Installing Oracle Analytics Publisher Enterprise
Oracle Analytics Publisher Enterprise provides the tools for:
Making reports available over the web (establishing the required report server processes)
Integrating reports with the Oracle Utilities Customer Care and Billing system
Scheduling reports to run on a regular basis
Managing instances of the reports that have been created by a previous run
Managing user access to the report instances
This section assumes that you have already installed Oracle Analytics Publisher Enterprise such that requests can be pointed to the Oracle Analytics Publisher Enterprise running on Windows or Unix.
Note: Images Do Not Generate Properly Without X Server in Unix version of Analytics Publisher. If you are running the Analytics Publisher server on a Linux or Unix machine that does not have an X Server installed reports that contain images may not be properly generated. Workaround: Specify the following property at the java command line:
-Djava.awt.headless=true
