Understanding Consumer Product Rules
Determine Fallback Product
Determine If Reapplication Required
Basic information about the consumer product rule, including its name, description and detailed description. This is standard information for most consumer product rules.
Specific parameters used by the consumer product rule.
Determine Fallback Product: A rule that determines the fallback product using a consumer product class recorded in the rule.
Determine if Product should be Reapplied: A rule that determines if reapplication is necessary by deriving the current consumer product component eligibility criteria operands for the consumer product and comparing these with the previous operand values.
Additional algorithms may exist for your implementation. To see the available algorithm(s), search for algorithm types of the Consumer Product Rule (BO) – Apply Rule algorithm entity in the application.
