SMS Channel Communications
The Behavioral Demand ResponseCloud Service uses the SMS channel to send automated pre- and post-event text messages to customers. The messages are designed to motivate customers to save energy during peak events.
Design
The following are samples of SMS messages for the Behavioral Demand Response program.They include the peak day date and peak day start and end times configured based on the utility’s preferences.
Pre-Event SMS Sample
"UTIL: Today, 7/1 is an Energy Savings Day. From 2pm-6pm, join your community to help save energy. Text STOP to opt out."
Post-Event SMS Sample
“UTIL: Great job! On the 7/1 Energy Savings Day, you used 5.2 kWh and were 10th out of ~100 similar neighbors. This helps to save energy and money. Text STOP to opt out.”
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
SMS Short Code Provide the short code that should appear as the sender ID when a customer is contacted as part of the Behavioral Demand Response Program. Example: 96744 |
Required
Utility Name Indicate the utility name that should be used when contacting customers via SMS. Be sure to provide the name exactly as it should appear in the text message. Example: "CLIENTNAME: Today, 7/1 is an Energy Savings Day. From 2pm-6pm, join your community to help save energy. Text STOP to opt out." |
Required |
Utility Phone Number Note: Applicable only to clients with Press 6 to Enroll. Configuration Options Provide your customer service contact number. Example: "Thank you for confirming your subscription to CLIENTNAME text alerts. Msg&Data rates may apply. 4msg/month. For help call XXX-XXX-XXXX." |
Required |
