Budget Plan - Calculation Algorithm
On
Budget Plan - Main you must define the
Calculation Algorithm used by the system when it calculates a customer's recommended budget amount.
If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that calculates recommended budget amounts.
Parent topic
