Deposit Class - Good Customer
On
Deposit Class - Main you must define the
Good Customer Algorithm used by the system when it determines if a customer is considered good (the system recommends new / additional deposits for bad customers). Refer to
Deposit Review for a description of the background process that reviews customers for adequate deposits.
If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that determines if a customer is considered good.
Parent topic
