Preparing the Staging Database
After the staging owner (STGADM), application user (STGUSER) and read access user (STGREAD) are created, install the initial database option in the staging schema. The rest of the steps are listed below.
To run the utility:
1. Set JAVA_HOME, PATH, and CLASSPATH.
Linux/UNIX:
export JAVA_HOME=/scratch/software/jdk1.8.0_102/
export PATH=$JAVA_HOME/bin:$PATH
export CLASSPATH=/../FW-V4.5.0.0.0-Oracle-Database- Multiplatform/FW/jarfiles/*
Windows:
SET JAVA_HOME=C:\Program Files\Java\jdk1.8.0_101
SET PATH=%JAVA_HOME%\bin:%PATH%
SET CLASSPATH= C:\FW-V4.5.0.0.0-Oracle-Database- Multiplatform\FW\jarfiles\*
2. Run Conversion from any directory making sure Step 1 is complete. Run the command as necessary.
