Open-Item Accounting Table Setup Sequence
Open-item accounting tables need only be set up if your organization practices
Open Item Accounting
. Refer to
Setting Up The System To Enable Open Item Accounting
for a description of the tables that must be set up to enable this functionality.
Parent topic
Customer Care and Billing Control Table Setup Sequence
This site works best with JavaScript enabled
