UOM / TOU / SQI
If using calculation rule-based rates, the calculation rule that calculates CCL requires the consumption that is subject to standard rate VAT as a service quantity.
If using component-based rates, the algorithm that calculates CCL requires the following service quantities:
• The percentage of energy related charges that is subject to standard rate VAT
◦ Define the SQI used to store this service quantity. You will specify this SQI as a parameter to the algorithm used to calculate VAT. Refer to the RCAM-VAT algorithm type for more information about the base package algorithm.
• The total consumption
Define the UOM / TOU / SQI used to store these service quantities.
Parent topic
