Near Real Time Usage
The Near Real-Time Usage widget displays unvalidated electric interval usage data for customers with AMI (Advanced Metering Infrastructure) meters. The data for this widget is delivered through an API built in partnership between the utility and Oracle Utilities Opower, and is designed to provide users with energy usage data and trends that are nearly current, as opposed to delayed or batch-processed data.
Near Real Time Usage Example
The image below is an example of the Near Real Time Usage widget.
Example screenshot of a bar chart displaying estimated near real-time electricity use over time, with usage values shown for different hours across twenty-four hours. A link for downloading the usage data is visible.
Configuration Options
There are no applicable configuration options for this widget.
