Notification Preferences Overview
The Notification Preferences functionality is comprised of two main components: sending messages out of the system and maintaining customers’ communication preferences for receiving these messages.
Notifications are created by an algorithm plugged into the Create Notification plug-in spot on the Notification Type (BO). The base product provides the C1-CRE-NTF algorithm, which creates the notification via an outbound message.
The following sections describe specific notification preference concepts and how to configure the system to use notification preferences.
Parent topic
