Appointments Table Setup Sequence
Appointments
need only be set up if your organization allows your customers to make appointments for field activities.
Refer to
Enabling Appointments
for a description of the tables that must be set up to enable this functionality.
Parent topic
Customer Care and Billing Control Table Setup Sequence
This site works best with JavaScript enabled
