Managing Batch Users
Each time a batch process is executed, the security components of Oracle Utilities Customer Care and Billing must authenticate the user against a security repository and authorize the user to access the components the batch process needs to complete its operations.
The Batch component of the architecture uses the following security mechanisms:
Security Mechanism
Description
Authentication
Any batch users must be defined to the operating system configured security repository and be a member of the operating system group assigned to Oracle Utilities Customer Care and Billing.
Note: The Userid does not have to match the authorization user.
Authorization
The authorization user is defined within Oracle Utilities Customer Care and Billing as per the Online Users and is specified as a job parameter at execution time or in configuration files supplied for the batch process. Refer to the Server Administration Guide for details of the parameters used for batch processing.
To manage Batch Users therefore the following is recommended:
• Add the authentication user used to initiate the thread pool and submitter processes for a batch process to the configured operating system repository.
• Specify a valid user authorization identifier as a parameter for the batch process. This identifier must be authorized to the valid actions against the main objects used in the batch process. Refer to the product functional documentation on the objects used in each of the product batch processes.
