Setting Up Bill Route Types
Bill route types define the method used to route bills to accounts. To define a bill route type, open > >
Description of Page
Enter a unique Bill Route Type and Description for every bill route type.
Bill Routing Method controls the type of information that may be defined when the respective
Bill Route Type is selected on
Account - Person Information. The following options are available:
• Postal: Use this method if the routing is via the postal service.
• Fax: Use this method if the routing is via fax.
• Email: Use this method if the routing is via email.
The values for
Bill Routing Method are customizable using the
Lookup table. This field name is BILL_RTG_METH_FLG.
The next two fields control how bills that are routed using this method are
printed (both in batch and online).
• Use
Extract Algorithm to define the algorithm that constructs the records that contain the information that appears on a printed bill. Refer to
Printing Bills for more information.
Parent topic
