Installation Record Setup
Specify an automatic payment algorithm that causes a match event to be created when automatic payments are created for open-item accounts. The base package algorithm will do this for you if you specify the appropriate parameter on the algorithm. Refer to APAY-CREATE for more information about this algorithm.
If you want a Control Central alert to highlight when the current account has any open match events, plug in the appropriate control central alert algorithm on your installation record. Refer to C1-OPN-MEVT for more information about this algorithm.
If you want to enable manual pay segment distribution for open item accounts, along with other functions, you will need to plug in an installation algorithm for bill balance calculation. Refer to C1-OI-BI-AMT for more information about this algorithm.
Parent topic
