Setting Up Tender Types
Tender types are used to indicate the method in which the tender was made. A unique Tender Type must exist for every type of tender that can be remitted. For example, if you allow cash, checks, direct debits from a checking account, and direct debits from a credit card to be tendered, you'd need the following tender types:
Tender Type | Description | Like Cash | Generate Auto Pay | Require External Source ID | Require Expiration Date | External Type |
CASH | Cash | Yes | No | N/A | N/A | N/A |
CHEC | Check | No | No | N/A | N/A | N/A |
OVUN | Cash drawer - over/under | No | No | N/A | N/A | N/A |
DDCH | Direct debit - checking | No | Yes | Yes | No | Checking withdrawal |
CRED | Direct debit - credit card | No | Yes | No | Yes | Credit card withdrawal |
Go to > > to define your tender types.
Description of Page
Enter a unique Tender Type and Description for the tender type.
Turn on the
Like Cash switch if this tender type is cash or the equivalent of cash. This indicator controls if the system generates a warning if a cash-only account remits a tender other than cash. It is also used to generate a warning for online cashiers to turn in their tenders when the cash-like amount exceeds the maximum amount balance defined for the
tender source.
Turn on Generate Auto Pay if this type of tender causes an automatic payment request to be routed to a financial institution. For example, this switch will be on if this tender type is used for direct debits from a customer's checking account (because every tender of this type will have an automatic payment request created when the tender is created).
The following fields are only used for tender types associated with automatic payments:
External Type This field is used by the background process that creates the information that is interfaced to the automatic payment source. Specifically, it controls the record type associated with the different types of automatic payments that are routed to the automated clearinghouse (ACH).
The values for this field are customizable using the Lookup table. This field name is EXT_TYPE_FLG.
Require Ext. Src. ID This switch indicates if an Auto-Pay Source that references this type of tender must contain an External Source ID. The External Source ID is the unique identifier of the financial institution to which the automatic payment will be routed.
This switch is typically turned on for tender types associated with checking / saving direct debits. It is turned off for tender types associated with credit card debits (you don't need an external source for a credit card debit, you just need the credit card number).
Expiration Date Required Turn this switch on if an Auto-Pay Option that references an auto-pay source that references this type of tender must also contain an expiration date (e.g., automatic debit / credit cards).
Turn this switch off for tender types associated with checking / saving direct debits.
Tender Authorization Indicates that tenders of a particular type require authorization prior to being created.
Business Object If Tender Authorization has a value of Required, a Business Object must be specified for the tender type. The primary function of this Business Object is to manage the authorization of payment tenders.
Fastpath:
For more information on authorizing credit card payments, refer to the Tender Type - Credit Card with Authorization business object.
Turn on Allow Cash Back if the system should automatically calculate a cash back amount when a tender is remitted for this tender type and the amount tender exceeds the amount being paid.
Parent topic
