Setting Up Person Identifier Types
When you set up a person, you may define the various types of identification associated with the person, e.g., their driver's license number, their tax identity, etc. Every piece of identification associated with a person has an identification type.
How are person identifiers used? The reason why identifiers are defined on a person is so that users can look for a customer using one of their person identifiers (see
Control Central - Search Facilities for more information). In addition, person identifiers help prevent duplicate persons from being added to the database. The base product provides an algorithm type C1-PERSONVAL that can issue a warning or error to a user before they add a new person or update an existing person when another person exists with the same identifier. This is a BO validation algorithm on the person MO’s identifying BO.
Person identifier types are optional. An
installation option controls whether at least one identifier type is required on every person.
You can access the portal from > > .
This is a standard
All-In-One Portal.
Refer to the embedded help text for more information.
Parent topic
