populated from the OUBI_SP_UT_AGE_SEQ sequence.
Natural Keys
SRC_SP_ID
Service Point ID
D1_SP_UNR_USG_SNAP_DL.D1_SP_ID
SRC_SP_UT_AGE_TYPE_CD
Unreported Usage Aging Type Key
D1_SP_UNR_USG_SNAP_DL.UNR_USG_SNAPSHOT_TYPE_FLG
Measures
FACT_CNT
Count
CONS_AFT_LAST_UT
Total Quantity
D1_SP_UNR_USG_SNAP_DL.TOT_CONS_SINCE_LAST_UT
This is the total consumption since the last usage transaction was sent.
CONS_AFT_LAST_UT_
BUCKET1
Consumption After Last UT - Bucket 1
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT1
This is the total consumption, since the last usage transaction was sent, that falls within the first configurable bucket range.
CONS_AFT_LAST_UT_
BUCKET1_DESCR
Consumption After Last UT - Bucket 1 Description
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT1_DESCR
CONS_AFT_LAST_UT_
BUCKET2
Consumption After Last UT - Bucket 2
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT2
This is the total consumption, since the last usage transaction was sent, that falls within the second configurable bucket range.
CONS_AFT_LAST_UT_
BUCKET2_DESCR
Consumption After Last UT - Bucket 2 Description
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT2_DESCR
CONS_AFT_LAST_UT_
BUCKET3
Consumption After Last UT - Bucket 3
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT3
This is the total consumption, since the last usage transaction was sent, that falls within the third configurable bucket range.
CONS_AFT_LAST_UT_
BUCKET3_DESCR
Consumption After Last UT - Bucket 3 Description
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT3_DESCR
CONS_AFT_LAST_UT_
BUCKET4
Consumption After Last UT - Bucket 4
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT4
This is the total consumption, since the last usage transaction was sent, that falls within the last configurable bucket range.
CONS_AFT_LAST_UT_
BUCKET4_DESCR
Consumption After Last UT - Bucket 4 Description
D1_SP_UNR_USG_SNAP_DL.CONS_SINCE_LAST_UT_BKT4_DESCR
DAYS_LAST_UT
Days Since Last Usage Transaction
D1_SP_UNR_USG_SNAP_DL.TOT_DAYS_SINCE_LAST_UT
This is the number of days since the last usage transaction was sent.
SNAP_TYPE_CD
Snapshot Type Code
D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_TYPE_FLG
Foreign Keys
DATE_KEY
D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_DTTM
DAYS_LASTUT_TYPE_
KEY
Days Since Last UT Type Dimension Surrogate Key
D1_SP_UNR_USG_SNAP_DL.TOT_DAYS_SINCE_LAST_UT_BKT_CD
This field is populated based on the total number of days since last usage transaction bucket code associated with the service point.
SP_UT_AGE_TYPE_KEY
Unreported Usage Aging Type Dimension Surrogate Key
This field is populated based on the unreported usage snapshot type associated with the service point.
MTR_DEVICE_KEY
D1_SP_UNR_USG_SNAP_DL.D1_DEVICE_ID
This field is populated with the device ID based on the unreported usage snapshot type associated with the service point.
SPR1_KEY
D1_SP_UNR_USG_SNAP_DL.SPR1_CD
This field is populated based on the service point ID associated with the unreported usage transaction. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via the extract parameters.
SPR2_KEY
D1_SP_UNR_USG_SNAP_DL.SPR2_CD
This field is populated based on the service point ID associated with the unreported usage transaction. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second one configured via the extract parameters.
SP1_KEY
This field is populated based on the service point ID associated with the unreported usage transaction via its related object collection.
If there is no service point ID associated, then the service point ID is derived from the device associated with the activity.
SP2_KEY
D1_SP_UNR_USG_SNAP_DL.PARENT_SP_ID
ADDR_KEY
D1_SP_UNR_USG_SNAP_DL.ADDRESS_ID
US_KEY
Usage Subscription Dimension Surrogate Key
D1_SP_UNR_USG_SNAP_DL.US_ID
This field is populated based on the service point associated with the unreported usage transaction. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the first subscription type defined on the extract parameters.
USAGE_GROUP_KEY
D1_SP_UNR_USG_SNAP_DL.USG_GRP_CD
This field is populated based on the usage group of the CCB-related usage subscription linked to the service point associated with the unreported usage.
CONTACT_KEY
D1_SP_UNR_USG_SNAP_DL.CONTACT_ID
This field is populated with the primary contact ID of the CCB-related usage subscription linked to the service point associated with the unreported usage.
UOM_TOU_SQI_KEY
UOM TOU SQI Dimension Surrogate Key
D1_SP_UNR_USG_SNAP_DL.D1_UOM_CD
D1_SP_UNR_USG_SNAP_DL.D1_TOU_CD
D1_SP_UNR_USG_SNAP_DL.D1_SQI_CD
This field is populated based on the UOM/TOU/SQI used for identifying the source measuring component and value identifier that is used to calculate the unbilled consumption.
PER_KEY
D1_SP_UNR_USG_SNAP_DL.CIS_EXT_PERSON_ID
This field is populated based on the External Person ID stored on the activity's contact identifiers.
ACCT_KEY
D1_SP_UNR_USG_SNAP_DL.CIS_EXT_ACCT_ID
This field is populated based on the External Account ID stored on the activity’s CCB-related usage subscription’s identifiers.
SA_KEY
D1_SP_UNR_USG_SNAP_DL.CIS_EXT_SA_ID
This field is populated based on the External Service Agreement ID stored on the activity’s CCB-related usage subscription’s identifiers.
PREM_KEY
D1_SP_UNR_USG_SNAP_DL.CIS_EXT_PREM_ID
This field is populated based on the External Premise ID stored on the activity’s service point’s identifiers.
SP_UT_AGE_UDD1_KEY
Unreported Usage Analysis User Defined Dimension 1 Surrogate Key
D1_SP_UNR_USG_SNAP_DL.UDD1_CD
SP_UT_AGE_UDD2_KEY
Unreported Usage Analysis User Defined Dimension 2 Surrogate Key
D1_SP_UNR_USG_SNAP_D.UDD2_CD
UDM1
D1_SP_UNR_USG_SNAP_DL.D1_UDM1
UDM2
D1_SP_UNR_USG_SNAP_DL.D1_UDM2
UDM3
D1_SP_UNR_USG_SNAP_DL.D1_UDM3
UDM4
D1_SP_UNR_USG_SNAP_DL.D1_UDM4
UDM5
D1_SP_UNR_USG_SNAP_DL.D1_UDM5
UDM6
D1_SP_UNR_USG_SNAP_DL.D1_UDM6
UDM7
D1_SP_UNR_USG_SNAP_DL.D1_UDM7
UDM8
D1_SP_UNR_USG_SNAP_DL.D1_UDM8
UDM9
D1_SP_UNR_USG_SNAP_DL.D1_UDM9
UDM10
D1_SP_UNR_USG_SNAP_DL.D1_UDM10
UDDGEN1
D1_SP_UNR_USG_SNAP_DL.D1_UDDGEN1
UDDGEN2
D1_SP_UNR_USG_SNAP_DL.D1_UDDGEN2
UDDGEN3
D1_SP_UNR_USG_SNAP_DL.D1_UDDGEN3
UDDGEN4
D1_SP_UNR_USG_SNAP_DL.D1_UDDGEN4
UDDGEN5
D1_SP_UNR_USG_SNAP_DL.D1_UDDGEN5
UDDGENL1
D1_SP_UNR_USG_SNAP_DL.UDDGENLONG1
UDDGENL2
D1_SP_UNR_USG_SNAP_DL.UDDGENLONG2
UDDGENL3
D1_SP_UNR_USG_SNAP_DL.UDDGENLONG3
UDDGENL4
D1_SP_UNR_USG_SNAP_DL.UDDGENLONG4
UDDGENL5
D1_SP_UNR_USG_SNAP_DL.UDDGENLONG5
UDDFK1_KEY
D1_SP_UNR_USG_SNAP_DL.D1_UDDFK1
UDDFK2_KEY
D1_SP_UNR_USG_SNAP_DL.D1_UDDFK2
UDDFK3_KEY
D1_SP_UNR_USG_SNAP_DL.D1_UDDFK3
UDDFK4_KEY
D1_SP_UNR_USG_SNAP_DL.D1_UDDFK4
UDDFK5_KEY
D1_SP_UNR_USG_SNAP_DL.D1_UDDFK5
SNAPSHOT_DT
Snapshot Date
DATA_SOURCE_IND
JOB_NBR
Job Number
Usage Snapshot Fact
The Usage Snapshot fact stores the summarized consumption details, such as total usage and number of measurements. The data is stored for every active service point in the system on a periodical basis. Once a month (or once a week), a TOU map is applied to every active service point’s consumption; every resultant TOU, measurement condition and quantity results in a row on the Usage Snapshot fact.
Taking the Usage snapshot involves transforming the consumption by applying a few core Oracle Meter Data Management functionalities, such as converting scalar consumption to intervals, axis conversion and TOU-mapping, These functionalities cannot be replicated in ODI. Instead, a download table for the Usage Snapshot is populated in Oracle Utilities Meter Data Management through a specialized batch job. This job is responsible for taking the weekly or monthly Usage Snapshot, and inserting the results onto the download table. This download table is the one replicated and loaded by the ODI ETL process on to the data warehouse
Entity Relationship diagram of the Usage Snapshot fact.
Properties
Property
Value
Target Table Name
CF_CONSUMPTION
Table Type
Fact
Fact Type
Snapshot
D1_SP_USG_SNAP_DL
Stage Table Name
STG_CF_CONSUMPTION
ODI Package Name
B1_PKG_CF_CONSUMPTION
ETL View Name
B1_F_CONSUMPTION_VW
B1_CONSUMPTION_MON_MV1
B1_CONSUMPTION_MON_TOPX_MV1
D2-SP-USG-DL
Fields
Target Field
Description
Source Field
Surrogate Key
CONSUMPTION_KEY
Consumption Dimension Surrogate Key
This field is populated from the OUBI_CONSUMPTION_
SEQ sequence.
Natural Keys
SRC_SP_ID
Service Point ID
D1_SP_USG_SNAP_DL.D1_SP_ID
SRC_MC_ID
Measuring Component ID
D1_SP_USG_SNAP_DL.MEASR_COMP_ID
SRC_CONS_SNAPSHOT_TYPE_CD
Usage Snapshot Type
D1_SP_USG_SNAP_DL.USG_SNAPSHOT_TYPE_FLG
SRC_TOU_CD
TOU Code
D1_SP_USG_SNAP_DL.D1_TOU_CD
SRC_MSRMT_COND_CD
Measurement Condition Code
D1_SP_USG_SNAP_DL.MSRMT_COND_FLG
SNAP_TYPE_CD
Snapshot Type Code
D1_SP_USG_SNAP_DL.SNAPSHOT_TYPE_FLG
Measures
QUANTITY
Quantity
D1_SP_USG_SNAP_DL.MSRMT_VAL
NUM_MSRMT
Number of Measurements
D1_SP_USG_SNAP_DL.NBR_OF_MSRMTS
This field is populated with the number of measurements included in the summarized consumption of the service point.
NUM_MIN
Number of Minutes
D1_SP_USG_SNAP_DL.NBR_OF_MINS
This field is populated with the number of minutes per measurement.
FACT_CNT
Fact Count
Foreign Keys
DATE_KEY
D1_SP_USG_SNAP_DL.SNAPSHOT_DTTM
This field is populated based on the snapshot date/time.
CONS_SNAPSHOT_TYPE_KEY
Consumption Snapshot Type Dimension Surrogate Key
This field is populated from the Consumption Snapshot Type table based on the usage subscription type associated with the usage subscription.
MC_KEY
This field is populated based on the Measuring Component ID associated with the usage subscription via its related object collection.
SPR1_KEY
D1_SP_USG_SNAP_DL.SPR1_CD
This field is populated based on the service point ID associated with the usage subscription. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via the extract parameters.
SPR2_KEY
D1_SP_USG_SNAP_DL.SPR2_CD
This field is populated based on the service point ID associated with the usage subscription. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second one configured via the extract parameters.
SP1_KEY
This field is populated based on the service point ID associated with the usage subscription via its related object collection.
SP2_KEY
D1_SP_USG_SNAP_DL.PARENT_SP_ID
MTR_DEVICE_KEY
D1_SP_USG_SNAP_DL.D1_DEVICE_ID
This field is populated based on the device ID associated with the usage subscription via its related object collection.
If there is no device ID associated with the usage subscription, then the device ID is derived from the measuring component or service point associated with the usage subscription.
ADDR_KEY
D1_SP_USG_SNAP_DL.ADDRESS_ID
US1_KEY
D1_SP_USG_SNAP_DL.US1_ID
This field is populated based on the service point associated with the usage subscription. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
D1_SP_USG_SNAP_DL.US2_ID
This field is populated based on the service point associated with the usage subscription. It is populated with the usage subscription linked to the service point, whose usage subscription type’s subscription type matches the second subscription type defined on the extract parameters.
USAGE_GROUP_KEY
D1_SP_USG_SNAP_DL.USG_GRP_CD
This field is populated based on the usage group of the CCB-related usage subscription linked to the service point associated with the usage subscription.
CONTACT_KEY
D1_SP_USG_SNAP_DL.CONTACT_ID
This field is populated with the primary contact ID of the CCB-related usage subscription linked to the service point associated with the usage subscription.
MSRMT_COND_KEY
Measurement Condition Dimension Surrogate Key
This field is populated with the measurement condition associated with the current usage subscription.
UOM_TOU_KEY
UOM TOU Dimension Surrogate Key
D1_SP_USG_SNAP_DL.
D1_UOM_CD
This field is populated based on the UOM code and TOU code associated with the usage subscription.
PER_KEY
D1_SP_USG_SNAP_DL.CIS_EXT_PERSON_ID
ACCT_KEY
D1_SP_USG_SNAP_DL.CIS_EXT_ACCT_ID
This field is populated based on the external account ID stored on the activity's CCB-related usage subscription's identifiers.
SA_KEY
D1_SP_USG_SNAP_DL.CIS_EXT_SA_ID
This field is populated based on the external service agreement ID stored on the activity's CCB-related usage subscription's identifiers.
PREM_KEY
D1_SP_USG_SNAP_DL.CIS_EXT_PREM_ID
This field is populated based on the external premise ID stored on the activity's service point's identifiers.
CONSUMPTION_UDD1_KEY
Consumption User Defined Dimension 1 Surrogate Key
D1_SP_USG_SNAP_DL.UDD1_CD
CONSUMPTION_UDD2_KEY
Consumption User Defined Dimension 2 Surrogate Key
D1_SP_USG_SNAP_DL.UDD2_CD
UDM1
D1_SP_USG_SNAP_DL.D1_UDM1
UDM2
D1_SP_USG_SNAP_DL.D1_UDM2
UDM3
D1_SP_USG_SNAP_DL.D1_UDM3
UDM4
D1_SP_USG_SNAP_DL.D1_UDM4
UDM5
D1_SP_USG_SNAP_DL.D1_UDM5
UDM6
D1_SP_USG_SNAP_DL.
D1_UDM6
UDM7
D1_SP_USG_SNAP_DL.D1_UDM7
UDM8
D1_SP_USG_SNAP_DL.D1_UDM8
UDM9
D1_SP_USG_SNAP_DL.D1_UDM9
UDM10
D1_SP_USG_SNAP_DL.D1_UDM10
UDDGEN1
D1_SP_USG_SNAP_DL.D1_UDDGEN1
UDDGEN2
D1_SP_USG_SNAP_DL.D1_UDDGEN2
UDDGEN3
D1_SP_USG_SNAP_DL.D1_UDDGEN3
UDDGEN4
D1_SP_USG_SNAP_DL.D1_UDDGEN4
UDDGEN5
D1_SP_USG_SNAP_DL.D1_UDDGEN5
UDDGENL1
D1_SP_USG_SNAP_DL.
UDDGENLONG1
UDDGENL2
D1_SP_USG_SNAP_DL.
UDDGENLONG2
UDDGENL3
D1_SP_USG_SNAP_DL.
UDDGENLONG3
UDDGENL4
D1_SP_USG_SNAP_DL.
UDDGENLONG4
UDDGENL5
D1_SP_USG_SNAP_DL.
UDDGENLONG5
UDDFK1_KEY
D1_SP_USG_SNAP_DL.D1_UDDFK1
UDDFK2_KEY
D1_SP_USG_SNAP_DL.D1_UDDFK2
UDDFK3_KEY
D1_SP_USG_SNAP_DL.D1_UDDFK3
UDDFK4_KEY
D1_SP_USG_SNAP_DL.D1_UDDFK4
UDDFK5_KEY
D1_SP_USG_SNAP_DL.D1_UDDFK5
SNAPSHOT_DT
Snapshot Date
D1_SP_USG_SNAP_DL.
SNAPSHOT_DTTM
DATA_SOURCE_IND
CI_INSTALLATION.
ENV_ID
JOB_NBR
Job Number
VEE Exception Snapshot Fact
The VEE Exception Snapshot fact stores the details of the exceptions encountered during VEE processing of the initial measurement data. It captures metrics, such as number of IMDs that result into exceptions, as well as those that do not result into any exception. The data is stored periodically.
Taking the VEE Exception snapshot involves determining the number of IMDs with and without exceptions. For IMDS with exceptions, we further subdivide the counts by exception type, IMD type, severity, VEE group and rules. Due to this complicated logic that looks at the presence and absence of data, as well as the volume of IMDs, these data are not replicated on the data warehouse. Instead, a download table for the VEE Exception Snapshot is populated in Oracle Utilities Meter Data Management through a specialized batch job. This job is responsible for taking the weekly or monthly VEE Exception Snapshot, and inserting the results onto the download table. This download table is the one replicated and loaded by the ODI ETL process on to the data warehouse
Entity Relationship diagram of the VEE Exception Snapshot fact.
Properties
Property
Value
Target Table Name
CF_VEE_EXCP
Table Type
Fact
Fact Type
Snapshot
D1_SP_VEE_EXCP_SNAP_DL
Stage Table Name
STG_CF_VEE_EXCP
ODI Package Name
B1_PKG_CF_VEE_EXCP
ETL View Name
B1_F_VEE_EXCP_VW
B1_VEE_EXCP_MON_MV1
B1_VEE_EXCP_TOPX_MON_MV1
D2-SPVEE-DL
Fields
Target Field
Description
Source Field
Surrogate Key
VEE_EXCP_KEY
VEE Exception Key
This field is populated from the OUBI_VEE_EXCP_SEQ sequence.
Natural Keys
SRC_SP_ID
Service Point ID
D1_SP_VEE_EXCP_SNAP_DL.D1_SP_ID
SRC_MC_ID
D1_SP_VEE_EXCP_SNAP_DL.MEASR_COMP_ID
SRC_EXCP_TYPE_CD
Exception Type Code
D1_SP_VEE_EXCP_SNAP_DL.EXCP_TYPE_CD
This field populates the source column from the download table. If the source column is not found in the download table, then the field is populated with ‘***’.
SRC_IMD_TYPE_CD
IMD Type Code
D1_SP_VEE_EXCP_SNAP_DL.D1_IMD_TYPE_FLG
SRC_EXCP_SEV_CD
Exception Severity Code
D1_SP_VEE_EXCP_SNAP_DL.EXCP_SEVERITY_FLG
SRC_VEE_GRP_CD
VEE Group Code
D1_SP_VEE_EXCP_SNAP_DL.VEE_GRP_CD
SRC_VEE_RULE_CD
VEE Rule Code
D1_SP_VEE_EXCP_SNAP_DL.VEE_RULE_CD
SNAP_TYPE_CD
Snapshot Type Code
D1_SP_VEE_EXCP_SNAP_DL.SNAPSHOT_TYPE_FLG
Measures
FACT_CNT
Count
IMD_COUNT_NO_EXCP
IMD Count without Exceptions
D1_SP_VEE_EXCP_SNAP_DL.NBR_IMDS_WITH_NO_EXCP
This field is the count of IMDs without exceptions, populated on the summary row.
IMD_COUNT_DISTINCT
IMD Count with at Least One Exception
D1_SP_VEE_EXCP_SNAP_DL.NBR_OF_IMDS_MIN_ONE_EXCP
This field is the number of IMDs that has at least one exception, only populated on the summary row.
IMD_COUNT
IMD Count
D1_SP_VEE_EXCP_SNAP_DL.NBR_IMDS_WITH_EXCP
This field is number of IMDs with exception for the exception type, severity, IMD type and VEE group/rule combination.
Foreign Keys
DATE_KEY
D1_SP_VEE_EXCP_SNAP_DL.SNAPSHOT_DTTM
MTR_DEVICE_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_DEVICE_ID
This field is populated based on the device ID associated with the VEE exception via its related object collection.
If there is no device ID associated with the exception, then the device ID is derived from the measuring component or service point associated with the activity.
MC_KEY
This field is populated based on the measuring component ID associated with the VEE exception via its related object collection.
SPR1_KEY
D1_SP_VEE_EXCP_SNAP_DL.SPR1_CD
This field is populated based on the service point ID associated with the VEE exception. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the first one configured via the extract parameters.
SPR2_KEY
D1_SP_VEE_EXCP_SNAP_DL.SPR2_CD
This field is populated based on the service point ID associated with the VEE exception. The service provider is retrieved from the service point or from the fallback service provider on the service point’s market. The market relationship type used is the second one configured via the extract parameters.
SP1_KEY
This field is populated based on the service point ID associated with the VEE exception via its related object collection.
If there is no service point ID associated with the exception, then the service point ID is derived from the device associated with the activity.
SP2_KEY
D1_SP_VEE_EXCP_SNAP_DL.PARENT_SP_ID
ADDR_KEY
D1_SP_VEE_EXCP_SNAP_DL.ADDRESS_ID
US1_KEY
D1_SP_VEE_EXCP_SNAP_DL.US1_ID
This field is populated based on the service point associated with the VEE exception. It is populated with the usage subscription linked to the service point, whose usage subscription type's subscription type matches the first subscription type defined on the extract parameters.
US2_KEY
D1_SP_VEE_EXCP_SNAP_DL.US2_ID
This field is populated based on the service point associated with the VEE exception. It is populated with the usage subscription linked to the service point, whose usage subscription type's subscription type matches the second subscription type defined on the extract parameters.
USAGE_GROUP_KEY
D1_SP_VEE_EXCP_SNAP_DL.USG_GRP_CD
This field is populated based on the usage group of the CCB-related usage subscription linked to the service point associated with the VEE exception.
CONTACT_KEY
D1_SP_VEE_EXCP_SNAP_DL.CONTACT_ID
This field is populated with the primary contact ID of the CCB-related usage subscription linked to the service point associated with the VEE exception.
EXCP_TYPE_KEY
Exception Type Dimension Surrogate Key
This field is populated based on the exception type code associated with the VEE exception.
IMD_TYPE_KEY
IMD Type Dimension Surrogate Key
This field is populated based on the IMD type code associated with the VEE exception.
EXCP_SEV_KEY
Exception Severity Dimension Surrogate Key
This field is populated based on the exception severity code associated with the service point.
VEE_RULE_KEY
VEE Rule Dimension Surrogate Key
This field is populated based on the exception rule code associated with the service point.
PER_KEY
D1_SP_VEE_EXCP_SNAP_DL.CIS_EXT_PERSON_ID
This field is populated based on the external person ID stored on the exception’s contact identifiers.
ACCT_KEY
D1_SP_VEE_EXCP_SNAP_DL.CIS_EXT_ACCT_ID
This field is populated based on the external account ID stored on the exception’s CCB-related usage subscription's identifiers.
SA_KEY
D1_SP_VEE_EXCP_SNAP_DL.CIS_EXT_SA_ID
This field is populated based on the external service agreement ID stored on the exception’s CCB-related usage subscription's identifiers.
PREM_KEY
D1_SP_VEE_EXCP_SNAP_DL.CIS_EXT_PREM_ID
This field is populated based on the external premise ID stored on the exception’s service point’s identifiers.
VEE_EXCP_UDD1_KEY
VEE Exception User Defined Dimension 1 Surrogate Key
D1_SP_VEE_EXCP_SNAP_DL.UDD1_CD
VEE_EXCP_UDD2_KEY
VEE Exception User Defined Dimension 2 Surrogate Key
D1_SP_VEE_EXCP_SNAP_DL.UDD2_CD
UDM1
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM1
UDM2
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM2
UDM3
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM3
UDM4
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM4
UDM5
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM5
UDM6
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM6
UDM7
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM7
UDM8
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM8
UDM9
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM9
UDM10
D1_SP_VEE_EXCP_SNAP_DL.D1_UDM10
UDDGEN1
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDGEN1
UDDGEN2
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDGEN2
UDDGEN3
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDGEN3
UDDGEN4
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDGEN4
UDDGEN5
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDGEN5
UDDGENL1
D1_SP_VEE_EXCP_SNAP_DLUDDGENLONG1
UDDGENL2
D1_SP_VEE_EXCP_SNAP_DLUDDGENLONG2
UDDGENL3
D1_SP_VEE_EXCP_SNAP_DLUDDGENLONG3
UDDGENL4
D1_SP_VEE_EXCP_SNAP_DLUDDGENLONG4
UDDGENL5
D1_SP_VEE_EXCP_SNAP_DLUDDGENLONG5
UDDFK1_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDFK1
UDDFK2_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDFK2
UDDFK3_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDFK3
UDDFK4_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDFK4
UDDFK5_KEY
D1_SP_VEE_EXCP_SNAP_DL.D1_UDDFK5
SNAPSHOT_DT
Snapshot Date
DATA_SOURCE_IND
JOB_NBR
Job Number
