Advanced Search Options
The product offers an option to perform expanded / fuzzy searching in
Control Central Search by Name and Address. The option is only available if your implementation has appropriately configured your database for fuzzy searching.
Refer to the DBA guide in the installation guide for details on setting up the database to support fuzzy searching. Note that there are some implementations where fuzzy searching will not be possible. For example, it's only available for implementations using the Oracle database. Additionally, not all languages are supported. Refer to the Oracle Database documentation for more information about fuzzy searching.
If your implementation has configured its database to enable fuzzy searching, you must also set up a
Feature Configuration to indicate that feature is supported. Find the Feature Configuration record for the
General System Configuration feature type. (It may need to be defined if it does not exist). Choose the option type
Enable Expanded Results and define a value of
Y.
Parent topic
