Defining Issuing Centers
This section provides information about defining issuing centers that are used to assign document numbers to bills and payment events. An issuing center should be configured for each location that issues bills. The installation record Document Number and Document Number Details algorithms contain the logic used by the system to assign a document number to a bill. To set up an issuing center, open > > >
Fastpath:
Refer to
Document Numbers for information about document number assignment.
This section is only relevant for some organizations. The information in this section is only relevant if your organization indicated on the installation record that it uses document numbers as an alternative bill id. If your organization does not use document numbers as an alternative bill id, then no other setup is required.
The topics in this section describe the base-package zones that appear on the Issuing Center portal.
Parent topic
