Outbound Message - Message
Use this page to view the XML source used to build an outbound message. Open this page using  >  >  and then navigate to the Message tab.
Description of Page
The XML Source is displayed.
If a message XSL is defined on the external system / outbound message type record linked to this outbound message, the Show XML button is enabled. Click this button to view the XML that is a result of applying the Message XSL to the XML source.
Parent topic
