Importing Keystores/Truststores
WhileOracle Utilities Customer Care and Billing supplies a default keystore and truststore it is possible to import existing keystores and/or truststores from alternative sources (such as a corporate level set of stores or from a trusted CA authority).
To import a keystore or truststore the following process should be followed:
• Logon to the machine you have made the changes upon as the product administrator.
• If you have not already done so, use the splenviron utility to set the environment variables for the product environment.
• Ensure the KS_IMPORT_KEYSTORE_FOLDER or TS_IMPORT_KEYSTORE_FOLDER is set in the ENVIRON.INI prior to continuing. These are the locations the files to be imported will be located for keystores and truststores respectively.
• Copy the new keystore or truststore to the locations specified in the KS_IMPORT_KEYSTORE_FOLDER or TS_IMPORT_KEYSTORE_FOLDER respectively.
• Execute the initialSetup.sh –s | -S to import the keystore (-s) or truststore (-S) successfully.
