Budget Plan - Monitor Algorithm
On
Budget Plan - Main you must define the
Monitor Algorithm used by the
Budget Monitor background process when it determines if a customer's budget plan is out-of-sync with their consumption patterns.
What happens? If the algorithm determines that a customer's budget plan is out-of-sync with its current recommended amount, an entry is added to the
Budget Review page.
If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that highlights if a customer's current budget amount is out-of-sync with their consumption patterns.
Parent topic
