Environment Variables
Oracle Utilities Customer Care and Billing uses several environment variables to determine where information is stored and to be placed for its internal operations. Becoming familiar with these variables will assist you in finding information quickly and efficiently.
Note: If a custom script is written to access or write information to the product functionality, it is highly recommended that the following variables be referenced in your scripts. This is to maximize the chance that your script will remain functional across upgrades.
The following table outlines some of the key environment variables:
Variable
Usage
ANT_ADDITIONAL_OPT
Options for ant in accordance with the configuration settings at installation time.
ANT_HOME
Location of ant build utilities.
ANT_OPTS
Options for ant for Oracle SDK.
ANT_OPT_MAX
Maximum memory settings for ant in accordance with the configuration settings at installation time.
ANT_OPT_MIN
Minimum memory settings for ant in accordance with the configuration settings at installation time.
CMPDB
Database Type (ORACLE).
DBNAME
Database Name.
ENVFILE
Location and name of environment configuration file.
HIBERNATE_JAR_DIR
Location of Hibernate Java library.
HOSTNAME
Name of host (fully qualified).
JAVA_HOME
Location of JDK.
LD_LIBRARY_PATH
Library Path.
NLS_DATE_FORMAT
Oracle NLS Date Format.
NLS_LANG
Oracle NLS Language string.
NLS_SORT
Oracle NLS Sorting.
ONLINEBILLINI
Location of document rendering software template building configuration files.
ONLINEDOCINI
Location of document rendering software configuration files.
OPSYS
Operating System Name.
OPSYSINFO/OPSYSVER
Operating System Version.
ORACLE_CLIENT_HOME
Location of the Oracle Client software (used for location of perl). If full Oracle Database software is installed on the host this value will match ORACLE_HOME.
ORACLE_HOME
Location of the DBMS software.
OSTYPE
Operating System Type.
PERL5LIB/PERLIB
Location of Perl Libraries.
PERL_HOME
Location of Perl.
SERVER_ROLES
Roles enable for this server.
SERVER_ROLE_BATCH
Whether the batch server is included.
SERVER_ROLE_INTEGRATION
Whether the integration server is included.
SERVER_ROLE_ONLINE
Whether the online server is included.
SPLADMIN
Administration user ID.
SPLADMINGROUP
Administration group.
SPLApp
Name of root web application WAR file.
SPLAPP
See SPLOUTPUT.
SPLBCKLOGDIR
Location of backups of online log files (must be set manually).
SPLEBASE
Location of software for environment.
SPLENVIRON
Name of environment.
SPLOUTPUT
Location of output for environment.
SPLRUN
Location of runtime for environment.
SPLSDKROOT
Location of SDK (Development environment only).
SPLSYSTEMLOGS
Location of product specific logs.
SPLVERSION
Version identifier of product (prefixed with V).
SPLVERSION_NUM
Version number of product.
WEB_ISEXPANDED
Whether web application is expanded or not (not = WAR/EAR files).
WEB_SERVER_HOME
Location of web application server software.
WL_HOME
Location of Oracle WebLogic installation (WebLogic supported platforms only).
Note: HIBERNATE_JAR_DIR is used for the installation process only. After installation is complete the jar files located at the locations specified by these environment variables are copied to the correct locations for execution.
Note: Additional variable may be created by various operating system and product utilities. The list above constitutes the non-temporary variables.
