Function | Path |
General Environment | |
Seasonal Time Shift | Admin, Seasonal Time Shift |
Time Zone | Admin, Time Zone |
Installation - Framework | Admin, Installation Options - Framework Indicate whether Seasonal Time Shift is required. |
Installation | Admin, Installation Options Set Base Time and Start Day Option. |
Interval Billing Environment | |
Bill Factor | Menu, Rates, Bill Factor Note: earlier, you may have created bill factors for your general Rates environment. At this point, you may need to add more bill factors to satisfy your interval billing needs. |
Interval Profile Relationship Type | Admin, Interval Profile Relationship Type [Note - you won't be able to define the collection of valid Interval Profile Types until after you define the Interval Profile Types.] |
Interval Profile Type | Admin, Interval Profile Type [Note - you may need to define new algorithm types and algorithms if your interval profile type requires creation or validation algorithms.] |
Algorithm | Admin, Algorithm. You will need to set up the creation and validation algorithms needed for an Interval Profile Type. |
Shared Profiles | Menu, Interval Billing, Interval Profile Note: this is needed at this time if you want to create Start Options, which reference shared profiles. |
Interval Registers | |
Interval Register Type | Admin, Interval Register Type |
Meter Configuration Type | Admin, Meter Configuration Type Note: earlier, you may have created meter configuration types for your general meter environment. At this point, you may need to add more meter configuration types for registers, which are used for interval or index channels. |
Meter Type | Admin, Meter Type Note: earlier, you may have created meter types for your general meter environment. At this point, you may need to add more meter types for meters, which are used for interval or index channels. |
Time of Use Billing | |
Time of Use | Admin, Time of Use Note: earlier, you may have created time of use codes for your meter environment. At this point, you may need to add more time of use codes to satisfy your time of use mapping. |
TOU Group | Admin, TOU Group |
Bill Factor | Menu, Rates, Bill Factor At this point you may need to set up bill factors that are specifically for time of use pricing. |
TOU Map Relationship Type | Admin, TOU Map Relationship Type [Note - you won't be able to define the collection of valid TOU Map Types until after you define the TOU Map Types.] |
TOU Map Type | Admin, TOU Map Type |
Algorithm | Admin, Algorithm. You will need to set up any creation algorithms needed for your TOU map types. |
TOU Map Templates | Admin, TOU Map Template Note: this is not required, but will help to set up data for your TOU Maps. |
Shared TOU Maps | Menu, Interval Billing, TOU Map Note: this is needed at this time if you want to create Start Options, which reference shared TOU maps. |
Contract Options | |
Contract Option Type | Admin, Contract Option Type |
Algorithm | Admin, Algorithm. You will need to set up any validation algorithms needed for your contract option types. |
Contract Option Event Type | Admin, Contract Option Event Type |
SA Interval Billing Rate Environment | |
Rate | At this point, you are ready to set up your interval billing and time of use rates and calculation rules. Refer to the Rate Environment section in the Control Table Setup Sequence. |
SA Interval Billing Controls | |
SA Type | Admin, SA Type Note: earlier you may have created your SA Types. At this point you may need to modify interval related SA Types to add valid interval information. Refer to the SA Type section in the Control Table Setup Sequence. |
Start Option | Admin, SA Type Start Option Note: earlier you may have created your SA Type Start Options. At this point you may need to modify interval related SA Type Start Options to add valid interval information. Refer to the SA Type section in the Control Table Setup Sequence. |
