Deposit Class - Recommendation
On
Deposit Class - Main you must define the
Recommendation Algorithm used by the system when it calculates a customer's recommended deposit amount.
If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that recommends deposits.
The system uses the Review Tolerance Percentage to prevent the recommendation of small deposits by the Deposit Review background process. For example, if this field contains 10(%), the system would only recommend an additional deposit if the recommended amount was more than 10% of the existing deposit.
Parent topic
