To Do Entry Setup
Two To Do types are supplied with the base package:
• TD-MODTL. This To Do type highlights the presence of open, disputed match events.
• TD-MONTL. This To Do type highlights the presence of open, non-disputed match events.
Each of the above To Do types should be configured with the roles that work on entries of each type.
In addition, the account management group and/or divisions from which the default roles are extracted should be updated to define the role that should be defaulted for each of the above To Do types.
Fastpath:
Refer to
The Big Picture Of To Do Lists for more information about To Do lists.
Parent topic
