Terminologies
This section describes the terminology used for data maps included in the document.
<Table Name>
Indicates the name of fact or dimension in a star schema in the data warehouse.
Properties
Lists properties of the table independent of each field. The following properties are listed in the table:
Property
Value
Target Table
Name of the table in the target schema (data warehouse) into which data is loaded
Table Type
Fact or Dimension
SCD Type
Type 1 - Existing records are updated directly.
Type 2 - Existing records are deactivated and changes are captured by inserting new effective records. The existing records are deactivated by assigning an effective end date of the current date. The new records will have effective start date of the current date and effective end date of a significantly future date.
Fact Type
Whether this is a snapshot or transactional fact table.
Snapshot - Captures a snapshot view of the data as available in the source system during that period (monthly or weekly). Each snapshot's data is stored independently.
Accumulation - Data from the source system is accumulated periodically. Changes from source system will be merged with the existing data. Multiple copies of the same data will not be maintained.
Source System Driver Table
Name of the table in source database on which the data is primarily based.
Oracle Data Integrator Package
Name of the ODI package that needs be executed to extract data from the source application and populate a specific target table in the data warehouse.
ETL View
Resides in the replication layer and fetches the base values from the replication tables as a starting point for further transformations to be done by the Oracle Data Integrator interfaces.
Fields
Lists the individual properties of each field in a fact or dimension. It includes the following columns:
Property
Value
Target Field
Name of the column in a fact or dimension present in the data warehouse. The extracted/transformed data is loaded here.
Description
Description of the target field
Source Field
Name of the field from the source application used to load the target field either directly or after transformation.
Transformation Logic
Specifies the details of how the data from the source field is transformed before being populated into the target field.
Field Categories
Lists the categories under which fields in a particular fact or dimension are grouped. The categories are as below:
Category
Details
Surrogate Key
The primary key on the fact/dimension table maintained within the data warehouse.
Natural Keys
The set of columns from the source system define the granularity of the fact or dimension table. The natural key columns from the source along with certain other data load attributes can be used to uniquely identify a record in the table.
The additional columns needed for the identification depend on the type of the table as listed below:
• SCD Type 1 Dimension - Data Source Indicator
• SCD Type 2 Dimension - Effective Start Date, Effective End Date, Data Source Indicator
• Accumulation Fact - Data Source Indicator
• Snapshot Fact - Snapshot Date, Data Source Indicator
Attributes
Hold descriptive data from the source system and are typically available in dimension tables.
Measures
Hold numerical values based data that is calculated from the source system data and are typically available on fact tables.
Degenerate Dimensions
Hold descriptive data from the source system and are typically available in fact tables. These cannot be included into any of the available dimensions.
Foreign Keys
Foreign key references on the fact tables to the dimension tables.
User Defined Attributes
Additional fields available to customers for extending the star schemas. These fields will not be populated out of the box. Customers need to customize the ETL and populate these fields.
Data Load Attributes
Hold the date/time information, job number details, etc, related to the ETL processes, that are needed for audit purposes.
