Account Center
The Account Center allows business customers to view and change information about their login details (email and password) and any applicable communication preferences. This functionality is available for utilities that provide a standalone web portal to business customers rather than implementing SSO authentication. See Authentication for more information about the different methods of authentication as well as the default requirements for secure passwords.
Manage Recipients and Preferences
The Manage Recipients and Preferences section allows users to manage recipient and alert preferences. Users can edit the primary recipient's information, add additional recipients to the account, edit recipient details, and select alert preferences for each recipient. Recipients are users who can be selected to receive communications and alerts related to the account. At a minimum, the section displays information for the primary recipient.
Manage Recipients
The details for each recipient are displayed and can be edited. Recipients other than the primary recipient can also be removed. The primary recipient can not be removed from the account. Additionally, each recipient must have a name and at least one communication type (email or phone number). The communication type determines which communications and alerts a recipient can select to receive. For example, an email address is required in order for a customer to select to receive email alerts. Recipient details include:
- Name
- Email address
- Phone numbers for text and voice messages
The name that appears on communications is the name on the actual utility account, and not the name that is displayed in the Account Center. If the primary recipient changes their name in the Account Center, it will not change the name that appears on the communication.
Create New Recipient
Customers can specify other recipients to receive alerts. Basic validation is performed to ensure that the phone numbers and email addresses resemble real values, but these values are not tested or verified. Note that these recipients will receive copies of the communications sent to the primary recipient. This means that the communications will contain the name of the primary recipient, not the secondary recipient.
Manage Message Preferences
The Message Preferences section is displayed once for each recipient on the account, and provides a list of the available communications and alerts that the recipient can receive. This section of the widget can be expanded or collapsed by clicking Details.
The products and channels that are displayed for each recipient depend on:
- The products and communications that are available from the utility.
- The communication types included for the recipient. For example, do they have both an email and a phone number?
- Whether the recipient is the primary recipient on the account.
Each applicable channel can then be selected or cleared for each recipient of a product.
High Usage Alerts
High usage alerts are digital communications sent through email, text, or voice channels to inform customers when they are expected to receive a higher energy bill.
A personalized alert threshold is available to business customers who receive High Bill Alerts AMI email. For information on the applicable cloud service, see the Oracle Utilities Opower Business Customer Engagement Proactive Alerts product overview. Depending on the characteristics of a customer's accounts, the customer is provided one of the following options to define an alert threshold:
- Cost threshold: The cost threshold allows customers to specify a dollar amount as their personalized threshold. When the cost threshold is set, the customer will only receive a high bill alert when their cost exceeds the threshold. All active utility accounts for a customer must have modeled rates. If a customer does not set their personalized threshold, they will only receive high bill alerts when they exceed the combined usage and cost threshold set by the utility. The recommended combined threshold is 30 percent.
- Usage threshold: The usage threshold allows the customer to set a percentage-based personalized threshold. When the usage threshold is set, the customer will only receive an alert when their energy use exceeds that threshold for the same billing period in the previous year. The default usage threshold is 30 percent. The usage-based threshold is available to customers who are ineligible to define a cost-based threshold. This applies to customers with at least one active account without modeled rates.
Login Details
For utilities that do not implement SSO authentication, a Login Details tab is available in the Account Center for customers who need to update their login email address and password. Any reset passwords must adhere to the password security requirements as defined during the utility's setup and configuration of the product.
