Setting Up and Executing Billing Data Extracts
- Configure the Billing Data Configuration for the DataConnect master configuration record. This is used to configure the UOM, TOU, and SQI of the SA Type's service quantity and charges that will be extracted. Additionally, you can also configure the UOM, TOU and SQI at the rate level.
Add the Capture Bill and Bill Segment Extract for DataConnect
v1+ (C1CAPBILBSEG) related post bill completion algorithm to
the applicable customer classes.
If using DataConnect v1, use the Capture Billing Data for DataConnect (Comma-delimited) (C1-CAPBILLEX) algorithm.
- Execute initial load batch processes related to billing data.
- Once the initial load synchronization has been executed, current data should be extracted on a regular ongoing (or incremental) basis. In addition to sending current data, any billing corrections will be extracted as well (data related to bill segments not linked to bills but are linked to frozen FTs that are linked to completed bills).
- Execute the sync request monitor process.
- Execute the extract batch processes related to billing.
