Demand Report Header Module
The Demand Report Header module notifies customers of when their demand hour occurred during the current month. This module is included only in the Demand Report email, and appears at the top, below the standard email header.
Design
This image shows an example of the Demand Report Header module:
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option | Input Value |
Peak Period Name The name of the peak period in the Insight Statement can be configured. This value should match the peak period name for all other Behavioral Load Shaping modules. Default: Peak |
Required Choose one of the following: Use the default. Use the following peak period name: |
To see how this module fits into the overall user experience, see Design and Configuration: Demand Rate Coach Emails.
