Div. SA Type | Calculation Algorithm | FT Algorithm | Consumption Algorithm | Auto Cancel Algorithm |
CA/G-RES | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | Auto Cancel Bad Estimates |
CA/G-COM | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | NA - can’t estimate consumption. |
CA/G-IND | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | NA - can’t estimate consumption. |
CA/CABLE | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | NA - can’t estimate consumption. |
CA/E-COY | Apply Rate | Payoff = 0 / Current = 0 | Get Consumption from SPs | NA - can’t estimate consumption. |
CA/E-RESU | Apply Rate To Usage Request | Payoff = Bill Amount / Current = Amount Due | Get Consumption Using Usage Request | NA - can’t estimate consumption. |
CA/E-COMU | Apply Rate To Usage Request | Payoff = Bill Amount / Current = Amount Due | Get Consumption Using Usage Request | NA - can’t estimate consumption. |
CA/WO-STD | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable |
CA/WO-LIA | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable |
CA/CHARITY | Recurring Charge | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
CA/PA-REGU | Recurring Charge With Auto Stop | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
CA/MERCH-I | Recurring Charge For Amount To Bill | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
CA/DEP-I | Recurring Charge For Amount To Bill | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
CA/ONETIME | Billable Charge | Payoff = Bill Amount / Current = Amount Due | N/A - no consumption is needed | N/A - no consumption is needed |
CA/OVR UNDR | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable |
CA/E-SUB ENR | Apply Rate | Payoff = Bill Amount / Current = Amount Due | ||
CA/E-SUB BC | Billable Charge | Payoff = Bill Amount / Current = Amount Due | N/A - no consumption is needed | N/A - no consumption is needed |
CA/E-FIN SETTL | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable |
Bill Segment Type | Calculation Algorithm | FT Algorithm | Consumption Algorithm | Auto Cancel Algorithm |
BD RATED | Apply Rate To Usage Request | Payoff = Bill Amount / Current = Amount Due | Get Consumption Using Usage Request | NA - can’t estimate consumption. |
BILLCHRG | Billable Charge | Payoff = Bill Amount / Current = Amount Due | N/A - no consumption is needed | N/A - no consumption is needed |
COMPUSAG | Apply Rate To Usage Request | Payoff = 0 / Current = Bill Amount | Get Consumption Using Usage Request | N/A - no consumption is needed |
RECUR | Recurring Charge | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
RECUR AS | Recurring Charge With Auto Stop | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
RECURATB | Recurring Charge For Amount To Bill | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed |
SUB RATE | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption From Master Bill Segment | N/A - rated sub service agreements are cancelled when their master is canceled. |
Div. SA Type | Calculation Algorithm | FT Algorithm | Consumption Algorithm | Auto Cancel Algorithm | Bill Segment Type |
CA/G-RES | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | Auto Cancel Bad Estimates | SP-RATED |
CA/G-COM | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | Auto Cancel Bad Estimates | NOESTRAT |
CA/E-RES | Apply Rate To Usage Request | Payoff = Bill Amount / Current = Amount Due | Get Consumption Using Usage Request | NA - can’t estimate consumption. | BD RATED |
CA/E-COM | Apply Rate To Usage Request | Payoff = Bill Amount / Current = Amount Due | Get Consumption Using Usage Request | NA - can’t estimate consumption. | BD RATED |
CA/G-IND | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | Auto Cancel Bad Estimates | NOESTRAT |
CA/CABLE | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption from SPs | Auto Cancel Bad Estimates | SP-RATED |
CA/E-COY | Apply Rate | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed. | N/A - no consumption is needed. | COMPUSAG |
CA/WO-STD | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable | |
CA/WO-LIA | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable | |
CA/CHARITY | Recurring Charge | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed | RECUR |
CA/PA-REGU | Recurring Charge With Auto Stop | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed | RECUR-AS |
CA/MERCH-I | Recurring Charge For Amount To Bill | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed | RECUR-AS |
CA/DEP-I | Recurring Charge For Amount To Bill | Payoff = 0 / Current = Bill Amount | N/A - no consumption is needed | N/A - no consumption is needed | RECURATB |
CA/ONETIME | Billable Charge | Payoff = Bill Amount / Current = Amount Due | N/A - no consumption is needed | N/A - no consumption is needed | BILLCHRG |
CA/OVR UNDR | N/A - non billable | N/A - non billable | N/A - non billable | N/A - non billable | |
CA/E-SUB ENR | Apply Rate | Payoff = Bill Amount / Current = Amount Due | Get Consumption From Master Bill Segment | N/A - rated sub service agreements are cancelled when their master is canceled. | SUB RATE |
CA/E-SUB BC | Billable Charge | Payoff = Bill Amount / Current = Amount Due | N/A - no consumption is needed | N/A - no consumption is needed | SUB BC |
